Edit... nevermind
"^ ballinnnnnnnnnnnnnnnn!
Check out my quintet at FourzahMusic
My mom needs her airbag light turned off. Anyone got the tool? pm me
I have a socket I modified to ease the job of changing the CPV valve for the S54.
Anyone have an RTAB tool for an e46 (M3, if it matters) they are willing to loan out?
Need to borrow/rent fender rolling. In/close to Athens.
need spring compressor for coilover. im in douglasville but will travel.
Originally Posted by mtnracere30
Want To Borrow/Use Fender Roller----- Im in Alpharetta but would be willing to come to wherever you are to use it and i will pay you... PLEASE PM ME ASAP
| TRM | Wilwood | Nardi | ACS | FX-R's |
| Harrison Motorsports |
e46 airbag reset tool need next weekend!
yes i do. butttt
Bill came through to the rescue. turns out the seat belt buckles were fine, the previous owner must of just pulled the seats out at some point.
will you be around next monday?
who me?
Anyone interested in lending/renting a Fan Clutch Pulley Holder and the 32mm Fan Clutch Wrench?
Installing new water pump, thermostat, etc on the E36.
I could meet you at 4ngiefest, use the tool on Sunday, and return on a weekday?
I'm between Atlanta and Marietta almost daily...
thanks,
John
Need someone with an Airbag Reset tool in the Alpharetta or Atlanta area. 328iJunkie already offered but in SC and I wanted to see if anyone else closer in atl has the tool. Thanks in advance.
Hi, does anyone have a compression tester I could use for an afternoon? I live in Edgewood/decatur area. I can stop by, do the test and be on my way!
I have one, if needed, Makes water pump replacing a cinch. PM if interested. Located in Loganville, GA. work in Stone Mountain.
Anyone near Loganville/Grayson, need to reset ABS. PM and let me know what it will take to make this happen.
Hoping to get my camber plates in today. In need of air tools or perhaps someone much stronger than I... But yeah the bolts are way too tight for hand tools. Anyone in the midtown area?
I need to change the rear wheel bearings in my e30. Does anyone have the tools to replace them? I live in Gwinnett but commute to Marietta daily.
