Harrison Motorsports
Page 1 of 12 1234567891011 ... LastLast
Results 1 to 25 of 278
Thread: Tools available for local DIY projects
    Atlanta
    15 Alfa 4C, 17 M3
    I don't have any, of course, but a few folks suggested that we sticky a thread with available tools. Please use this thread only to post whatever special tools you have that you are willing to loan/rent out to other local users for DIY car projects. Please include contact information or specify that you want to receive PM's (only do this if you actually check your PM's often!).
    Let's see if this works.
    "My philosophy, in essence, is the concept of man as a heroic being, with his own happiness as the moral purpose of his life, with productive achievement as his noblest activity, and reason as his only absolute." - Ayn Rand
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    Airbag &CEL tool. and other poo.
    460whp/515wtq wifes MMW tuned 335i
    Oct 2007
    Atlanta: Come for the traffic, stay for the smog
    1995 M3, Avusblau Metallic
    I have a Peake Research Oil Service and Inspection light reset tool. There's really no reason for anyone to borrow it but I'll gladly reset your light if I ever see you around.
    Also, I have a nifty grey handled double-sided screwdriver and a set of wrenches; 8mm, 10mm, 12mm, and 13mm.
    Oct 2005
    East Cobb Snob
    97' M3
    AKG RTAB removal tool for E30 and other older BMWs. Makes a messy and hellacious task otherwise simple.
    http://www.akgmotorsport.com/rtabremove.html
    E39, E46, E36 Control arm/thrust arm bushing/tie rod removal tools. This press tool makes the outer ball joint incredibly easy...dont waste time with a pickle fork.
    45mm front hub nut socket with 1/2" adapter and custom inner race removal tool. Makes hub bearing chages a 30min job.
    14MM hex diff socket w/14mm spanner and 11mm 12mm flare nut tool for brakes
    Dec 2004
    Atlanta
    06 GS430
    I'd like to contribute bbaz, I have his # if anyone needs it.
    GO DAWGS!
    Atlanta GA
    328I
    36, 46mm sockets
    BMW bearing tool
    mini-sledge(to go with the bearing tool..)
    3/8, 1/2 torque wrenches
    assortment of metric gear box end wrenches
    assortment of metric sockets
    MIG welder
    OBD2 scan/reset
    12 ton shop press
    And a whole lot more
    Chris: 404-386-3617
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    who wants to let me borrow their rear wheel bearing tools sometime soon? I can trade borrowing my peake tools
    Oct 2007
    Stockbridge, GA
    98 Z3 M Roadster
    I would like my air bag light resest. Where do you find yourself on weekends?
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    i wont be down there this weekend (exams) but ill be down next weekend. Ill be around duluth/ATL. might go down to tech to help my buddy move out.
    Dec 2003
    ATL
    '11 1M, '13 Tacoma
    Quote Originally Posted by 328iJunkie View Post
    I have a valve spring tool I made. I heard it works pretty well.
    "We are the music makers...and we are the dreamers of dreams."
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    Yes thomas does.and yes it works amazing. and yes he will be getting it back this weekend
    Sorry for the delay. thanks again
    Atlanta (Conyers)
    73 Porsche 911 (sold) 97 M3/4/5
    I have a reset tool, I live in Conyers work in McDonough if you need a quick reset.
    Atlanta, GA
    E39 525i manual sport
    I have:
    RTAB tool(s)
    FCAB tool(s)
    FCAB lollypop tool
    All for a price, rent fee, or barter. FS too.
    Cosmos - Black l l Lux l HK l OEM clears all around l Depo HID's 55W 5000K l Strut bar
    Atlanta, GA
    99 M3
    I have the Carsoft 6.5 tool I got from Ebay. Functions like resetting service interval not working on my car, could be my DME. Anyone with the Peake tool want to compare notes?
    Oct 2007
    Stockbridge, GA
    98 Z3 M Roadster
    I'm actually in need of some mechanical advice/assistance on a brake bleed/antifreeze flush for my 98 M Roadster. I'm mechanically inclined but don't want to get into any major trouble by doing something that's not in the do it yourself manual I'm using. I will have the car on jack stands, wheels off, and have all supplies. I will pay for what I would think wouldn't take more than 2 hours of advice and the occasional help. I'm down here in stockbridge. Any takers...
    Apr 2008
    Alpharetta, GA
    06 330i, 88 M3
    I have big sockets (36, 46mm)
    36mm wrench for water pump
    17mm allen key for E30 tranny fill plug
    Various other hand tools used for E30 & E36 projects
    Apr 2008
    Alpharetta, GA
    06 330i, 88 M3
    Quote Originally Posted by charlesnr20 View Post
    Not sure if it's the same as E36, but the bleed procedure is easy.
    Connect pressure bleeder.
    Pressurize.
    Turn key to "On" position (no motor running)
    Open farthest bleed screw
    With the screw OPEN, have your helper pump the brake pedal 10x (don't worry fluid will not go back in), which tells the ABS controller to bleed
    Close bleed screw
    Repeat for other 3 screws
    Note that for E30s this is the same, except you need 12 pumps.
    Savannah, GA
    1997 M3/4
    I am in Savannah and have the following:
    Peake SRS tool (1994-2000 models)
    Spring compressors
    Air compressor and impact wrench
    Assorted hand tools
    2006 Acura TSX
    1999 Ford Ranger
    1997 M3/4/5 (Sold)
    1995 M3 (Sold)
    Jan 2006
    Dulluth,GA,USA
    1997 M3;95 325is(M p
    Anyone have camshaft locking/positioning tool I can borrow? for 6 cyll, and 8 cyll.Please let me know ASAP.
    Richmond, VA
    2017 F31 M Sport
    Peake R5/FCX-3-U good for 1987 - 2007. Yes, I went the extra $30 for the heck of it.
    Freude am Fahren
    2017 F31 Sport Wagon
    '11 VW Golf TDI (which retained its value *REALLY* well!)
    Jul 2005
    Atlanta, GA
    e60 e39 e28 e46 e36c
    Fender Roller...
    We can barter/rent/etc.
    Click for pics/vids
    BMW: e60 530i | e39 540i | e28 533i | 2002 |
    Chevy: 72 C10 (Lays Frame) | 70 Caprice
    Marietta, Georgia
    2001 Ti. Silver M3
    I have Autoenginuity SES Reset Software as well as the Desktop Dyno
    I also have the S54 engine valve tool
    as well as a ton of other crap that I cant think of right now...
    2001 TiAg E46 M3
    Atlanta, GA
    2011 335is, 2012 535i GT
    I have the peake reset tool. I am located near Newnan if anyone needs a reset down I-85 south.
    Nashville
    E34, E36
    Fender rolling tool & peake reset tool
    back & forth between Georgia Tech (ATL) & Savannah...
    Marietta, GA
    06 Impreza Wagon
    anyone with an e30 rear wheel bearing tool?
