what are you doing for the turbo timer?
just a direct wire into the ignition or are you running a delay ?
if so hows the delay addressed with the turbo timer ?
[ame]http://www.amazon.com/DEI-528T-Pulse-Timer-Relay/dp/B0009IR4AC[/ame]
When it loses ignition power, the pump continues to run for 10 seconds or so. You can set it to run for up to 90 seconds. If you used a turbo timer, it would still run for the amount of set time after the car shuts off.
Do it Carl. Do it.
Carl I usually hold anti lag for about 10 - 15 seconds when shutting the car down to make sure any residual oil is heated up so it can flow out nicely.
