Autogeek.net Car Care Products
** 10% off @ Autogeek.net - PinnacleWax.com & Wolfgangcarcare.com - Coupon Code = clubmember
Results 1 to 12 of 12
Thread: What to use to fill in paint chips?
    Jul 2006
    a big city
    none
    Hey, I'm prepping my car for paint, and it has more chips than a Herr's factory. I just need to know how to fill them in so that I can get a smooth surface to paint on. Should I use bondo, jb weld, or what?
    Dec 2001
    USA
    SV650 & '13 WRX Hatch
    Quote Originally Posted by Quailane View Post
    BMWCCA #387539
    Oct 2007
    Tyler,TX
    I would dry a filling agent like bondo, only a lil will work tho and you have to get it as even as possible, its risky, or you could just get some touch up paint and pile it in there and then wetsand to a smooth surface and then paint (lesss risky)
    SO-CAL
    how are you gonna paint your car? over your old finish? sand down the surface to flatten the paint down, this will lower the depth of the paint 'chips' so that theyll be easier to fill. Us a good quality high biuld primer and shoot the entire sanded area. once dry, blocksand to smooth level out the 'chips'. repeat the process until it is very even. then shoot your sealer, wetsand-600/800, color, then clear.
    '93 325i
    Overland Park KS
    2002 330 XI, 2003 Mustang Mach 1
    If you're prepping your car for paint, why fill chips? A re-paint will involve sanding and surface prep thereby bringing the surface to below the chip level.
    For spot chip repair, I use a rubber blade edged tool and touch up paint with reducer + hardener. I squeege the paint in the chip area, let dry and remove excess with a formulation of linseed oil and reducer. I then repeat the process until the chip is filled.
    Partial fill
    Finished
    Toto
    Detail Maniac!
    NY
    97 328i
    I have a baseball sized chip I've done 2 coats of filling in. All thanks to bird crap but its filling in nicely. Just a pain in the ass to fill in such a big spot with a paint pen/brush.
    Overland Park KS
    Quote Originally Posted by darthE36 View Post
    WOW!....that's a monster size chip area. I don't even want to see that bird LOL.
    Seriously, an area that big, I'd probably sand and airbrush. It would be quicker and give a better result.
    Toto
    Detail Maniac!
    Mar 2005
    California
    1999 M3 - HellRot
    Bondo is overkill, there is something called glazing compound, and it is used to fill in small holes(usually in bondo) that would work.
    But best practice would be to sand and use a good primer like nonn37 said.
    Benfer Cold Air - JC Shark - H&R Springs - B&M SSK - PowerFlex Bushings - Stromung - HIDs - V1 - Pull me over red
    Apr 2006
    NorCal
    MTree
    Is there a way to sand off excess touch up paint?
    Dec 2001
    USA
    Quote Originally Posted by M13 View Post
    Sure. You can wet-sand.
    Personally, I leave wet-sanding to a professional, it scares the bajesus outta me.
    BMWCCA #387539
    Aug 2008
    Chagrin Falls, OH
    05 A4(modded),323i
    Quote Originally Posted by ESMcBlurM3 View Post
    Yep, wetsanding is the way to do it. Langka System has a paint blob eliminator...never used it, but I gets good reviews. I've wet sanded many paint chips and excess paint...definatly leave it up to someone that knows what they are doing!
    ----> Top2Bottom Auto Detailing: Just Check the Website! Its Worth It.
    Nov 2007
    London, Ontario, Canada
    BMW 733i, BMW 540i/6
    there are filler type primers you can buy or you can apply a layer of puddy coat.
    1994 BMW 740I E32: SOLD
    1984 BMW 733i E23: Hartge engine, Hartge strut brace, Centra type 7 staggered 16" rims
    1997 BMW 540i/6 sport: polished/ported throttle body & traction control unit, E60 short shifter, ss braided flex lines, 2000 M5 tail lights, genuine Alpina bumper lip, genuine M5 auto fold mirrors, facelifted color matched trim
