I have a set of Girling calipers that will need rebuilding and an E12 MC to go along with it. $75 shipped.
please email me at fullswing at e21legion dot net.
thanks!
Any idea of the cost of rebuilding the Girling calipers?
Kevin
2000 Toyota Land Cruiser [2020-Present]
2013 Honda Pilot EX [2018-2020]
2003 Audi A4 Avant [2012-2018]
2004 Accord: [2006-2012]
1978 Black 320i [2007-2017]
1995 Boston Green 318is: [2001-2006]
Knoxville, TN
The easiest thing would be to use them as cores.Originally Posted by TheBestCow
i'm going to disagree. brake calipers are one of the easiest things to rebuild, providing they are not severely pitted by water damage.
a caliper rebuild kit list at bavauto for $13 without pistons, $30 on realm with pistons. i have found few times that new pistons are needed.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
14 f800gsa - red headed stepchild!
For you, Tom or for others similarly inclined. For most, it's time vs money so swapping them might be easier if you needed a pair you could slap on right away.Originally Posted by Tom D
As a professor of mine used to say, arguably, the best answer is "it depends".
While I was at the junkyard I found a 93 240DL and inspected the calipers. They looks identical to what you guys are using, except only have a single brake line instead of the dual lines. They only wanted $20 for the pair so I picked them up and compared to the photos on here and the factory E21 calipers and they are identical in every way except the single brake line. Not sure if this will make a big difference in braking power.
Just an FYI. I didn't come across anyone mentioning them, so it just opens up more possibilities I suppose.
I'll bring this one back.
I'm about to do this in the next week, w the 240 calipers. How are ppl bleeding these w the 2 ports? I've never had a car that had 2 ports on the caliper. I can see it being easy w 2 separate lines ... I guess I am just wondering if I tee the 2 fittings and do them both at the same time or maybe the inside first then the outside?
Thx
It's just two more fittings to bleed, you can't bleed both ports on each caliper at the same time. They are so close to each other, with similar line lengths that it doesn't really matter which one you do first. I bled the lower port on mine first.
Not to confuse the matter, but some of these 240calipers actually have three ports to bleed, I haven't been able to figure out why yet, maybe a high point that creates an air pocket? But if this is your case, just bleed them all, one at a time.
I picked up the 91-93 240 w/abs calipers - they have a single line but are otherwise the same as the dual-line calipers. They were a little more expensive, but there was much less hardware to buy, and install and bleed time.
I've been running them for about a month now and they work great. Thanks for all the helpful info guys!
going to bump this.
I want to do this swap but am uninterested in slotting the rotors as well as all the mods needed to run the mini calipers. Has anyone ever thought about contacting a manufacturer about making a rotor? Wouldn't we just need the 323i rotor but 15mm larger in diameter?
I contacted Stoptech and spoke to Eric Briefly about this. He said minimum orders for new rotors would have to be a couple hundred pairs.
obviously i am not going to buy 200 pairs of rotors
My thought is that if e21 and 2002 owners alike express the need for such a product that a parts provider I.E. VAC motosport, Ca Tuned, Bimmerheads, Ireland Engineering, Bav Auto ect. would step up and make an order or collectively make and order from Stoptech or another OEM provider.
Thoughts?
Ian
My rotors are still being grazed ever so slightly by the brake pads. I checked the pins and everything appears to be following JR's tutorial to the T. I also grinded off the backing plate portion which interferred.
Any suggestions on torquing down the two caliper retaining bolts?
@iferro there's an ebay seller in La Habra, CA from whom I bought a pair of authentic Brembo slotted, vented, and zinc-coated rotors from. I'm certain the rotors are correct, but as you can tell, I'm still having fitment issues.
Can you elaborate on this please, as I'm not clear on which part of the caliper you are referring to.
How much clearance should I expect between the rotor and pad?
Still trying to align the Girling calipers on my vented rotors (rotors for 77' 320i).
One pad always seems to graze the rotor ever-so-slightly, and I've tried different tightening sequence and different torque on the two caliper mounting bolts.
Should I try some brake pad shims to aid in aligning the caliper?
Bump.
Do you already have washers between the caliper and carrier?
I got m12, grade 10. Is that sufficient?
Has anybody done this upgrade without changing the master cylinder? My brakes feel like crap after doing the calipers and rotors, wondering if it's because my MC is stock. Thinking about going back to stock, I really just want to drive the damn car!
I have argued this so called 'upgrade' for years and no one has convinced me yet that it's anything more then a change of hardware. seriously guys, if you want better brakes then buy better tires.
Tom D
77 e21 - m42
88 e30m3
04 330 dinan3
84 r1000rt
02 r1150rs
all of them gray
Yes, if you are still using your original master cylinder, it most likely needs servicing, using the proper hone and new seals, a process I believe Tom has covered in depth somewhere in the forum.
If your e21 master cylinder has been tuned up back into good condition, there is no need to opt for a larger bore size master cylinder (especially if you've already ran new brake lines for two-port Girling calipers) unless you prefer the feel of shorter pedal play
I opted for the master cylinder used by BMW E12 models --with a larger diameter bore and two brake line ports on each caliper.
My refurbished MC cost about $80 refurbished (most likely using Chinese rubber unfortunately,) or you can find the superior ATE MC for more than $200.
I did replace the calipers' rubber with Swedish stuff.
I am one of the less mechanically-inclined forum members, but I have been spinning circles in my head for a year or more now, trying to figure out the flaw in Tom's argument- that the weakest link in the chain is an inadequate amount of tire on the ground. I have yet to disprove that theory however, as much as it bothers me
pretty sure Tom isn't referring to the amount of tire on the ground (size) but to the quality of the compound
rebuild your calipers and put some Hawk pads in them. don't have to be HP+'s, even just HPS. I've become a fan
