This is a car being built to conform to 3 different sets of rules, so there may be features that won't make sense to some. It is primarily being built to compete in Targa Newfoundland, however it will also be used for a lot of drag racing, and some road racing when time allows.
Before I share my build, I'd like to acknowledge the examples that I've used to help me with this project.
- Bimmerworld E46 World Challenge car
- Bryan Watts E36 M3
- Ryan James E36 M3 (In primer at that point)
- Chris Lewis E46 M3
- PTG E46 M3 GTR
Thanks to these individuals and teams for taking the time to share.
360 degrees of 330Ci:
The cage is pretty much complete, however there is still more gausetting, seam welding, and sheet metal work to be done.
any more details on what you have in mind?
That the first time I have seen that chassis do a barrel roll! Very nice.... Thanks for the nice mention as well. Good luck and let me know if I can help in any way. If you were close by I would come over and seam weld that puppy for you.
Chris
#175 CM E46 M3
Former Knee Dragger
Real name= Chris P. Lewis
Occupation= Green House Gas Creator, but I planted a GARDEN last year.
"When you live inside a vacuum, nothing sucks"
http://flickr.com/photos/8150451@N03...7602830737584/
Where's teh jaffster love? lol
You should make an animated gif of those pictures.
Do you have a closeup of the rear shock tower/bulkhead area? Whats that big column?
Also, are you running full rear coilovers?
Engine plans?
Steve,
80% of the design was finalized the fall of 2006. By October of 2007, everything was pretty much decided on and most of the bars had already been cut and fitted. If your cage had been completed earlier, "the jaffscage" might have been mentioned.
Good idea with the GIF.
Rear suspension will be stock configuration with Moton Clubsport dampers. (You can see the bump stops still mounted to the bottom of the car)
The entire stock rear bulkhead and parcel shelf has been removed from the car. Considering that every rear suspension pick-up point has been tied into the cage, we didn't see a need for the stock rear bulkhead so we cut it out to reduce weight. We then tried to minimize the amount of material used to build a firewall for the trunk-mounted fuel cell. This placed the "wall" behind the rear shock mounts, which left the rebound adjustment knob on the damper out of reach. The solution was to create a semi-circle recession that you could easily access the dampers from inside the trunk:
The engine will be a fully built M54B30 with a Euro S50B32 intake manifold.
Interesting, thanks for the pics.
You going with a carbon roof I hope
Ok ... who'll be the first to make an animated gif of that thing on the rotissary Make sure to morph them into each other so it's smooth! (I'm at work, so I don't have the software here!)
edit: I see Steve beat me to it
OK if you are SERIOUS about drag racing, eliminate all unnecessary brackets IMMEDIATELY!!
#175 CM E46 M3
Former Knee Dragger
You should be using a battery that is so small that it won't fit in the stock holder (unless the rules don't allow it). I also believe that most race cars eliminate the fuseable link, but I could be wrong on that. I cut out a many brackets as I could and it was like 7 lbs. total. I am still cutting them out. Took 5 lbs the other day. Working on 4 lbs of personal fat that needs to go as well.
Chris
#175 CM E46 M3
Former Knee Dragger
We are on the same page Chris. My fabricator and I spent over 2 days removing brackets and unessessary sheetmetal from the car. Here's a small sample of this:
Probably the biggest PITA was the multimedia bracket on the left side of the trunk...we ended up having to do a bit of welding to fill in the holes. LOL
Battery is a PC680 with custom bracket. (Stock bracket got ditched) I also have to run a rear mounted battery cut off switch for drag racing. (More pictures of that later)
Last week I was having fun with the wiring harness:
What is left:
What was removed:
This weekend I'm hoping to finish with the undercoating:
How did you mount your DME Chris?
Are you allowed to run stand alone ecu?
1st of all I'm dizzy!
2nd...Enjoy some video clips
E21 http://video.google.com/videoplay?do...arch&plindex=0
E30
http://video.google.com/videoplay?do...arch&plindex=2
E34
http://video.google.com/videoplay?do...arch&plindex=9
E36
http://video.google.com/videoplay?do...arch&plindex=7
another view http://video.google.com/videoplay?do...arch&plindex=7
Engine bay http://video.google.com/videoplay?do...arch&plindex=8
just for fun, bitchin scooter: http://www.youtube.com/watch?v=K1Z9oC2hdTg
Perhaps you enjoy the trusted Wankel http://www.youtube.com/watch?v=NKrQzkl65lE
Crazy Audi...turn up the volume http://video.google.com/videoplay?do...lee+audi&hl=en
I know there is a video of some crazy Z3 coupe dragster that does the gnarliest launch I've ever seen...think top fuel, but harder..I can't find it though.
The guy who invented the first wheel was an idiot. The guy who invented the other three, he was the genius.
Jon
CURRENT:
2011 E91 328i - Valentine One - LED Interior - Eibach Coilovers - Vossen Wheels
SOLD:
1989 E30 J-Stock
1995 E36 C-Mod
2003 E46 B-Mod
1990 E30 325is - Red on Black
1998 E36 M3 Convertible - Silver on Black
2000 E39 540i Sport - Black on Black
2005 325iT - Blue on Tan - 6sp - Koni's - Eibach - Valentine One - 3.64 LSD
2006 E90 330i - Silver on Black
2014 535i - Space Grey on Black - H&R - Valentine One
Finished up stripping the rest of the undercoating off last week:
More undercoating to add to my collection:
Total in the container: 10 Lbs.
Another 2.2 Lbs was removed previously about a year ago, and another 2 lbs was removed after the 10 Lbs was weighed.
So there's just under 15 lbs on the bottom of an E46 Coupe
Lightweight firewall
Photo for Chris:
Working on the dash:
What came off:
Tomorrow I'm having the dash dyed.
Fuel system work:
Nice work.
