my 2001 530i is approaching 85k miles, I have no problems with anything, thank god.
what service, if any, would you guys recommend as i approach 85?
thanks
The first thing would be to replace the Vanos seals -http://www.beisansystems.com/procedures/vanos_procedure.htm
Along with that work-while it's down that far would be to replace the cooling system--and do it completly--02 sensors-plugs-tranny fluid.
If you can make it to 100k miles it should be fine to do then--after which the car should be ready for another 100k miles.
2001 530i service I and II
- 2000 BMW 540i/6 (Anthrazit Metallic 397)
- 2001 Buick Park Avenue Ultra (Bronzemist Metallic)
- 1964 Buick Wildcat (Sunburst Yellow / Arctic White)
Fan Blades Can Explode.. Read My Thread
last part of #2.
That's all Fragz? Some people wonder why it's $$$ when they go to the dealer to do it.
The ATF change is not mentioned (lifetime BS I know).
And as Poolman mentioned - Vanos.
Here's a nice read on BMW maintenance. While it is from a E46 forum, the basics of the schedule apply with explanations from BIMMER magazine.
http://forum.e46fanatics.com/showthread.php?t=271535
But at your mileage, I would suggest a ATF fluid change if not done before.
should i get this done at the dealership? how much $$$ do you guys think we are talking here?
Please, if anything, change the transmission fluid before you're too late. The best idea I've seen is to change it now and then change every 30k religiously. Not to turn this into a transmission thread but the lifetime fill is so BS even BMW reneg'd on it.
-Denton
Replace (preemptively) the entire cooling system. Flush all fluids, have all joints, bushings, and moving parts inspected. Your Bimmer will thank you! It's not gonna be cheap but it sure beats a fried motor with seized pistons.
Rules to live by:
- Fast, reliable, cheap. You can only have two.
- Do it right, or do it twice.
- BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
1998 528i 5-speed sport - sandbeige with technical graphite trim - Jim Conforti Shark Injector - CDV delete - MY2000 M5 Xenon headlights - MY2000 M5 tails - PP M5 front bumper - E46 M3 paper filter - E60 545i shifter w/ E46 ZHP knob - 12" Alpine Type-R & 500w RF - CD53 w/ AUX input
thanks for feedback but still no one has answered whther i should get this done at the stealership or any german auto repair shop? please advise.
thanks
See post #11...
If you are taking the car to the dealer without a warranty, then you might as well bend over.
Take the car to an independent shop, or if you want to learn and save mucho money, do the work yourself.
Jason
i am located in west michigan
Don't do the dealership unless you have money to burn...
"If everything seems under control, you're not going fast enough. - Mario Andretti"
I just hit 86k. I'm just gonna drop it off at a Euro car shop. I don't trust myself to DIY the seals. I'm putting on new plugs next week, along with the tranny fluid swap. I'll send updates on non dealer shop prices.
While you may not realize it.....your suspension is worn and doesn't feel like it once did:
http://edgemotorworks.com/index.php?...d=27&Itemid=55
I have an 02 530I with 80k on it and have so far....replaced the cooling system (all parts including water pump and thermostat, did this during the supercharger install), did the vanos seals DIY and replaced valve cover gasket at that time, plugs, crankshaft position sensor (went out at 70k and when it goes there is no warning or codes thrown, the engine just shuts down....no default values in the ECU for this sensor), Koni FSD shocks all around. All belts were replaced at the 60k stage 2 service done at a local indy.
Next....02 sensors
2002 530IS 5 speed, Sapphire Black/Sand, M-Tech sport package, premium package, ESS Twin Screw supercharger, Southbend high performance clutch, Performance Gearing 3.15 LSD.....1999 M3 Cosmos Black/Black, Active Autowerks intercooled supercharger, H&R suspension and a bunch of other stuff....
