Results 1 to 4 of 4
Thread: DIY: M50 Manifold Install - Modifing the OBD2 IAT sensor to fit into the OBD1 Manifol
    Aug 2003
    Austin, Texas
    1997 BMW 328is
    Exclamation DIY: M50 Manifold Install - Modifing the OBD2 IAT sensor to fit into the OBD1 Manifol
    See the picture below. This works great!
    -Robert
    97 BMW 328is - cosmos blk/blk - 2door - 5speed - sport package
    Shark Injector - Cosmos Racing CAI - UUC Clutch Stop - UUC Underdrive Pulleys - UUC Delrin Shift Carrier Bushings - UUC SS Clutch Line - UUC TME Red - UUC Stainless Steel Brake Lines - MZ3 SSK - Bilstein Sport Shocks - Eibach Prokit Springs - 96+ M3 Offset Strut Mounts(swapped) - 96+ M3 Rear Sway Bar -
    96+ M3 Control Arms - 96+ M3 LCABs - E46 M3 RSMs - X-Brace - Turner RTAB Limiters - Turner Brass Caliper Bushings - Fan Delete - Rear Shock Tower Brace -
    Jan 2012
    Washington DC, DC
    1996 BMW M3
    thanks for the photo. i am still confused as to why the OBD one cannot be used. the electrical connector looks exactly the same. Different calibration for the sensor?
    Nov 2003
    Washtington State
    98 Estoril M3/4/5
    Great info. I tried this but the threads would not take and the small plastic nub wore down to nothing. So I found this option
    http://store.bimmerworld.com/modifie...ion-p1515.aspx
    Instead I removed more plastic and was able to essentially create the same thing without having to buy one from bimmerworld. Works great!
    bmos's Avatar
    bmos is offline Enthusiast and Technician
    Feb 2015
    Cumberland, ME
    1973 Bavaria, 1998 M3
    I know this is an older thread but I notice the bimmerworld IAT link is broken.
    In case anyone needs it, here is the new link: http://www.bimmerworld.com/Modified-...version_2.html
