See the picture below. This works great!
-Robert
97 BMW 328is - cosmos blk/blk - 2door - 5speed - sport package
Shark Injector - Cosmos Racing CAI - UUC Clutch Stop - UUC Underdrive Pulleys - UUC Delrin Shift Carrier Bushings - UUC SS Clutch Line - UUC TME Red - UUC Stainless Steel Brake Lines - MZ3 SSK - Bilstein Sport Shocks - Eibach Prokit Springs - 96+ M3 Offset Strut Mounts(swapped) - 96+ M3 Rear Sway Bar -
96+ M3 Control Arms - 96+ M3 LCABs - E46 M3 RSMs - X-Brace - Turner RTAB Limiters - Turner Brass Caliper Bushings - Fan Delete - Rear Shock Tower Brace -
thanks for the photo. i am still confused as to why the OBD one cannot be used. the electrical connector looks exactly the same. Different calibration for the sensor?
Great info. I tried this but the threads would not take and the small plastic nub wore down to nothing. So I found this option
http://store.bimmerworld.com/modifie...ion-p1515.aspx
Instead I removed more plastic and was able to essentially create the same thing without having to buy one from bimmerworld. Works great!
I know this is an older thread but I notice the bimmerworld IAT link is broken.
In case anyone needs it, here is the new link: http://www.bimmerworld.com/Modified-...version_2.html
