when i started my car and drove for 45 seconds a red lit icon appeared on my dash. it is a circle and it is surrounded by 6 blocks. 3 on each side... i don't know how to explain it better sorry but i think that means something is messed up i just don't know what happened and if i should drive it still. if anyone had any info about that i would greatly appreciate it, oh and my car is a 93 325i if that helps.
-Pampifide
Brake lining sensor. Pull your wheels off and inspect your pads. The brake lining sensor that is affected will need to be replaced. You might need new pads as well.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
thank you stradmaster
i have the same issue. my pads are fine. is there a way I can reset the sensor, or do I have to get a new one?
Usually those pad sensors only cause the light if they get damaged. I'd look over your pad sensors and see if you see any visible damage. If it's damaged, then you need to replace it.
SÜNDE REISEN
If you routinely change your brake pads before the light appears then the sensor never becomes used (damaged) and can be kept. Once the light is illuminated, the brake sensor must be replaced.
It means you got a special Alaskan distribution car that has 600 bhp.
