Results 1 to 20 of 20
Thread: Z3 driver door latch problem
    Oct 2002
    Simi Valley Calif.
    Topaz Blue 2001 Z3 3.0
    2001 3.0i
    I'm sure you guys have dealt with this before and I have searched through the posts, drivers door handle does not always open the door. i can push on the door a little from the outside and pull up on the handle but i want to fix it.
    BTW, the dealer says that i have to replace the part. $450 after laughing i thought i would look into this further with the gurus. Recommendations?
    Also, Is there a "how to" on pulling the door panel and fixing/replacing this thing?
    Thanks,
    Blu
    Pomona, CA (SoCal)
    '01 titan silver z3 3.0i
    i had this problem as well, door would be hard to or would not open at all unless i put pressure on the door. after some quick read-thrus on some threads regarding the problem, i came upon two main solutions: 1) using a torx tool to twiddle with the latch (on the car, not the door) and 2) simply lubing up the door latch mechanism (on the door)
    considering i only had a spray available with me at the time, i went for option 2 since it was easier and cheaper.. and after a quick few sprays, the door opened with ease..
    Toledo, Ohio
    1999 Z3 2.8 Coupe
    Quote Originally Posted by byronface View Post
    +1. Had the same issue, asked Randy, he rubbed some grease on my...uh...latch, problem solved. Haven't had a problem since.
    1999 Z3 Coupe
    Removed: spare/jack/tool kit/fog lights/A/C/knee bolsters/center cargo bulkhead/subwoofer housing/rear wiper/trunk floor
    Forbes diff mount/trunk floor reinforcement
    Forbes custom bolt-in rollbar
    Whalen Shift Machine and billet hood release handle
    TCK S/A coilovers
    16" x 9" BBS E26 3-piece magnesium racing rims
    Unorthodox crank & alternator pulleys
    3.0 300mm discs with PF pads and braided stainless lines
    Shift light & MZ3 shifter
    Momo steering wheel
    lightweight motorcycle battery
    Corbeau seats
    IE subframe bushings
    Straight pipe w/resonator tips
    Current weight, 04-26-09: 2,680 lbs, 55.7%/44.3% CAT certified
    Dubai
    Jeep GC V8, M Roadster, Supra TT, Merc 190E AMG
    I have this issue. What I discovered much later is that if you tug the door handle from the side closest to the rear edge of the door, it opens!
    Oct 2002
    Simi Valley Calif.
    Thanks to all. Byron, nice photo gallery.
    You may have saved me $450 from the rotten dealer.
    I'll let you know.
    Blu
    Oct 2002
    Simi Valley Calif.
    Yep, the grease did it.
    Interesting that the latch has a plastic coating that has worn off at the end. my guess is that this is like a permanent lubrication so grease doesn't have to be added to the catch. Well, it does now.
    los angeles
    '01 Z3 Coupe, '91 318i
    If it turns out that grease won't fix it, I have the complete door handle assembly. It was replaced by the dealer under warranty when I was having problems with the lock cylinder spinning in place. I have both sides available as I recently replaced them both with chrome handles. Anyhow, let me know if your interesed, and if you buy my rear bumper, you can it free.
    Dec 2004
    Boston, MA
    M3, MZ3, 348TS, Chevelle
    Quote Originally Posted by robrez View Post
    What was the problem, and how was this fixed?? I just screwed mine up the other day and now my driver's side lock cylinder just spins around in place.
    BMW M3 - Ferrari 348 - Chevrolet Chevelle
    los angeles
    Quote Originally Posted by Itsablurr View Post
    Here're a DIY for fixing the spinning lock cylinder problem.
    I'm not sure why the dealer chose to replace the whole thing, but it was under warranty.
    Dec 2004
    Boston, MA
    Awesome. Thank you! I'll have to give it a shot as soon as I have some warmth...
    Europe
    2010 GTi
    ha yeah I had this same problem a little liquid wrench fixed mine!
    Mar 2005
    If anyone else has this problem, I recommend using white lithium grease in spray form.
    Tyrone, Ga USA
    2010 135i M Sport 6MT
    I might go ahead and put some on there to make sure i dont run into that problem
    Oct 2002
    Simi Valley Calif.
    Yes, i used the white spray grease.
    For now It worked great.
    Mar 2006
    Valparaiso, IN
    1998 Honda Civic Si
    I am having a similar problem but my doorhandle by the lock seems to be coming off the door about 1/16". If I press on the lock/plastic (right rear side) the door opens fine. This is annoying when having the car worked on. The mechanic always asks 'what's up' and I tell them I have an 'anti-theft lock'....hillbilly style. I think I am going to need more than lube for this fix.
    Robert
    98 Silver Z3 Roadster 2.8 (6/07-3/09)
    Currently Bimmerless :/
    Jul 2010
    Los Angeles, CA
    1998 Z3
    Hey wow. I had this problem and it was going to cost me a couple hundy to fix. I just sprayed w-40 in to the latch, and it fixed the problem! Thanks guys!
    Victoria, BC, Canada
    1998 Z3 1.9 and Audi Q5
    +1 on the white lithium grease. My driver's door would only open from the outside some of the time. I was going to disassemble and check for bent parts before the door stayed permanently closed. I saw a post on this forum to try the lithium on the latch mechanism (in the door jam). I was suspicious it could be this simple, but am very happy I have not had a problem since. It is now part of my routine maintenance to grease the latch mechanisms.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    I put it mostly on the hook part (of the latch) and barely any on the striker post (on the door jamb).
    In both cases, just a smear will do, as you don't want to be dragging your clothes (or worse: wife/gf's clothes) across it.
    You can always put more grease on a year later, when it starts to act up again
    Jun 2019
    Ocala, FL
    2001 BMW Z3 Coupe
    I have a 2001 Z3 Coupe.
    On both doors, I need to press above or below the handle, or lift upward from the handle, to open the doors. From the inside, both doors open fine.
    WD-40 and Grease DID NOT work for me.
    However, success achieved by using Torx socket to loosen latch on car (not door) and pushing it down and out a bit, and then re-tightened.
    All your comments were useful too. Thanks.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by Schoelow View Post
    ... loosen latch on car (not door)...
    It's often called the striker, for search purposes.
    BMW MOA 696, BMW CCA 1405
