How about Castrol Syntec 5W-40 for a M62?
It's rated API Service SL, SJ, CF, BMW longlife 98
1999 540it - Schwartz II/Sand Beige, style 5 rims, Conti DWS 235/45 tires, Billy HD/Sports, Stoptech S/S BL, F1 Pinacle 35% tint, Zionsville Cooling kit
1998 318ti Cali Sport - Schwartz II/Schwartz Anthratz, staggered style 23
1997 318ti Sport - Schwartz II/Schwartz Anthratz, staggered style 68 ,
1995 318ti Active - Alpineweib III/Schwartz, squared style 32
1994 325i - Bostongrau/Tan, Billy Sports, H&R springs
1991 318ic - Schwarz/Anthratz Stoff, Bilstien HD, Z4 3.0 SS, Magnaflow, S/S Stress bar, x-brace, M20 FW, Elipsoid/HID, K&N
BMWCCA# 160411
1995 318ti Sport Schwartz II/Schwartz Anthratz - Sold
1985 635CSI - Schwartz\Sand - Sold
1984 533i "Max" - Schwarz/Schwarz, - Sold
1984 318i - Champagne/Tan, Stock - Sold
Should be fine.
Thanks Pete! Reading through the thread and a similar chart I pulled from a 2007 version of TIS, I really could not pick what was optimal for a daily driver in 100+ degree weather for a M62. I figured the Syntec would be OK.
I typically have been running Mobil 1 15w-50 for my 533i, but had been reading this was too heavy for the M62 and still get average mileage.
BMWCCA# 160411
BMWCCA# 160411
ok great, just changed my oil and filter using mobil1 0w40. Thats what I used last time, but I misread S62 as M62 in the chart and thats where I got confused.
Pete was right. The TWS is just some of the M engines.
Fyi, the Mobil1 0w-40 causes excessive noise in a lot of engines.
Just remember that German Castrol 0w-30 is the only true synthetic. The 5w-40 is just a Group III. If that matters to you...
"If everything seems under control, you're not going fast enough. - Mario Andretti"
Hey Jared! Luckely, I'm not smart enough yet to know what that really means.
So, even though Castrol Syntec 5w-40 claims to be a full synthetic, are you saying it's not? Is it enough that it is listed in the approved oils for LL-98?
Sorting out what's ideal vs. whats approved vs. whats readially available is the confusion for me. (Not jumped too deep into this...)
BMWCCA# 160411
BMWCCA# 160411
BMWCCA# 160411
hmm... I can read it just fine.
Sweet M52 can use any of the LLs 97s rule!
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
BMWCCA# 160411
'00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.*Trans failure at 244k+...FS Now
i use mobil 1 0-40 no complaints...good part is the Merc uses the same oil...
No but I picked up the info from here...there's a lot of good info on this site and it appears to be unbiased.
appears is a good word....
Even though it was tested by an independent lab, the test was basically requested by Amsoil. Amsoil is the only company (plus RP, I think) that still uses the results of this test in their marketing materials. Many scientists claim that the 4-ball wear test does not properly reflect the conditions in an actual car engine.
Not saying that it's wrong, but basically every oil company has their own battery of tests on which their products excel and those are the tests that they push in front of the customer. Recently Castrol was pushing a message (during superbowl ads) that their Edge results in 8x less wear compared to Mobil1 using IVA testing sequence.
Nevertheless, Amsoil does really well on a lot of those tests. Here's a more recent and more complete document of theirs:
https://www.amsoil.com/lit/g1971.pdf
Yeah, but notice the small print below the table where they advise against using LL-04 oils in gasoline engines outside of Europe.
Hard to say. Back when the LL-98 specification first came out, I'm sure there were quite a few full synthetic oils out there that met it.
But nowadays, this LL-98 spec is not all that stringent (by comparison to some other newer specs) so it doesn't require the latest and greatest oil chemistry. Oil manufacturers will use the lowest-cost ingredients to meet the spec. If they can meet the spec by using Group III base stocks, they will.
I would guess that most of the LL-98 oils nowadays are Group III, unless they also meet some other specs (in addition to LL-98). But again, Group III does not equal bad. As long as the oil does the job, who cares what it's made of. There are some new bio-oils (basically vegetable oil) out there that perform as good or better than full synthetics in certain engine applications.
Last edited by quattro PETE; 05-07-2009 at 02:55 PM. Reason: Automerged Doublepost
