2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
Glad to be of help once in a while, even though I don't frequent this forum as much anymore. But I'm not surprised to see this thread still being brought up to the surface every now and then. The subject of "which oil to use" will never die. It's quite fascinating, really. For example, there are boutique lubricants made from vegetables nowadays that rival group IV/V synthetics in terms of performance and resistance to degradation due to fuel dilution, high temps, etc. Granted, they won't make it onto BMW's approved oil list due to prohibitive costs of testing/certifications, but one day they may become more mainstream and then who knows... we may be putting Crisco 0w-20 in our 2025 BMWs.
How about Beef tallow!
http://getg.com/engineOil/5W-30.php
After further research, it appears Group III oils are not inferior to Group IVs as it seems to be made out. Oil refining has come a long way and in some cases Group IIIs can be just as good or better than Group IV due to additives as Group IV does not take to additives as well as mineral based. It is also rumored Mobil 1 is 70% or more PAO. So given all the information garnered these few days, unless I can find Euro formulas more readily and close to the $4+ I pay for M1 5w30. I am sticking to it despite those who think I am better off with a true synthetic and LL-01 per European Standards.
More great reading for those who are interested in the the advancement of Group III oils:
http://www.bobistheoilguy.com/forums...Number=1104963
http://www.machinerylubrication.com/...oil-technology
http://www.machinerylubrication.com/...ase-oil-trends
Group III oils shear faster, sludge easier, and their molecular structure is not as uniform. 99% of the time they don't do as well in UOAs as a PAO or Ester.
No one is trying to convince you to change your oil but as I've stated over and over.
Manufacturer specs are there for a reason. Everyone not running an oil that meets manufacturer specs should run UOAs.
"If everything seems under control, you're not going fast enough. - Mario Andretti"
ABSOLUTELY!!!!
You're still overlooking a lot of what I'm saying. Manufacturer's specs are not just about shear stability or TBN. Your oil will probably have plenty of TBN left after that OCI. It may still have decent viscosity, but what if there are other issues? You have no idea if your oil is really protecting your engine or if it is slowly eating itself. Without a UOA you can't see the wear numbers.
As I stated earlier, an oil is not just viscosity. Every good oil manufacturer will have several SKUs for the most popular viscosities. If we pick on M1 for instance, one of their 5w-30 blends may be fine but another may not. The same can be said for Total, Amsoil, Lubro, etc. They're each blended for different purposes.
Entire engines have been wiped because the wrong oil was used. I'm not saying you need regular UOAs, but do at least one or two to make sure you are ok. Chances are you'll be fine, but what if you're not and you see high wear numbers? Isn't a couple UOAs cheaper than a new engine? Is it worth risking your engine over a couple dollars on oil?
Thanks. Understood. Will get Blackstone labs analysis next go round.
In the end, it is not about using spec'd oil then, it's more about UOA for each members' personal usage patterns because even something within spec can have bad UOA reports and with ever changing formulations, one should probably get UOAs more often than one would think.
chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/grayMods:plate delete, debadged, 35% tint,euro console, Evans NPG (zero pressure cooling system), CDV delete, Rogue Octane SSK, RP Symcromax
See: My REGISTRY PICTURES
I had GC analyzed after 10K miles in my 530i... lab's conclusion was that it needed to be changed at that point, but wear was still low. It's just that TAN was creeping up, indicating increasing acidity.
Well it's time for me to eat my words. I've said many times that I have never seen any LL-01 oil sold at any Walmart ever. I just got home from my local Wally-world and they do indeed now have a shelf stocked with Mobil-1 0w40 Euro Car oil at $6.57 as a regular price. Still no GC though.
Thanks. I 'll check Wally-world again next time. $6.57 is better then the $8.49 at Advanced Auto and even then they usually only have 4-5 quarts at a time.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
Don't feel bad. My local China Mart never stocked M1 0w-40 and they still don't. But I know some of them do. Not sure who makes these decisions... I guess local store managers.
As for GC, it was never sold at Walmarts in the US. It is sold at Walmarts in Canada though, from what I've heard.
Hello Addam,
Per below our on-line Oil Recommend Tool, Mobil 1 0W-40 is the best choice
for youe car. And when you feel the engine power get less than B4 or find
lube oil consumption coming up, it's the time to use Mobil 1 5W-50 which is
more suitable for vehicles with high milage. Hope this helps.
(Embedded image moved to file: pic08568.jpg)
************<a.smithgolfpr ***********************************************
************o@gmail.com> *************************************************
************************************************** *********************To
*************************************<Lubeline@exx onmobil.com> ***********
************06/10/2011 ************************************************cc
************08:50 PM ************************************************** ***
************************************************** ****************Subject
*************************************#292921-AU(English) - Lubricants: ***
*************************************for Cars and Trucks *****************
The following inquiry was sent through:
Brand:
First Name: Addam
Last Name: Smith
Position Title:
E-mail: a.smithgolfpro@gmail.com
Company:
Address:
Country: Australia
Phone:
Fax:
Current Customer: Yes
Question:
Hi There
I own a BMW e39 535i Sports 2000 Model. I have had my oil changed two times
by two different mechanics on the Gold Coast in Australia. I requested
Mobil one that meets my cars standard request and both times I have had
Mobil one 5w-50 added to my engine and told it was the right oil. But after
lots of studying I have been told Mobil 1 0w-40 is the Oil I should be
using can you please tell me what is right.
Thank you
Addam smith
Sorry to dig up an old post, but are you referring to ALL M vehicles, or just the newer ones like the S54 equipped E46 M3 and newer? I was going to try Total 10w50 in my S52 equipped 1997 M3, because i wanted a heavier oil to guard against lifter tick after occasional autocross runs..i currently run Euro Castrol 0w30.
Bump ^^^^^
Sent from my POS android phone using BF.com
About oil filters, should I stick with Mann, or are the alternatives at least halfway decent?
Jeder lobt was Nürburgring-erprobt
Yeah, you're right. I couldn't bring myself to try anything other than OEM. My inquiry was more along the lines of acceptable subsitutes, because only Advance Auto bothers to sell Mann, and I dont expect them to have it readily available all the time.
Why is the BMW M twin oil not on the list?
I use full synthetic 5 w 30
