When I turn the wheel completely to the right the tire makes a grinding sound....I don't believe it does it when I turn the tire completely to the left.......the belts are supposedly a little worn and I am looking at replacing them.....any thoughts on the problem?
Check all the plastic pieces in the wheel wells. I had that problem once and found out I had a piece of my spoiler that needed to be bolted back in place because it was rubbing against the wheels when I turned hard to the left.
James
2005 Imola Red M3 - VF Stage I Supercharged Street/Track Car
E46 M3 VF Engineering Stage I Supercharger DIY
if i had to gues based on that limited information I would say its a wheel bearing.
If you push on the wheel does it have any play??
