----SOLD----
I have an instrument cluster pulled from a 1996 UK M3 Evolution. It's in absolutely fantastic condition, and has ~134,200 miles on it. I bought it recently but decided against installing it.
$300 OBO.
1999 Estoril/Gray M3
Bump.
If Euro why the MPH outter ring? Just asking cause my Boy has a '94 Canadian E36 318is, and it ONLY has KPH, no MPH ring at all.......
John
'95 Hellrot M3 w/Dove
AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
the rev limiter different though so it most likely is from an evo
It's from the UK. They still use MPH over there. It is from an Evo, hence the higher visual redline. The speedometer also reads to 170 instead of 160. Also, in the US we have a red line at 55mph, whereas the Euro clusters do not - a relic from the days of a US national speed limit.
It also has an Oil Temperature gauge below the Tach, which the US clusters do not have. We have the MPG gauge.
isit easy to wire up the oil temp gauge on us car?
That's interesting, if I could justify buying that I probably would. Nice
VP Anyone have a Girlfax?
You have to run a wire from a sender in the oil drain plug or an oil distribution block (LeatherZ sells ODBs for about $100 with senders preinstalled) to the cluster. I've heard it's not too bad.
If you're planning on upgrading your oil cooler to the better Euro system (bimmerworld sells the complete kit for $850 or so), it has a spot for the sender already. Otherwise you need to buy an ODB or a drain-plug sender.
hmm I have the ODB. Just more than I want to spend at the moment, good to know.
Bumpalicious.
Sale pending.
damnit. I want to find one with mph on it for when it goes back to the states with me
98 Euro E36 M3 (ExSMG)/99 M3 Daily Driver/93 M3 (S54) TBD-hp/TBD-tq ) Current NASA track record holder TTD on street tires @ 3450lbs (Eagles Canyon 2:05.3, MSR-Houston 1:47.08)S52E36 TWS CCW 1:54.8, COTA 2:30.6 Race Lap 3yr old 245/40/18 Hankook Z214 C51)
well what happened....
Sold. Sorry.
Doh
