You never explained how you went about just having the angel eyes light and not the parking lights. Something about covering the contact on the parking bulb?
Firstly,
Thank you for taking your time and effort to write up a well described and easy to follw DIY with good quality pics. I'm sure plenty of owners have taken advantage of your good will.
Well I followed you write up (almost) to a T but unfortunately didn't get them sparkling as much as yours. I actually started with 800 grade 'cause I figured my h/lights weren't as bad as yours (way back on your first post). I followed with 1,000, 1,500, 1,800 then finished with 2,000. I took my time and spent about 5 minutes on h/light per grade. Wrapped it up with PlastX just like you recommended.
On the first pic (about half way through the procedure) you'll see that I've sought of partly gone through what looks like a protective coating or similar. Have I or what? Do I need to start all over again with the 400 like you did and 'cut' through that coating?
The end result does look better than when I started but I reckon they could/should look even better.
Yeah, I guess it was a big secret for you,wasn't it? To answer what kit and where did you buy it from AND if your AE in front of the lenses?
You dont have to if you dont want to...
It my opinion looks like you are almost there BUT either didn't apply enough force while working with Meguiars PlastX.
In my opinion 800 is not enough. You gotta go atleast with 400/600. Then if everything done right, you dont need 1800. Just go from 1500 to 2000.
Also, I dont think there is protective coating. I raped mines starting with 200 (and washed away a lot of powder) and they came out not that bad (see pics above).
Do you have a pic of how they looked before?
PS. Btw did you open them cause reflectors look kinda foggy (dusty)?
Cool! You will be fine.
You dont have to go with 200. 400 is more than enough. I did mines with 200 because they were too bad AND I wanted to make sure I am not gonna do it again.
Working with 200 took most of the time. It produced a lot of powder. I did it until I was sure there are not pits left. Few times I stopped, wiped it with paper towel drying and making sure i did not miss any pits.
Then I used 400 which took about half of time I spent with 200. Again, I stoped once in while,drying and making sure i did not miss anything.
Once you ve done 1000, it feels very soft AND when its wet you may think its almost done, BUT once its dry it becomes all foggy. Then you continue with 1500 and 2000 until there will be almost no friction left.
@Pistonbroke, mine looked the same with that "protective coating" look. I spent more than 5 minutes on each grit though. Especially the final grit. I really wanted to make sure the sanding was uniform. And a lot of elbow grease when I applied the PlastX.
Just picked up a set of ccfl AE's... thank you so much for posting this! I can't wait to get them installed! My lights were so pitted that I figured I needed to buy a whole new setup. You have just saved me hundreds of dollars!
Next I need to go to my indi to get my DRL's deleted.
I am in the process of refinishing my headlights on my Z4 right now. The "protective" coating was actually starting to yellow and had deteriorated on top of the light and looked terrible. I obviously have had to sand through that to get it to look well. So for those of you who have done this a while back and sanded through the coating (If you went 400 or 600 you definitely did), how are the lights holding up so far? Beyond the Plastic Polish are you guys running any sort of wax/seal on it? Thanks!
I didn't bust through all of the coating but the whole headlight is holding up ok. Obviously, to keep them clear as long as possible, periodic touch up will be needed. I need to take mine off and redo the PlastX stage at least, but they are nowhere near as bad as they were when I originally did this. I didn't use any kind of sealant or wax.
Check it out! I installed my AE's today!
I didn't clean my lenses because I was short on time, but I will get to that another day.
THANK YOU SO MUCH for posting this DIY!!!!! It went very smoothly thanks to everyone's input here on bimmerforums!
There's nothing like the feeling of finishing a project yourself!!
Nice job!!! You're car is almost identical to my bro's.
http://forums.bimmerforums.com/forum...&postcount=313
Pull out your parking bulb, you will see the two contact points for the 2 filaments. Trial and error which one controls what and use some electrical tape to cover the parking filament. Describing it can only help so much, you have to get out there and do it.
lol! Yes, it's a giant secret...
Go to ebay, search for 4000K CCFL Angel eyes...
Seriously, if you have a question not being answered in a thread, just PM the person... they won't bite.
UNDER CONSTRUCTION
- 2000 528i Sport -
Got any questions about my car? Feel free to PM me!
Update:
One of my inverters went out again, so, Fab and Orkhan insisted I place the inverters inside the housing as per this DIY. I have a couple of things to add to the DIY.
1- The DIY is on a light housing that doesn't have a circular window for viewing the level bubble. I had to route the AE ring cables with a slight deviation around the window (will post pics tonight).
2- The double sided tape I used to secure the inverters inside the housing was too thin to reach the curved housing wall. I doubled up the tape and it adhered to the housing with no problem.
Props to Orkhan for the CCFL Inverter!
1-
2-
Thanks a bunch...for both answers,
I understand, you probably were away doing something else...jk
Thats what I thought. Different temperature. Yours of 4000k are looking so close to real ones, that's why I asked. Mine's are more blueish, but still cool.
UPDATE
I dont know if this topic popped up before, but make sure you use tape that will hold high temperature. I recently opened one of my lenses and found out that tape I used to secure the wires is almost vaporized.
siny528i
Hey! I just recently purchased a 1997 BMW E39 about 3 weeks ago. I used to drive a Toyota Camry and am loving my new ride. I am new to the forums and BMW for that fact. I want to install these AE as my light output is really poor however I don't know specifically which AE will fit my car. Will those from a 2000 and up model fit my 97? And what kelvin should i consider? Any help will be GREATLY appreciated. Thanks you guys.
I wish I could post some pics but I didn't make any. I will try and post them for the second lens.
I used heavy duty construction tape when I did mines about 9 months ago and I just found out that its all melted.
You just need to search Ebay for "Angel Eye E39". Read description if its gonna fit your car. 6000k - white but slightly blueish, 4000k - slightly yellowish, that makes it look like real ones. I have now 6000K installed and I like them. Its not really too blue, but if they go out I will replace them with 4000K.
in this pic 1 has been sanded and polished and the other is untouched. i have both finnished now and will be doing the AE upgrade soon too. must say big thanks for this guide its worked brilliantly
Nice job tsx.
You can definately tell the difference.
GL with the A/E upgrade.
