Results 1 to 12 of 12
Thread: e36 shift knob usually falls off....what do must replace it with for race usage?
    Apr 2001
    Argyle,Texas
    95 M3 S/C
    I noticed its common for e36 shift knobs to come off while shifting when they get older. Was curious if there was a common knob most you guys replace it with ??
    P.S. I'm saving money for my first DE anybody wanna help ??
    2011 Toyota Highlander (wife)
    2002 X5 4.6is - 225,000 (Dead)
    2001 Toyota 4runner
    1995 S/C M3 - 99,000 miles
    1995 525i - 244,000 miles (sold)
    1999 528iT Touring - 175,000 (sold)
    1992 318is - 325,000 miles (Sold)
    1986 325e - 180,000 (sold)
    Gainesville, Florida
    BMW Z3 Supercharged
    A metal knob. I have the UUC. It's great. On the BMW knobs, the plastic tabs do tend to break soon.
    stjobs
    Apr 2001
    Argyle,Texas
    95 M3 S/C
    stjobs
    Yah I was curious on this since there is so much shifting and it tends to be "aggressive" shifting. Looking for a knob that wont wear out soon.
    2001 Toyota 4runner
    Aug 2002
    Orlando, Fl.
    '99 M3
    This same exact thing happened to me less than 2 months after I got my car while I was at the dragstrip. You could go with the recommendation of the above post and go with the aftermarket knob, but if you want to retain that stock look, BMW has an identical piece except that the shift knob and boot are combined into one unit, whereas the old style has the knob separate from the boot which eventually leads to the knob flying off while shifting aggressively.
    The BMW dealer replaced the whole assembly under warranty with the one-piece unit, which looks exactly like the previous setup, which totally eliminates the chances of a repeat occurence.
    '99 ///M3 13.766 @ 100.12
    Gruppe M style CF intake, Eisenmann Race exhaust, Kosei K1's, Motorsport side molding badges, Rieger gt cup front spoiler, OEM ///M5 trunk lip spoiler, 6000k HID+Predator Chromium angel eyes w/parking light delete, Bilstein Sport struts/shocks, Eibach springs, Rogue Engineering RSM's
    BMW Z3 Supercharged
    The UUC isn't going anywhere, it's much heavier than stock, made of solid aluminum, fits tightly and attaches with a stainless steel set screw. It makes shifting feel smoother and more solid, and also slightly shorter.
    stjobs
    Nov 2001
    Overland Park, KS
    E30, E36/5, F350
    Pretty much all of the aftermarket knobs attach with a set screw. Just find one that is comfortable for you.
    Feb 2001
    Lone Star State
    '09 Mini Cooper
    stjobs
    a metal knob in texas !!! the summers here are 100 deg +, unless u want the logo on the shift knob burnt into ur palm, u might wanna consider leather or carbon fibre knobs
    HTH,
    Dec 2002
    just put a stock knob on it and quit forcing the shift lever past the point of engagement
    installing a bolt-on knob does nothing for correcting the root cause of the problem, some drivers don't know how to differentiate between shifting fast and being hamfisted
    Mar 2002
    El Segundo, Southern Cali
    03 530i, 96 328is, E30
    My favorite knob is the Momo Short Anatomico (lower right #34 in the chart). It shortens the throw a bit and like most other Momo knobs it's secured by three set screws and i've never had one come off yet. Simple and effective :-)
    Randy Walters
    '89 325is (Competition car, now sold)
    '96 328is (Weekend Fun car w/M3 suspension, just sold)
    '03 530i Sport (Spare car)
    '05 X3 3.0 (Little Woman's DD)
    '21 Mazda 3 Premium Sedan AWD (Daily Driver)
    BMW CCA & SCCA Driving Instructor
    BMW CCA L.A. & S.D. Chapters
    Multiple SCCA Regional Championships
    Apr 2001
    Charlotte, NC
    '91 E34 M5, '89 325i, '00 Saab 9-5 Wagon
    While a stock knob can/does wear out, it is likely caused by poor shifting technique. In reality, the force you put on the shifter should in no way be in a direction that would force the knob off. Regardless of what knob you use, work on your technique.
    UUC has a decent article about shifting on their site:
    http://www.shortshifter.com/techniques2.htm
    If you are forcing the knob off, you probably aren't shifting correctly, and you are definitely being harder on your transmission than you need to be. Chill out and try to be smooth.
    Apr 2001
    Argyle,Texas
    95 M3 S/C
    I dont shift incorrectly or so I think. I've drove my car for 2 years and hav'nt broke any knobs I guess everyone was assuming I can't shift properly. But hey I suck at spelling so I'll give u that one. I just know a few guys around the dallas area that have broke theres before. Someone else driving my car broke my shifter so i replaced it with a stock shifter. Seems just as good and the metal ones feel weird to me.
    2001 Toyota 4runner
    Apr 2001
    What TeamZ4 and BMWRacerITS said. Besides, if you're grabbing the knob and ripping it around with that much force, it's a lot easier to misshift. Chill out, try to be smooth, and guide the shifter from gear to gear, instead of grabbing it in a deathgrip and yanking it around.
    And, a tip for those of you using aftermarket knobs - a little blue loctite on the setscrew works wonders. My UUC knob tended to loosen up and rotate a little. Finally loctited the setscrew and tightened it up - never had the problem again...
    Jim
