Results 1 to 25 of 34
Thread: Entire e36 Wiring Diagram
    Aug 2003
    Huntington Beach, CA
    M3's = Sold..for now
    I needed to find a wiring diagram for a problem with my car and came across one. Figured I would post it for anyone else who could use it. Its in pdf format.
    http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
    Jun 2003
    HB, CA
    95 M3
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Here is the complete list: http://wedophones.com/BMWManualsLead.htm
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Sep 2004
    Bucks County, Pa
    1995 M3, 1992 Saab 900, 2003 WRX
    Awesome!
    Ill be re-wiring my racecar soon and this will be great
    thanks
    Josh
    Nov 2007
    Belleville/ Oshawa
    92 Bmw 325i/ 92 Mazda mx-3
    Hey guys i have a 92 bmw 325i i was wondering if anyone had the engine wiring harness diagrams. I see the one above is for a 95 and 96 cars. thanks
    Arlington Heights, IL
    Z1, M3 LTW, 228
    Bentley
    Its amazing just how much is in that manual for wire diagrams.....
    I have tackled innumerable wire problems in my car.
    In fact, I was able to find a rare error in the manual as I tore apart my ABS wire harness, cut all the wires to the ABS dme, and spliced in the portion needed to run the euro M3 DME for ABS.....
    I made my own fusebox from a stripped down chassis harness....
    It really clarifies things like duplication of wires for the lights and their check light function etc...
    Very few things are omitted, but it can be tough to find some items.
    Alex.
    Alex Lipowich
    xyobgyn on AOL
    Trying to make the world a better place with 5 extra throttle bodies at a time.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by Shawno View Post
    Did you check the link I posted? It has all of the manuals.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by M3 Euro LTW View Post
    Alex.
    Agreed, but the ETM (posted above) goes above and beyond the Bentley. It has EVERYTHING, and is very model specific, so there is not much multi-model routing to figure out. I'm using it now for a race car ... putting in an ABS from a 92 into a 97, and gutting the other wiring. They whole check module circuit is crazy ... so many wires just to tell you that you hava bulb out
    Dec 2003
    Laguna Beach, CA
    '08 Touareg, 03 M3
    Where did you find the Euro Wiring diagram? Is it available somewhere online? Do you happen to have a link?
    I am going to be retro fitting A/C onto a '95 with the s50b32 and want to make sure I wire in the aux fan correctly. I have no trouble reading a wiring diagram, but I need to make sure I am looking at the right one?
    Alex.
    2003.5 E46M3 - BBS RGR, BMW Motorsport 3.91, JRZ/Dinan S3 suspension, SuperSprint V1 Stepped/cats, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
    My Journal
    Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    The link posted above has the euro models as well
    Dec 2003
    Laguna Beach, CA
    '08 Touareg, 03 M3
    really? ...I couldn't find any s50b32 diagrams. I will look again...I found the S50b30, are they the same?
    My Journal
    Ft. Lauderdale, Fl
    E36 M3, Mk2 GTI
    Wow thanks for posting this, can finally track down some wiring issues
    Oct 2008
    Spain
    318is & 1996 M3
    E36 M3 engine into E36 318 compact
    Hi all,
    Good information ive got from the wiring diagrams but I still have loads of doubts. Just to fill you in, crashed my m3 earlier in the year but luckly the engine, gearbox and lsd was in one piece and working. So I purchased an e36 318 compact have have fitted the engine and gear box in, went straight in adapted various bits and Im all ready to go.
    I have manged to do some wiring and the engine turns but it doesnt start, the fuel pump doesnt come on, even manually powering the fuel pump it still doesnt start, although this way fuel does get to the engine. Using the 318 pump.
    I know ive still need to do some wiring and there is a relay missing but I cant get find the information i need to complete the wiring. I need to match the 318 fuse box to the m3 computer and engine wiring.
    Unfortunately i left the m3 fuse box in the car and its already been scrapped.
    Any help or suggestions would be great.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    You are going to need to find an EWS antenna ring, and a new key. Then you are going to have to have the EWS aligned. If you had taken the EWS antenna, steering wheel lock and key from your old car and installed it, you wouldn't have had these problems.
    Search EWS swap...
    Caribou Maine, USA
    1994 325IC
    Thanks! Convertible top was kickin' my ass! Hopefully this'll help
    Sep 2004
    Ohio, USA
    96 M3, 97 M3, 2008 MiniCooper S
    Quote Originally Posted by ScotcH View Post
    Looks like a great site. Thanks for the post.
    Ken
    96 M3, no sunroof, OBD1-M50 intake manifold, ASC delete, CAI by TMS, Shark, VAC oil pan baffle kit, VAC HD oil pump shaft, VAC oil filter top, JB light-flywheel, B&B cat back, AA headers,underdrive pulleys, TCKline Coil overs-Koni SA, JT Design front strut bar, HR springs & bars, TCKline camber plates, Power Flex throughout, X brace, B&M-ssk, 4pt roll bar, fiberglass hood & trunk, Recaro Driver and Corbeau pass. seats and Schroth 6pt, Zionsville alum rad. JT Design front splitter, Z3 power steering rack (2.8 turns), A/C delete, Racepak IQ3 Data Acquisition plus eng oil pres, eng oil temp, eng water temp, brake pressure, and throttle position, final drive - 3.64 LSD by Blanton.
    Tampa, Florida USA
    Silver BMW
    really love the wiring diagram. thanks a biggie
    May 2005
    Melb,Australia
    3.0 Euro M3, 328is track
    Im looking for wiring diagrams and any manuals in general for the E36 M3 Euro 3lt and 3.2lt
    Post up
    BLAKE AuST
    Sep 2010
    Dallas Tx
    1993 BMW 325i 4dr
    Sep 2010
    North NJ
    97 E36, 3rd Vin "S"
    im trying to click on the links and they just freeze when i try and pull up any of the manuals...is anyone else having this same problem. I really need the wiring diagram for a 92 325is climate control, the non automatic climate control system. any suggestions?
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Right click, then choose "save as"
    Louisville
    1999 M3 Cpe
    awesome diagram! thanks. However, I'm having trouble finding the pin fuctions for the dimmer switch. I'm trying to splice my autometer gauges into my dimmer. HELP!
    Jacksonville, FL
    ņangara GT
    links are dead.
    Anyone have an updated site?
    Feb 2002
    Prince Frederick, MD
    10 Tiguan, 09 TDI, 95 M3
    Quote Originally Posted by shellback View Post
    links are dead.
    98 M3 link worked for me!
    2014 Jeep Grand Cherokee Limited, 2013 Ford Mustang GT (Track Package, Recaros, Tech Package), 2006 Honda Civic (Beater!), 1995 Cosmos Black M3 Coupe
    Jacksonville, FL
    ņangara GT
    NM, got it to work.
    Maybe now I'll learn how to read this stuff...
