Results 1 to 14 of 14
Thread: Is this the tilton oil scavenge pump to use?
    Tampa, FL
    97 E36M3 S54
    Question Is this the tilton oil scavenge pump to use?
    http://store.summitracing.com/partde...5&autoview=sku
    Also a32guy said he found a fitment kit with all AN fittings and lines. Who makes this?
    Mar 2005
    CT
    E36, WRX
    Thats the pump I used but I didn't find any kit, I just ordered the fittings I needed from Jegs. Summit would have the same I'm sure.
    Tampa, FL
    97 E36M3 S54
    Would you do it the same way if you had to do it again?
    Mar 2005
    CT
    E36, WRX
    Quote Originally Posted by M52 POWER! View Post
    Yep.
    If I was to get elaborate I'd pretty much do Carl's setup. He did a great job. Not sure of his username at the moment, but you can find his M Coupe build within the next few pages.
    Atlanta
    M3/4/6, X5 4.4
    Quote Originally Posted by a32guy View Post
    Yep.
    Hey Chris, were you pretty much convinced you HAD to run a scavenge pump? Did you look at any options (creative drain line), or were you pretty sure you were gonna from the get go?
    J
    Sep 2004
    Atlanta
    67' GTO & Turbo E36
    scavenge pump = waste of $ and time... I have never had any problems even with my old cheap-O ebay manifold...
    Dec 2002
    New York Pot Hole City
    2017 Golf R
    I have a Boost Logic Oil Scavenge Pump for sale if anyone is interested BRAND new
    Mar 2005
    CT
    E36, WRX
    Quote Originally Posted by DADx2 View Post
    J
    Jim,
    I pretty much just assumed as it was cheap insurance. I'd rather run a $150 pump and some fittings than sacrifice a $1250 turbo. Maybe if you got creative, you could make it work. Not sure though.
    Good luck!
    -Chris
    Dec 2003
    memphis
    Lots o' m3s
    Quote Originally Posted by JordanMD88 View Post
    scavenge pump + waste of $ and time... I have never had any problems even with my old cheap-O ebay manifold...
    Except for that whole cracking thing :
    http://forums.bimmerforums.com/forum...3&postcount=11
    A scavenge pump isn't necessary for every manifold design, but with the 666 one you are placing the turbo a bit lower than some of the log style manifolds.
    You can probably get away without using it, but to some people (like me)...it's worth a few hundred dollars to have the peace of mind that a) your car won't smoke and b) to minimize any future time spent under the car wrenching on minor things.
    SOLD -A dozen ///M3s of all shapes
    techno550 is offline Senior Member Supporting Vendor
    Nov 2003
    Atlanta, GA
    E36's + 300D
    if the turbo placement is such that it doesn't need a drain, adding a pump is only going to add a failure point. A turbo that doesn't need a drain but has a pump on its return line will have issues when the pump fails.
    the electric pumps are fairly reliable. annual replacement should keep it in its safe life expectancy.
    Michael McCoy TRM
    Tampa, FL
    97 E36M3 S54
    Quote Originally Posted by M3Romeo View Post
    How does it compare to the tilton? Price? Pics & Info plz!
    Dec 2002
    2017 Golf R
    Its $225 + shipping fro boost logic, if anyone wants it I will do $200 shipped...Its brand, never used...I didnt take pics of it but heres a pic from boostlogic, its exactly the same!
    Aug 2002
    AZ
    BMWs and 'Yotas
    What are you running instead?
    Reigning and Longest Tenured OT President to Date
    Oct 2003
    richmond hill ga
    930 pt67 1.2 bar , 328i pt67 1.2 bar
    we have the same pump and also offer a extreme duty version of that pump that we run on some outlaw 10.5 cars
    here are the details on the new one
    • 350F Fluid Temperature
    • 3 GPM Pump Rate, 60+PSI
    • Hardened Bronze Gear Pump Rotors
    • 10,000 Hour Rated Dual Ball Bearings
    • 10,000 Hour Rated Over-sized Brushes
    • Black Anodized Extruded Aluminum Heatsink
    • Nickel-plated Pump Head
    • Stainless Steel Pump Head Fasteners
    • 3/8" NPT F Threaded Pump Head Ports
    • -6AN M Nickel-plated Adapters
    • Hi-Temp Wiring
    • Weatherproof Connectors
    • Rubber-isolated Mounting Bracket
    • Low-vibration, Quiet
    • 6.2" x 4.1" x 4.1" size, 6 lbs
    • 12 Volts Nominal
    • 5 Amp Nominal
    • Two-year Warranty
    the economy version like shown in the post above is a great pump but the pump housing itself is plastic and it rated at 1.75 gpm and 300 deg
    i got injectors
