Wow, he came out in my thread...I feel so special
Nah, if they came with the E36 WCT they would have been size 13 or something, Sofro is a big dude lol
'07 was a rebuild
and '08 Dave comes out??
always something new from Mr. White
Track Car - '88 S52 Track Rat (build in progress)
Daily Driver - '00 A4 1.8T Quattro
Track Car Part Out - http://forums.bimmerforums.com/forum...1#post18628719
Steve will we get pictures of the carbon fiber seat booster? At 5'6 you should be racing a horse or in an open wheel car.
Leave the tin tops for big guys.
Lol, ouch, low blow (no pun intended).
Ok kids, enough fun, its a build thread, lets keep this to another thread. Thx
Not funny, although I do prefer karting and formula cars. If formula cars were safer in club racing (or should i say drivers) I would be running a DSR right now. I almost bought one instead of building the E46. $75k and you can run slow DP laptimes!
Found them at pegasus race supply.....are these the same ones?
http://www.pegasusautoracing.com/pro...asp?RecId=4594
$467
69' BMW 1602 Vintage Racecar BS-L Racing w/ VARA in Cali (@1602racer on IG)
10' Toyota FJ Pre-Runner (LS3 big suspension - @trophyFJ on IG)
17' F250 6.7l Tow Rig and shop truck
'12 X5d Wifeymobile
89' M3 *Sold / 88' M3 *Sold / 98' M3 Sedan Sold / 06' M3 Comp.Pkg.SMG *Sold
My 1602 race car build thread.
That'd be them. You'll also want to look into the Remote Bias Adjuster, as well as the cantilever throttle linkage. Depending on your motor setup, it could be easier to do it right on the throttle assembly (s54 has off the shelf kits from tuners like Evosport). I like the adjustability right on the pedal though.
How does one convert the OEM throttle Hall sensor to work with this setup?
Sorry for the newb question.
EDIT: After looking at the Evosport kit you referenced, I assume you're converting the throttle to a cable linkage? Since you mentioned using the OE electronics, how do you reconcile the lack of throttle data with the ECU?
Are you talking to me or James?
I'm using AEM, and an M50...I might even use a morseteleflex pushpull cable for the throttle, but i have to see how much resistance it has on the return, otherwise i'll beef up the return on the throttle body.
Nice, I like to see OEM component integration like that, as the OEM components are usually better than 90% of whats available "off the shelf."
And typically cheaper...
