Okay, now that makes sense. Since my last post I veirified exactly what you said and you are correct. I cut open my old leaking tank and could see that the magnet on the float surrounds the sensor reed switch when the float is at the top position. If the float goes lower due to less coolant, the magnet moves away and the reed switch on the sensor opens causing the dash light to come on.
My dash light stays on because the aftermarket (non-BMW) coolant tank I bought off ebay probably doesn't have the magnet on the float. Kinda pissed about that, but that's what I should expect from cheap Chinese crap. So I can either short the leads on the sensor plug to keep the light off, or buy and re-install a proper tank.
Huge word of advice: test the new tank BEFORE installing it by installing the sensor, plugging it in to the harness connector, turn the tank upside down, and turn the ignition key on. If your coolant light is on, return the tank and get a proper one.
FYI: you can remove the sensor without removing the tank from underneath the car by reaching your hand over the transmission fluid cooler and twisting the sensor clockwise. It unscrews a quarter turn in the opposite direction you would expect (like a left hand thread).
Need a DME or EGS update?
https://forum.e46fanatics.com/showthread.php?t=1081716
Coding 530i after AT->MT Swap
https://www.bimmerforums.com/forum/s...ter-AT-MT-Swap
You could not be more wrong.
The coolant level sensor inside the expansion tank is very simple, it is a reed switch that closes when the magnet on the coolant level float (the red plastic stick) is near it and turns on the dash light indicating the coolant level is low. There is no heater or anything else. It is a simple height measuring device, on/off based on the proximity of the magnet to the float.
This information was already amended earlier in the thread. We have also validated that Sapote is a jerk (lol).
Yup. Because of its orientation it cannot turn counter clockwise as the tank's outlet is right there. It's only a quarter turn, so not too bad. When you see it, you quickly realize it can only turn one way. See the attached photo.
You can remove the sensor without draining the coolant, because it sits in a sealed compartment and works through magnetics.
The windshield washer fluid level sensor is the exact same part, so you can swap with that one as a test.
Well they had a float in the e36 expansion tank and it didn't work well either.
Sorry but critter explanation is total bs. Pls exlplain how the light could be triggered by simply pushing the float down. Clearly a magnetic resistance sensor. Not similar to the THREE WIRE system you describe (which IS how both oil level and maf work. No more arrogant bs pls. Shut your mouth if you don't know what you talk about.
