Thanks for the clarification. I am selling an old suspension and once the auction ends and I receive payment I will send you payment,
Also saw that you can burn chuck stickley chips. Wondering what kind of performance and cost it would be for the following
OBDI 2.8l m52 with m50 manifold, s52 head(Does this have a higher rev limit?) and s52 cams.
Thanks for the quote. I also noticed that you said something about sending you a dyno tune after the chip is installed and you will rework the chip. What all is involved with that?
Also forgot that this is going into a build date 6/95 325is so it has EWS
I will probably be ordering the software through you here in a month or so seeing that you have good pricing. Thanks for the info.
ABS SPEED SENSOR FREE SHIPPING IF ALL 4 ARE PURCHASE, IF NOT $7 SHIPPING. PAYPAL TO CMUZYY@AOL.COM
1 34 52 1 163 027 ABS Sensor FRONT $50 EACH ATE BRAND $40 FEBI BRAND
2 34 52 1 182 067 ABS Sensor REAR $55 EACH ATE BRAND
Sorry to keep being a pain, but what is the price for a fan clutch and fan?
Not sure if they are different for the cars, but please check a 97 328 and 95 325
Also do you offer aluminum thermostat housings for the 328 with gaskets?
Once again sorry for all the questions, but your pricing is so good it has allowed me to look into other upgrades or replacements. Thanks again for the great pricing.
You forgot to quote:
front sway bar bushing for standard suspension on E36 with 24MM sway bar w/ p/n 31-35-1-090-263. I forgot to mention my sway bar diameter, sorry.
Also you quoted me for coupe hood shocks, I need sedan ones; same price? Are the hood shocks aftermarket? Which parts are OEM and which are aftermarket? Or are they all aftermarket?
When are these prices good till?
Cosmos - Black l l Lux l HK l OEM clears all around l Depo HID's 55W 5000K l Strut bar
OK, I'll play. What price would you have for an Rear View Mirro with radio electron PART#51168213057
Now in E92 M3 ZCP -- Absolute beast
All parts for a '95 M3:
Rad. expansion tank - $55
88 degree thermostat - $??
Throw out bearing (21512226729) - $??
Fly wheel bolts - $??
Shifter bushing (25111221822) - $??
Bitch clip (25111221849) - $??
Ball cup bushing (25111220600) - $??
Shift arm bearing (25111222015) - $??
Fuel filter (13321270038) - $??
Valve cover gasket kit - $??
All shipped to 22310?
How much for pressure regulating valve 97 328is: 11151703484
shipped to 14606?
free shipping for this complete order. paypal to cmuzyy@aol.com
[QUOTE=Tom153;11810912]All parts for a '95 M3:
1 11 12 1 437 395 Valve Cover Nut Seal $ .66 x 15
2 11 12 0 034 107 Valve Cover Gasket Set $18
3 13 32 1 270 038 Fuel Filter $10
4 25 11 1 222 015 Support Bushing $26.88
5 25 11 1 469 397 Shift Tower Bushing $4.80
6 25 11 1 221 849 Locking Pin $5.58
7 25 11 7 507 695 Bushing $1.69
8 11 22 2 243 051 Flywheel Bolt $2 x 8
9 21 51 2 226 729 Clutch Release Bearing $36
10 11 53 7 511 580 Thermostat $13
can i have a quote for a e46 328i clutch kit?
