Page 11 of 11 FirstFirst ... 234567891011
Results 251 to 273 of 273
Thread: E30 M3 - Supercharged S50B32 [RNGTOY]
  1. #251
    Virginia Beach
    e36 M3 Supercharged
    Oh lord
  2. #252
    Reykjavik, Iceland
    ´99 M5 Avus Blue Metallic
    Here is the power curve for a similar motor that my tuner
    friend tuned:
    Nice curve for a track car
    Thordur
    1999 E39 M5 Twin Supercharged
    1989 E30 M3 S85 w/DCT swap in progress...
  3. #253
    DALLAS, TX
    e24, e30, e36, e61, e70.
    Holy hell how did I not know this existed in 07 Awesome thread mate!
    ​IG: @Street.Ego
  4. #254
    Sofia (Bulgaria)
    90 3??, 96 328i
    S85? Oh good lord
  5. #255
    Reykjavik, Iceland
    Yup, stroked to 5.4L with a M-DCT gearbox
    Thordur
  6. #256
    Reykjavik, Iceland
    This has been "progressing" slowly....
    Other things in life seem to get in the way of spending time/money on this
    Got a friend of mine who has already tore down his Europameister E30 M3 to help me yesterday, he´s very normal:
    Drysump tank out:
    Surface rust under battery:
    Rear side windows out and started to remove the heater:
    Worse has been seen on E30's, hopefully salvageable:
    Small rust dot on the A-pillar:
    Seems ok here:
    Some cancer:
    Garage filling up with parts
    Need to get some off to storage:
    Took the drysump tank apart while taking it out, cleaned it and reassembled:
    Plan now is to strip the car as soon as possible and then it´s getting blasted by "Dustless Blasting" (Home - Dustless Blasting). Then I´ll get a better idea how much metal work has to bee done.
    Thordur
  7. #257
    The Netherlands
    DE-spec E36 328i/M3 cab
    Awesome thread, never seen it before. Already been a while since it was last updated and seems to have died suddenly.
    How's the car doing?
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
  8. #258
    Reykjavik, Iceland
    Project still alive and progressing slowly
    Pics of the DCT box - on it´s way from Denmark:
    Will be interesting making it fit... the E30 tunnel is not quite big enough
    Also, finally the S50 engine is sold & paid for.
    Gave up on the original buyer and sold it locally - here is the happy new owner picking it up:
    Will go into a mint 1990 E30 316.
    So now the S85 is on the engine stand with the parts list.....
    Thordur
  9. #259
    H-Town/Los Angeles USA
    bmw e36 328i 4dr saloon
    ohh my, I like where this is going. Keep up the good work!!
    1996 328i (m52B28US) OBD1 euro ZF 5spd. 3.23LSD conversion / Chem. PnP Head/ DINAN stg.2 CHIP/ VAC race valves/ S52 cams/ A/C delete/ fan delete/ Washer Fluid resv delete/ ARP head studs/ Cometic 140MLS / VAC Solid Engine/trans Mounts/ CAI / 2.5"Borla race exahaust/ NGK R spark plugs, M50 Mani, S50 Oil Res, Riot Racing HFTB, SAMCO Hoses, JBR FW, X-Brace, Mtech Front Bumper, RE RSMs, stoptech SS lines, Bilstein sports, H&R Race Springs, S52 Reinforcement plates, Kosei K1 w/ bridgestone RE960as, Brembo/stoptech slotted rotors, M3 Trailing arms, M3 Calipers, M3 Axles, ACS strut brace, weight reduction.
    http://mbuild.blogspot.com/
  10. #260
    Reykjavik, Iceland
    Finally something happening..... DCT box transported from Denmark to Iceland:
    And seems to fit nicely in the tunnel - maybe I will not need to butcher it:
    And finally, a slight change in plans regarding the engine. Sourced a complete stock engine, will run that to start with.
    Rod bearings will be changed and then later I will go for the sleeved block stroker build:
    Will arrive in Iceland next week.
    PS. This thing had kept me busy, but now it´s complete the M3 gets some attention again
    https://www.bimmerforums.com/forum/s...C-E39-M5/page9
    Thordur
  11. #261
    Iceland
    BMW 850
    This is just insane.
    Keep up the good work Þórður
  12. #262
    Reykjavik, Iceland
    Quite the size difference between the stock S85 pan and the dry sump pan!
    Thordur
  13. #263
    Feb 2004
    JHB South Africa
    E46 330iT E36 328i
    This build just got a whole lot more crazy! I like it!
  14. #264
    Reykjavik, Iceland
    Some progress with dry sump install.
    Needed to thread one hole and put a bolt in it to block it.
    A good friend of mine that runs a CNC business is happy with the workmanship of the pan!
    AC and steering pump have to go:
    Also have to remove the chain that used to drive the stock oil pump as well as the chain guide/tensioner:
    Pumps out of the way. There you can see the old output of the oil pump and the oil input into the block:
    Chain off, had to loosen up the vanos pump to do so.
    Stuff off:
    Pumps and oil filter housing off:
    Here you can see better the original oil output and input into block:
    Inserting the ARP bolts:
    Blocking plate and new input for oil into block:
    Output blocked:
    Both installed:
    Pan in place:
    On the left is the new pulley for the dry sump pump. On the right is the stock crank pulley, need to machine the AC part off:
    Here you can see how it fits together:
  15. #265
    Reykjavik, Iceland
    Now the M5 has gone into winter storage - there is now space in the garage for some RNGTOY work
    With help from a good friend, the S85 went in this weekend.
    Only minor mechanical persuasion was needed
    Will probably get it 2-3 cm lower and 4-5 cm further back.
    But so far so good.
    Thordur
  16. #266
    UT
    98 M3/4/5
    that thing is F'ing massive in there!!
    98 Estoril ///M3 4/6
    S54 swap CSL
  17. #267
    Royalest of Oaks
    Mazda 3
    Oh lawdy... This is a thing of beauty
  18. #268
    Reykjavik, Iceland
    Some new parts for the build.
    Couldn´t resist some used Evolve intakes that were for sale recently.
    Also, some proper engine mounts from Vibra tech. Also a mono wiper kit from AKG + some reinforcements.
    Now waiting for the mounting bracket for the DCT, once that is get I can get the engine/box into final position.
    Thordur
  19. #269
    Reykjavik, Iceland
    Project superslow continues, DCT bracket finally here - Schmiedmann taking it very slow thru the holidays:
    Next is to bolt the DCT box to the engine and see how it all fits, headers too
    Thordur
  20. #270
    Reykjavik, Iceland
    Some heavy CAD design going on (Binky style) to make brackets, none of the OEM stuff can be used because of lack of space!
    Cardboard turning into metal:
    Thordur
  21. #271
    Compactive's Avatar
    Compactive is offline Helpful. BMW CCA Member
    Moderator
    DMV
    3x 318ti
    All these welds and clean af brushed metal gives me a big smile inside
    Want a custom signature? Post requests here, or PM me here | My Flickr
  22. #272
    Reykjavik, Iceland
    Quote Originally Posted by Compactive View Post
    Strangely satisfying
    Thordur
  23. #273
    Reykjavik, Iceland
    Decided to splurge on some Supersprint hardware:
    These are originally made for E46 M3, 2 x 2.5" - will incorporate into a custom exhaust. Old exhaust sold and will go into the car the S50 engine went into
    The preferred setup is:
    headers -> x pipe -> cutout valves -> mid box -> rear box
    But due to space restraints the cutout valves might have to go between the mid and rear boxes. I want to have both the possibility to have crazy loud V10 and then a track day compliant setup also
    But I have plenty time to figure that out, delivery is in week 11
    Thordur
