Just leave today and on the way home my engine temperature is very High so i pulled over
Check under the under and can seem to find the problem
is my thermostat broken or something else?
How should i check this problem out?
Thanks in advance
Kevin
It could be a stuck thermostat, low coolant, or any of several other problems. You can pull the thermostat and test it to see if it opens and at the right temperature.
Jim Levie, Huntsville, AL
How do I test the thermostat? Where is it located at?
Not a knock on you or anything, but from the sound of it, you shouldn't be the one testing it. Take it to someone that knows what to look for. Overheating problems can be tricky, and are not really the type of repair you want to try to DIY when it's your first time working on a car.
