I had to drop off the suspension goodies this morning at the shop so thought I would give you guys another video to snack on.
This just shows the exhaust dump which some were curious about since I decided against BLING tips. You also get to see some of the drivetrain mods, steel braided fuel lines, wastegate setup, etc. The radiator fan, BOV and some things are off the car...we are testing different things to make sure there are no boost, vac or oil leaks.
PUTFILE VIDEO
YOUTUBE COMING SOON!
nice... that looks like a 3" downpipe rite? i thought u guys were using 3.5". nice driveshaft
and what differential fin are u using? ruoge?
Custom Twin Charge build... tuned by VIC@SIASTUNING 11psi 400whp 400ftlb with a slipping clutch, high boost
GTK-650 (.7 comp and .68 or .81 turbines),Eaton M62 (clutched S/C), Custom 11" Crank Pulley ,Cometic 0.14" HG, Walbro255, TEC3r, Tial 50mm BOV, Tial 44mm Wastegate, SP Alcohol injection Stg1, UUC LTWFW stg2, spec performance organic clutch, Siemens 72lb injectors, 24x12x4 FMIC, 3" intercooler pipings, s54 oil filter housing,666 Topmount manifold, and oil cooler kit.
Looks great Cam! Parts with purposes, I love it. What size wastegate is that again?
Awesome man! You really have all your bases covered now!
While you're in there change that wastegate spring
HeHe I like parts with purposes. This car isn't just for looks.
60mm.
Thanks! Almost there. I have a few extra tricks up my sleeve still.
First I think I have a boost leak. If I do, that will be taken care of, then I will change the EBC to see if I can stretch that 14.7psi spring to 30psi. Then I will get Antilag and the line locks set up. Then I will see what my traction is like. Then I will try to acquire some 15" rims and see if I can fit some nice sized M/T DRs. Then a couple more tricks but somewhere in the mix I will try the 1/8th at least and get some freeway video with other FI bimmers.
Never had an external pump. Dual Walbros.
My 3.5" is just fine thanks.
Cameron, it looks really nice Now I understand why it sounds like it does, I thought it had a muffler (actually I thought it had dual exhausts). How wide is the resonator they fit under-car?
jesus, that car really has the best of the best parts in it, doesnt it....
-M3J0N
That wastegate looks large enough under there! 60MM, good lord, I couldn't imagine the sound if you didn't tie that back into the exhaust system! Very nice Cam, parts choosen are so high quality and researched well. Once set up, I'm really interested in the 1/4 mile times.
Cause I'm a hood figga!
Are you going to put a x brace on it aswell?
That is actually a muffler not a resonator. I will measure it for you.
Thank you. I never wanted this to be one of those cars where it's shiny in some places with some nice stuff but at closer inspection there are cheap bandaids and overall poor quality.
Thanks! Unfortunately I don't ahve a 1/4 mile strip anywhere near me but I will make the long journey to one some day for sure.
Yeah, in the other thread about Go, Show and Handling I have pictured the stuff being installed which includes an x-brace. Before I always just spent money on GO stuff and ignored the proper suspension and little goodies that I really needed. I am still surprised I took the plunge on the BBK because it is a lot of money for no GO power. However not dying is also a priority these days.
