Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Thread: Going to change oil for 1st time - recommended E32 oil type?
  1. #26
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Shell Rotella 15w40 here. In our cold climate the weather is warm in the summer but not Texas-hot.
    90,700 miles 1992 BMW 735iL Azure Blue Metallic with Silver Grey leather interior ‣My car ‣My YouTube channel
  2. #27
    Jul 2012
    South Yarmouth MA
    11/87 735i & 735il P/C
    I’ve been using Shell Rotella T6 (Full synthetic) 15w-40 with a bottle of the Lucas full synthetic oil stabilizer.
    3.5-4k intervals (I could probably push it another 1k miles, but at ~$35 an oil change I’d rather play it safe)
    I live in the northeast USA where temps can range from 0 to ~95 Fahrenheit
  3. #28
    Jul 2020
    usa
    1994 740i
    my son has a 535i we use castrol gtx 10w40 and a mann filter and i use liqui molyMoS2 additive 238k still runs like new My 94 740 I use 20w50 castrol oem filter same additive it gets cold in NY
  4. #29
    Nov 2007
    SF, bay area
    94 740, 74 wagoneer
    Quote Originally Posted by Cactuar View Post
    Same here, in Cal, the indy has used the 15W40 rotella, the oil change place down the street the castrol 20W50. 120K on the engine.
  5. #30
    Richmond, Virginia
    '88 735i, '06 RSX
    In reality all these 10W40-15W40-20W50 oils should be just fine for the M30 as long as a good interval is being enforced. I don’t think it’s a particularly picky engine, but id stay away from 5W30 or the European blend 0W40
  6. #31
    Jul 2020
    usa
    1994 740i
    truthfully i use the dino oil and change it frequently i dont know what the previous owner used and im wary of changing to synthetic on such an old car because i dont want to starts springing leaks but thats just me
  7. #32
    Jul 2012
    South Yarmouth MA
    IMHO you’d be fine switching to synthetic - but also in my humble opinion, one of the reasons I go with the rotella 15w-40 is because it’s “heavy duty Diesel engine oil” meaning it has more zinc and other additives that probably more-closely match what would’ve been found in the BMW spec oils of the late 80’s early 90’s.
  8. #33
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    old thread revival
    On page 79 of the 1992 E32 owners handbook oil specs of those days are listed http://www.e38.org/e32/E32_1992_Owne..._optimised.pdf of course, these are outdated. Castrol website mentions
    750IL E32 5.0 Litre V12 M70 1988-1995 Service Refill Capacity: 7.5* Litres (Includes Oil Filter) https://rego2oil.castrol.com/en_au/a...uto_1988_1995_
    CASTROL EDGE 10W-60
    CASTROL GTX ULTRACLEAN 15W-40
    CASTROL GTX 20W-50
    735iL E32 M30 1987-1992 Service Refill Capacity: 5.75* Litres (Includes Oil Filter) https://rego2oil.castrol.com/en_au/a...uto_1987_1992_
    CASTROL GTX HIGH MILEAGE 15W-50
    CASTROL GTX 20W-50
    740IL E32 4.0 Litre V8 M60 1992-1994, Service Refill Capacity: 7.5* Litres (Includes Oil Filter) https://rego2oil.castrol.com/en_au/a...uto_1992_1994_
    CASTROL EDGE 10W-60
    CASTROL GTX 20W-50
    I am still using Chevron 10W40 all year round which I got cheap from COSTCO.
    Which oils are you using nowadays and do you change by intervals shown in the check control or by mileage? Of course, it is also climate depending.
    Service Interval Light System explained http://www.bimmerboard.com/forums/posts/328963/
  9. #34
    Oct 2008
    Romania
    1994 BMW E32 730i M30
    Quote Originally Posted by shogun View Post
    In late 2020, I've stated my opinion in another thread; see the link below:
    https://www.bimmerforums.com/forum/s...9#post30567289
    As an update, I would like to add the following:
    1. An oil that has the potential to be a good option for the BMW M30 is the Motul Classic 2100 15W-50.I t is a semi-synthetic, API SH oil. As per the datasheet, it is formulated "with a combination of high-Zinc level (ZDDP content above 1800 ppm) and Molybdenum additives" and "an oxidation stable synthetic base that allows stay-in-grade viscosity, and consistent engine oil pressure and extra high-temperature oil film strength".
    Here's a link to Motul US product page:
    https://www.motul.com/us/en-US/products/2100-15w50
    2. The Web page below provides a link to "Mobil 1 Product Guide", a .pdf file listing the phosphorous levels for all Mobil 1 synthetic motor oils.
    It is an interesting read.
    https://www.mobil.com/en/lubricants/...r-classic-cars
    1994 E32 730i M30 manual
    ex- 2006 E86 Z4M Coupe
    ex- 1986 E28 535i
  10. #35
    Jan 2005
    Japan
    Thanks, I merged the 2 oil threads now
  11. #36
    Oct 2020
    Revolutionary City
    01 325cic, 90 750iL
    I'm using Liquimoly Molygen 5w-40.
    First Blackstone report shows higher than average metals, but it was first oil change after the top-end rebuild (didn't test the 250mi break-in oil).
    Should have a change coming up before winter, will report back.
    1990 750iL BronzitBeige Metallic
    2001 325cic OrientBlau
  12. #37
    Richmond, Virginia
    '88 735i, '06 RSX
    Still using Mobil 1 15W50 full synthetic for its performance across broad temperature. We get freezing cold winters and boiling hot summers, and this oil is among the few grades that does well in both. Plus you can get it from Walmart for about 22-25$ a gallon and cash in on a mobile rebate bringing the cost per gallon to about 16-18$ a gallon. No brainer in my book, my M30B35 has been happy with it for 4 years
  13. #38
    Aug 2009
    Houston,Texas
    83 533 92 325 97 m3
    I recently switched from Driven HR oil to the Driven GT its a Pennsylvania green synth blend. But this is for a built S52 swap has 90k on it now. I like the Joe Gibbs oil.
    Sorry meant to add that is in my E34 touring but I just got a E32 735 that is pretty clean from my boss at the shop and we put motul classic 20/50 in it and I may switch to the Driven GT. A lot of people from years back swore by the old kendall and brad penn oil.
    Also its GP not GT my bad.
  14. #39
    Aug 2009
    Houston,Texas
    83 533 92 325 97 m3
    Gp-1
  15. #40
    USA
    e34 540ia/e32 740il
    I've used Castrol syntec 0w-40 in all my BMWs, all year around in Pennsylvania and Florida. For as long as I can remember, and up until a few months ago, you could buy 5 quart jugs of this oil in-store at any local Walmart for ~$26, which is an excellent deal. However, it seems that Walmart does not carry it anymore and my at-home stock is pretty much out...
    I select the 2nd number of the oil weight (40 in my case) based on what viscosity you want for the engine at operating temp, and find the lowest 'W' winter weight for that oil grade. Even a 0 weight (first number) oil is still thicker viscosity when the engine is at 100F ambient temperature compared to when the engine is up to its ~200F operating temp with the -40 weight (second number) oil; even the best multi-grade oils decrease in absolute viscosity with increasing temperature. So unless you're in a climate where the outside air temp is like 130F, then get the lowest 'W' number available for the operating temp weight that you need. This will improve oil flow before the engine is up to its operating temp.
  16. #41
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    If you don't have service records or haven't pulled the valve covers you won't know the amount of sludge in the engine. I've started using LiquiMoly Engine Flush before the oil change. It's a low viscosity, high detergent additive. You only let the car idle for about 10 minutes but make sure the engine is hot before you add it. The old oil will be extra dirty from the modest scouring action. It cleared up my tapping lifters and I know I have a moderate amount of sludge. I will use it every time in ALL my cars from now on.
    Sent from my SM-G955U using Tapatalk
  1. Replies: 24
    Last Post: 02-23-2010, 07:47 PM
  2. Replies: 92
    Last Post: 01-27-2010, 07:25 PM
  3. Oil change... tips for next time...
    By 91mat325 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-17-2008, 09:27 AM
  4. BMWCCA Driving School recommended before Auto-Xing for 1st time?
    By Drex in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-16-2007, 03:08 PM
  5. 1st time oil change -any cautions ???
    By m /// magic in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2001, 07:17 PM
