Thought i'd post some pics of my stereo install so far. Here's the equipment list with Diagram (Yeah, i was really bored).
Alpine 9835
MB Quart QSD 210
Seas ER15RLY 5" Woofers for Kicks
JL Audio 300/4 (Channel 1 going to Q's, and Channel 2 going active to the Seas)
JL Audio 13w6v2
JL Audio e1800d
Monster 6 channel all in one Line Cable (This works really well so that you only have one cable to run vs. 3 preouts to the trunk).
*Optima Yellow Top
*Fat Mat
9835 Matches really well with the stock amber gauges (Sorry some are crappy cell phone pics)
First off, the challenge of getting 4" speakers into the door using the factory grilles and mounting hardware. The credit here goes to my dad, he fabbed up some wooden spacers that not only brought the speaker back for mounting, but used the factory "Grille Screw" mounting. He is the man!
Now comes the challenge of the battery. We had to rab up some mounts in order to mount the optima because it didn't fit the way the OEM battery did. The Battery has slots on each side, so it just slides over these and is mounted that way, then tied down. Sorry don't have pic of optima in the mount yet.
Preouts out from the back of the deck..
Sound deadened the inside and around the kick panel
Didn't want to deal with pulling wires through the door, so i tapped the stock speaker harness (HK stock system) for the mid doors and tweeters.
(Ignore the Solid Black, Yellow, and Red wires.)
Amp Setup (for now). Gonna have to figure out how i'm going to mount the amps up. Right now its just on a board laying flat. So i'm still thinking..any ideas? Ideally, i want something i can easily take in and out as one piece for autoX and track events. Any Ideas?
Still have to use the rest of the sound deadener on the trunk and doors, ans mount the amps up. Maybe finish those thanksgiving break . Let me know what you think, Me and my dad did this all in 2 days, and thanks to him we were able to get most of it done...
1998 e36 M3 - Money Pit
1991 e30 325iX - Daily/Snow Sled
head unit looks very clean
"I feel like someone just took a shit in my head. I have no idea whats going on." -APav
Not that i know of, but i did not take apart the passenger side to investigate what wires are run. With the space i had on the drivers side, i couldn't imagine there being any wires running close to where you would've run them..
yep, actually the battery cable from the trunk runs the length of the passenger side into the engine compartment to the distribution/jump block and on the the electronics.
i'm surprised you're not exhibiting a major amount of audible feedback in your setup.
op, good job. the only thing i really have to say is you could have saved some dough buy using some knuconceptz signal wire opposed to the monster cables.
as for your dilemma with removal for track use. the only thing would have been to use one amp for everything and mount it securely to the underside of the rear deck. this way you really only need to yank the sub for track use which is a lot easier than pulling out all of your hardware. although, if you can manage to fab an enclosure above your battery location you'd be golden.
Ah, that's right, I do remember seeing that now. You'd definitely run into some troubles there..
The monster cable was only 50$, I liked having it all in one as well. At 15$ a piece for the stinger wires i was gonna use, it seemed worth it. It did work great, i get NO amp noise, very quiet. The speaker wire was something i could only get at my local walmart at the time ha.op, good job. the only thing i really have to say is you could have saved some dough buy using some knuconceptz signal wire opposed to the monster cables.
I think i have something somewhat figured out. What i ended up doing was building a rack to stack the two amps. I should have some pictures posted soon of the progress. But then i could take out the whole rack as one...as for your dilemma with removal for track use. the only thing would have been to use one amp for everything and mount it securely to the underside of the rear deck. this way you really only need to yank the sub for track use which is a lot easier than pulling out all of your hardware. although, if you can manage to fab an enclosure above your battery location you'd be golden.
ok thanks.
