I purchased a 2001 z3 3.0...
When i get a new car i always change the diff fluid to redline or amsoil. I noticed that BMW says this diff has a lifetime fill. Does that mean i shouldnt chenge the diff fluid... I ve never heard of a life time fill ...
thanks again
change it... lifetime is B.S.
depending how you drive.
If you autocross, change sooner, your rear end will stay cooler longer and wear less.
If you daily drive, lean towards the 60k.
Either way, change it,...
Ciao! - - Nathan
2000-2.8L Z3 StahlGrau Roadster, #65 - SM2 and a 2007 335i (BONE STOCK!)
BMWCCA Tejas Chapter & iZ3 Project Coordinator for the San Antonio Area.
FEAR MY TWO SEATER!!!!!!!
Hello, I'm a MOD-A-HOLIC, check out my site to see my addictions! www.z3power.net
Member Since May 30, 2002
In a FWD auto it'll just use ATF right?
Originally posted by Beau
the turbo is the perfect garbage can....
Wanted to change my tranny fluid which is also lifetime (yea right) fluid. He told me that if the tranny or rear fluid is changed to anything but BMW fluid the warranty is voided. Just a heads up. But then again, if anything ever happens after you change the fluid, you can always change it back.
