When I start up my car the display tells me to check rear lights. I have checked the rear lights over and over again and they are fine. Brake lights, back up lights, and night time running lights are all fine. What gives.
Sometimes its better to make a good run than a bad stand.
There may be some corrosion on the bulb housing. Sometimes it can cause an error.
UNDER CONSTRUCTION
- 2000 528i Sport -
Got any questions about my car? Feel free to PM me!
well i dont know if i have a huge issue with corrosion because i get every warning on blubs in the book, no matter what i do and clean and replace they always come back random, anyone have a idea if these cars have a bad ground issue or something, sometimes i notice the foglight flicker, sometimes only one head light flickers, sometimes the right sometimes the left.... should i just check all ground points....
545i 6 speed
Did you check your third brake light? I just replaced my bulb holder today and that took care of it. Run $4.10 at the dealer.
APR Stage 1 Tuned, APR Stage 1 intake
do have led taillights?
'00 528IT
First, check the third brake light as Black528i suggested. Next try swapping the backup light bulbs with the brake lights, holders and all.
I had to replace both brake light bulb holders last Spring. I checked the original holders and found no problems, but when I but them back in, the warning came back. The plastic was slightly yellowed compared to the new bulb holders, but other than that there was no difference.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
BMWCCA Member #337964
Good luck and keep us posted.
UNDER CONSTRUCTION
- 2000 528i Sport -
The third brake light works also. I might just have to replace all of the rear lights. 152k, my car deserves a little TLC.
replace all the bulbs in your tails,...it's cheap to do.If the problem persists, then check the wirirng.
I had a BMW parts man tell me to be sure to use replacement bulbs with silver bases not brass or it would still throw a code even though the lights work. Don't know if this is your problem, just a thought.
the wattage has to be right
Changing out all the bulbs sounds like throwing out the baby with the bath water. I'm not much of a DIY guy, so I'd take it to a mechanic to diagnose it.
Mark
(newbie)
I had this problem and discovered that there are two red parking lights on each side in the rear. One was burnt! Doh!
2008 Lexus LS460
2016 Lexus NX200t
PUREVIP
Island Elites - West Coast Elites
Team Airrex
ClubLexusHawaii
2002 540iA Sport (SOLD)
1998 M3/4 (SOLD)
Check the liscense plate lights as well--those are easily overlooked
