Please, does anyone have any tips for cleaning the heated windscreen washer jets, the ones on the 2.8 that I have just bought are completely blocked up presumably with mineral deposits caused by the heating of the water ?
1) fine wire; or 2) remove from car & soak in Limeaway or the equivalent.
Many thanks I will go hunt through the good lady's cleaning cupboards !
Compressed air__used cautiously__ will do a nice job too.
I suppose it depends on what the blockage is, but I've had it work on a few people's cars.
I pull the hose off the pump (at the reservoir) and shoot from there.
I just gave up and bought new ones. They are reasonably priced, and I switched to micro screw-type hose clamps at the same time.
Sometimes a small needle will work if the blockage is in the jets.
Jewelers drill bits and/or cutting torch tip-cleaner..
1997,,1.9L,,18" TSWs,,Alpine/Infinity/Polk sound,,Fogged airbox,,Magnaflow 14815,,Slotsanvents rotors,,Dark sunglasses,,Big smile
