Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 184
Thread: High RPM Miss/Sputter
  1. #101
    Oct 2003
    NYC
    Something Cool
    My '98 did this when i had it in 2003 and I could never figure it out...and i hated it...seemed to do it around the change of seasons though...fall-into winter and then spring-into summer.
  2. #102
    Jun 2004
    PA
    Too many to list...
    I scanned my codes this past weekend and nothing showed up. I also took the car out on a high way run tonight and sure enough at about 6200-6500 rpms in 3rd gear the sputter is still there.
    Next will be swapping coils with my brother's 330ci to see if that cures the issue.
    Doug
    '97 M3/4
  3. #103
    Mar 2001
    Mandeville, LA
    Z4 M coupe
    Go and pull the vehicle speed sensor in the diff (2 10mm bolts, accessible under the car without a jack.... just crawl) and see if it has any metal stuck to it.
    1/4 mile in 13.1 @ 106++ (calculators put this at 0-60 in "4.21" seconds.)
  4. #104
    CT
    Nike's
    Quote Originally Posted by xjeeper View Post
    why would that happen??
    And would that make the car sputter? weird
    I can't believe you haven't figured out this issue yet. Hope you do!
  5. #105
    Jun 2004
    PA
    Too many to list...
    Just curious what would make you think the VSS would have to do with the symptoms I'm experiencing?
    Doug
    '97 M3/4
  6. #106
    DC
    '97 M3/4/5
    Quote Originally Posted by douglee25 View Post
    That's really weird?? What did that chip run you?
    Doug
    Okay a few weeks later, and it is doing it again!
  7. #107
    Jun 2004
    PA
    Too many to list...
    I had a feeling it would. I really really think it's ignition related. Did you replace the coils yet?
    Doug
    '97 M3/4
  8. #108
    DC
    '97 M3/4/5
    Doug
    Coils were new as of over a year ago -- just ordered a cam position sensor from cmuzzy. Our cam position sensor is weird - from what I hear, it's kind of a combination VR/Hall sensor - it does not give a full on sine wave like a VR, but is not simply "on/off" like the hall. Hence why we can't buy a generic $15 hall to replace it!!
  9. #109
    Jun 2004
    PA
    Too many to list...
    Quote Originally Posted by epj3 View Post
    I did replace my cam sensor about 3 years ago. I actually had it fail when I was on vacation. It totally retarded the timing for my long trek home.
    Doug
    '97 M3/4
  10. #110
    DC
    '97 M3/4/5
    Doug
    Lucky it even ran, when I forgot to plug mine in after doing my m50 manifold swap it started knocking right away
  11. #111
    Dec 2005
    Chicago
    E36 M3
    Did swapping the coils help?
    I'm thinking about sending my injectors in to get cleaned and to replace the little parts
    99 Alpine/Gutted ///M3
    98
    Estoril/M-Technic cloth ///M3
    - RIP http://forums.bimmerforums.com/forum....php?t=1191513
  12. #112
    Jun 2004
    PA
    Too many to list...
    I still didn't get a chance to swap them. I've been up to my ears with other projects. I will definitely report back hopefully soon.
    Doug
    '97 M3/4
  13. #113
    Bay Area, CA
    Jeep ZJ, 95M3
    not sure if this help.. but my 95 used to do the same thing at about 5500-6500 in 3rd. I tried the basics: fuel filter/ plugs.. but nothing helped
    then the car threw the o2 code. After i replaced the o2 sensor(95s only have one).. it hasn't happened again. (knock on wood)
    just an idea.
    Mods: Eibach Sways, xbrace, JC chip, jtd underpanel, ssk
  14. #114
    Dec 2004
    Portland, OR
    2003 M3
    Bump,
    I now have the same problem, did any of you guys figure out what's causing that?
  15. #115
    Jun 2004
    PA
    Too many to list...
    I haven't had it happen in a long time.
    I have been getting an O2 code every now and again. I have all 4 sensors ready to replace, but I just haven't had the time.
    Doug
    '97 M3/4
  16. #116
    Dec 2004
    Portland, OR
    2003 M3
    Doug
    So it just stopped doing it although you've not changed a thing in the car?
  17. #117
    Jun 2004
    PA
    Too many to list...
    I haven't changed anything and the issue hasn't occured recently. I can't remember the last time it happened actually. Granted I don't run my car up to those speeds every time I drive, but again I haven't had issues. Of course now that I write this, the problem will return tomorrow morning.
    Doug
    '97 M3/4
  18. #118
    Dec 2004
    Portland, OR
    2003 M3
    Well, good news, it looks like in my case at least it was bad gas, after having those sputters for couple weeks, I finally had to get some gas, went to a different gas station and haven't had the problem for couple of days now, hopes it stays like this
  19. #119
    Jun 2004
    PA
    Too many to list...
    Keep us posted.
    Doug
    '97 M3/4
  20. #120
    Fort Collins, CO
    97 M3/4/5
    I have occasionally noted this problem in my car - I've replaced pretty much all the parts on your list except the coils. Given that it improves quite a bit/disappears with new plugs in my car, I'm fairly certain that the coils are to blame.
    Crank/Cam sensor would be my other two on the list of 'likely.'
    Chris
    97 M3
    94 325is
    12 Jeep SRT8
  21. #121
    Oct 2008
    Boston
    AW E36 M3, AW E46 M3
    how much are new coil boots?
    mine coincidentally started after i seafoamed the car, which goes along the lines of people say o2 sensors
    03' AW E46 M3 -> 15" AP BBK, 19x11 iForged Aeros, V-CSL GTS3, custom tuned by me
    98' AW E36 M3 -> 18x8.5 Hamann HM2, Taiwan Coilovers, custom tuned by me
    04' RC51 SP2 -> Full Yoshimura RS-3, HotBodies undertail, Lowering link, needs a TUNE
  22. #122
    Nov 2003
    Rockville, MD
    1998 M3
    ive had this problem for a while now. its just 2nd nature to me now. lol
  23. #123
    Jun 2004
    PA
    Too many to list...
    Quote Originally Posted by BrenM3 View Post
    I think new boots can be purchased from NAPA for about $55 for a set of six.
    Doug
    '97 M3/4
  24. #124
    Maryland
    E36 M3
    I'm coming into this thread late and didn't read all the posts. However, you said your plugs were $1.98 Each? I don't recall exactly what kind I bought, but they were the OEM plugs with 4 electrodes, 8 dollars or so each. I had high RPM mis-fires and the new plugs solved it. Perhaps it's the type of plug you are using?
    Shaun
    Driving a modified M3 is like dating a supermodel with a bad cocaine habit. It's going to be expensive and ultimately get you in a lot of trouble, but she sure does know how to have fun.
  25. #125
    Nov 2003
    Rockville, MD
    1998 M3
    Quote Originally Posted by delusion39 View Post
    Shaun
    he probably got the ngk coopers.. i have them also and they are fine.
