Page 4 of 8 FirstFirst 12345678 LastLast
Results 76 to 100 of 184
Thread: High RPM Miss/Sputter
  1. #76
    Jun 2004
    PA
    Too many to list...
    Well I tried taking it up to 70mph or so in 3rd gear this morning and the did not stutter. Weird huh? With my luck, I fully expect the problem to surface again come summer time.
    Doug
    '97 M3/4
  2. #77
    Atlanta GA
    97 S54,94 M-Technic,SE36
    try coils if it comes up again
  3. #78
    CT
    Nike's
    Put my new plugs in NGK iridiums the one with IX at the end. NO MORE MISFIRING car runs great now. I don't get that misfire anymore at 5600ish rpm in 3rd anymore. Man I wish I changed the plugs sooner.
  4. #79
    Atlanta, GA
    1998 Cosmos M3
    This may be a long shot, but I read through the entire thread before I posted so as not to be redundant. In the OP's first post he said he used anti-seize compound on the plugs. According to Pelican Part's Wayne, that is a no, no because of a possible arc from the plug to head facilitated by the anti-seize compound.
    http://books.google.com/books?id=wJv...IPhPJDaMJiqBM8
    God knows you've covered just about everything else that it could possibly be in the thread already.
    Good luck.
  5. #80
    Framingham, MA
    98 M3,94 325is,07 Avalan
    Quote Originally Posted by brando1118 View Post
    Good luck.
    Its not because of a possible arc from the plug, its because the plug needs to be grounded to the head, and the antisieze could prevent this grounding. Its right there in that link you put up.
    Jon
    98 M3 Track/Autocross/Street- AST 4100s.
    94 325is beater
  6. #81
    Jun 2004
    PA
    Too many to list...
    Good luck.
    Quote Originally Posted by fatboycowen View Post
    Interesting. I would be perplexed as to how other vehicles I've owned specifically state to use antiseize on the plug threads. If it was indeed a grounding issue, how could other manufacturers get away with it?
    Doug
    '97 M3/4
  7. #82
    Atlanta, GA
    1998 Cosmos M3
    Thanks for that. Sorry to mislead. It was a lot of reading until I finally posted. I got lazy and assumed. Very dangerous.
    Manufacturers can get a way with it because it's never a consistent problem with any particular make or model. It just happens "sometimes". But when you've got a thread like this where EVERYTHING seems to be addressed, it might be time to think outside the box for longshots. The anti-seize compound seems warranted enough, but it's still sketchy. But at this point what have you got to lose?
  8. #83
    Framingham, MA
    Quote Originally Posted by douglee25 View Post
    Doug
    If you think about it, when you torque the plugs in, there has to be metal to metal contact between the threads in some areas, so it should still ground. Maybe this is only a concern for high performance cars....
    Jon
    94 325is beater
  9. #84
    Jun 2004
    PA
    Too many to list...
    Very true. I will keep it in the back of head next time I notice the problem.
    Doug
    '97 M3/4
  10. #85
    Jun 2006
    Prior Lake, MN
    68 GMC, 02 M3
    So, it seems like a couple people have fixed the problem for now by replacing the cam sensor. How much is the cam sensor and is it easy to replace? Other items that everyone seems to be doing is cleaning the MAF and replacing the fuel filter. My guess would be a weak coil if such a thing can happen. I get the same miss....(definatly feels ignition related) at high rpm and maybe only 2 to 3 actual missfires while running the car through 3rd and 4th floored.
  11. #86
    DFW
    98 Estoril M3/2, 94 325i
    ^+1 and I'm having the same problem
    VP Anyone have a Girlfax?
  12. #87
    DFW
    Ok, so from my understanding, the choices we have to check the engine is...
    -M50 mani leaks/tightness
    -Cam Sensor (which I think might be my problem)
    -O2 Sensor (another I might have)
    Do you guys think that when I get my cams installed that it will get worse or go away, keep in mind I will be having Dr. Vanos install the cams with his "Sunbelt Vanos".
  13. #88
    Jun 2004
    PA
    Too many to list...
    Well had the car on the interstate today... the misfire is still there. I haven't seen the CEL but I may scan for codes when I'm back from business travel.
    Lovely...
    Doug
    '97 M3/4
  14. #89
    CT
    Nike's
    you still have original coils?
  15. #90
    Oct 2005
    MVW
    95 ///M 02 F4i
    Quote Originally Posted by epj3 View Post
    Nah, no way a pre-cat O2 sensor could do it. That WOULD definitely throw a code if it were getting bad enough of a reading to effect performance.
    Odd thing is my car hasn't ALWAYS done it, just started about 10 months ago
    damn that sucks man, I remember you posting up with probs when I was having misfire probs.
    fwiw, the cam sensor in my buddies 97 M went out.. it would fail hot and the car wouldn't start, ran normally all rpm, just wouldn't restart untill it cooled down. It also set a fault code.
    Bring MoneyWith you.
  16. #91
    Jun 2004
    PA
    Too many to list...
    Quote Originally Posted by Julz69 View Post
    Still the original coils but I did swap in brand new coil boots back in the summer along with new plugs. The cam sensor is also about 3-4 years old. The car has 106k on it. From what I've read, possible solutions are:
    1. Coils
    2. Coil Boots - Done
    3. MAF Dirty
    4. O2 Sensors
    5. Cam Sensor - Done (4 years ago though)
    6. Crank Sensor
    7. Fuel Pump
    8. Fuel Filter - Done
    9. Plugs - Done
    I'm not sure what to do next. My brother has a 330ci and I'm trying to find out the build date. Pre 9/2002 they have the same coils as the M3. I would like to try his out before I go throwing parts at the problem.
    Doug
    '97 M3/4
  17. #92
    E36
    Subscribed
  18. #93
    Virginia Beach, VA
    Blk 95 M3, Wt 95 Slush M3 (RIP)
    In this order.
    Fuel Filter (most DIYers forget about it)
    Seafoam that biach (use brakebooster line with 3/4 a bottle, and 1/4 in your gas, and go beat the hell out of her)
    Clean MAF
    Plugs (stay away from Platinum 4 plugs, go with single electrode copper ones)
    O2 Sensors
    "Aerodynamics is for those who cannot manufacture good engines"
    - Enzo Ferrari
  19. #94
    DC
    '97 M3/4/5
    Haha I hear ya, my car is nice and smooth all the other times, its just the one or two momentary "dips" in power up top before redline.
    Oh well, one more reason to go with a standalone and turbo
    Here's something interesting... still had this problem until Monday this week when I installed conforti software... Now it's completely gone and have not been able to reproduce the issue. Pulls smoothly to 7000 rpm.
  20. #95
    Jun 2004
    PA
    Too many to list...
    That's really weird?? What did that chip run you?
    Doug
    '97 M3/4
  21. #96
    Oct 2003
    Kirkland, Washington
    Cosmos 740iL Sport
    I have the same problem as seen in my dynos...
    I've been a lazy ass and haven't even attempted to fix it.
    Do my bidding for me BFC!
    For what it's worth, it did it on my stock tuning and dinan tuning.
    Definitely more of an ignition problem.
    I'm running the 2 pronged bosh iridium spark plugs as well.
  22. #97
    Jul 2006
    Gainesville Fl
    2JZ FD3S, 2JZ M3, 95 M3
    8k!!! damn!!
    -Andrew Mensah
  23. #98
    Oct 2003
    Cosmos 740iL Sport
    Quote Originally Posted by TheM3nsah View Post
    8k!!! damn!!
    LOL!
    No, 6500 RPMS. the time scale is just that, the time it took me from low RPM's to redline.
    Notice the difference with the flywheel. (the pink run is my run without the flywheel.
  24. #99
    Jun 2004
    PA
    Too many to list...
    Quote Originally Posted by mitchelrl View Post
    That's exactly where my engine is breaking up as well. Exact same spot! Weird. Sure seems ignition related to me. I found out this morning that my brother's 330ci has a build date of 2/2002, and therefore the coils will work in my car. I think we're going to attempt to swap these in and see if the problem is still present.
    Doug
    '97 M3/4
  25. #100
    DC
    '97 M3/4/5
    Doug
    It's just a shark injector...
