Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 81
Thread: Replacing ac compressor clutch BEARING
  1. #51
    Dec 2009
    San Diego, CA
    1997 BMW M3 Coupe
    I just tried to do this today, I got the 10mm bolt off just fine, but the compressor hub/cap would not budge... how did you guys take it off so easily! I threw in the towel after about 45 minutes of swearing and jamming screwdrivers between the pulley and hub/cap.
  2. #52
    Durham, NC
    2x 97 M3/4, 05 530i
    It'll eventually come off. You can't just pry in one spot- you have to try and get it from opposite sides at the same time, otherwise it'll just bind on the shaft from all the side load you put on it. If you pull on it evenly, it just slides right off. It's just tricky to get it right.
  3. #53
    Jun 2005
    Atlanta/Canada
    '00 M5 '02 325xit
    Did you get the snapring off first?
  4. #54
    Oct 2002
    Chicagoland
    '00 528iA, '01 325iA
    Quote Originally Posted by jfboy View Post
    That would definitely help...
  5. #55
    Durham, NC
    2x 97 M3/4, 05 530i
    Well, the snapring is what holds on the pulley. You have to pull the front disc off before you can get to the snapring, which is what whatthedealee is talking about, I assume....
  6. #56
    Dec 2009
    San Diego, CA
    1997 BMW M3 Coupe
    Yah I can't even get the front disc off...
    Quote Originally Posted by kevinwilly View Post
  7. #57
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    BMW uses Japanese compressors. You should be able to buy a complete new clutch assembly.
    Also, when you put the old one back together, make sure the unengaged clutch spacing is correct. If it's too much, you'll get symptoms of no AC after the system warms up. When it cools down a little the clutch will engage. When really hot it won't.
    Sorry, I used to know if for a Saab (also Japanese compressor), but I don't know it for a BMW.
  8. #58
    Dec 2009
    San Diego, CA
    1997 BMW M3 Coupe
    I got the front disc off, found out you can use a larger size bolt and screw it into the same hole, the front disc will pull itself off.
    Once I got that off, the snapring snapped in half... then the pulley won't come off the shaft, seems like it is binding at the end... so now i'm probably just gonna replace the whole compressor at this point.
    Quote Originally Posted by whatthedealee View Post
  9. #59
    Durham, NC
    2x 97 M3/4, 05 530i
    The snaprings are pretty fragile. I thought I had a bad compressor, but then noticed there was play in the pulley, which was making the whole thing bind and making the belt squeal.
    I decided to look at the bearing and found out the snapring was just broken. I had a spare so I replaced it and I've been working perfect since.
    The pulley/bearing should come off pretty easily. Sometimes there's a little bit of rust on the end of the shaft which makes it hard to get started... but with a decent prybar (again, working from both sides at once) it should come right off if you've got the whole snapring off.
    Compressors are expensive. And R134a will be at least 35-40 bucks. I'd just get a new bearing and snapring if you can- but then again I don't know what your original symptoms were.....
  10. #60
    Dec 2002
    Offshore GOM
    E36 M3's
    Does anyone have a part number for the snap-ring?
    Dakar 95 M3 (4/95 manufacture)
    Techno Violet 97 M3 (12/96 manufacture)
    Alpine White 16 535i M-Sport (10/15 manufacture)
    _________________________________
    "I have no idols. I admire work, dedication and competence." -- A. Senna
    Illegitimus Non Tatum Carborundum
  11. #61
    Oct 2003
    Seattle
    99 M3
    I don't believe the snap ring will have a BMW p/n, and won't be in realoem, Generally, these are standard parts and a good auto parts store or hardware store should have them. Outside chance you will have to go to a fastener store.
  12. #62
    Dec 2005
    Boston, MA
    '91 318is
    bumping this up...only thread i could find with this information
    so does anyone have a good source for the replacement bearing
  13. #63
    Oct 2003
    Seattle
    99 M3
    I took the Nachi bearing p/n to Kaman. They appear to have offices in all 50 States.
  14. #64
    Dec 2005
    Boston, MA
    '91 318is
    Quote Originally Posted by bluptgm3 View Post
    actually found it at autozone, sanden part $18
    http://www.autozone.com/cooling-heat...7355_440953_0/
  15. #65
    ATL
    97 E36
    Since this has been an on-going thread over the years I figured I'd throw my story/dilemma into the mix.
    '97 E36 bearing has obviously failed. Instead of messing with removing/pressing out old bearing and reusing all other existing components I find a "clutch kit" (pulley [w/bearing], clutch plate, electro-magnet, and new hardware) on Rock Auto.
    Ordered, and delivered as promised. Removed old, installed new ( there was a thousand cuss words that went with that snap ring). Worked great! No more noise. 5wks later, the noise is back- pull the clutch plate, the seal is gone from the bearing. Obviously overheated, grease gone, no wonder the noise is back.
    Put in warranty claim with Rock Auto, "kit" is covered. Order new "kit", and send failed part back. Installed replacement, 4months later- bearing has failed again! WTF! Now I'm thinking cheap bearing? Bad grease? Wrong belt? Tensioner wrong? What the Hell? So, one more time? Or does anyone have a different take on this?
  16. #66
    Feb 2002
    CA
    no e30
    OE parts or bust
  17. #67
    Apr 2009
    norcal
    a few e30s
    Quote Originally Posted by KledgeBldr View Post
    Since this has been an on-going thread over the years I figured I'd throw my story/dilemma into the mix. '97 E36 bearing has obviously failed. Instead of messing with removing/pressing out old bearing and reusing all other existing components I find a "clutch kit" (pulley [w/bearing], clutch plate, electro-magnet, and new hardware) on Rock Auto. Ordered, and delivered as promised. Removed old, installed new ( there was a thousand cuss words that went with that snap ring). Worked great! No more noise. 5wks later, the noise is back- pull the clutch plate, the seal is gone from the bearing. Obviously overheated, grease gone, no wonder the noise is back. Put in warranty claim with Rock Auto, "kit" is covered. Order new "kit", and send failed part back. Installed replacement, 4months later- bearing has failed again! WTF! Now I'm thinking cheap bearing? Bad grease? Wrong belt? Tensioner wrong? What the Hell? So, one more time? Or does anyone have a different take on this?
    Cheap parts. You need a better bearing, use the dimensions to find a better one.
  18. #68
    Feb 2010
    Memphis Tn
    2006 330ic, 2 e36 before
    Quiet at last
    I am adding to this Thread, it was most helpful in changing my pulley bearing. I did not remove the radiator. AC COMPRESSOR.jpgThe snap ring was angled where my pliers wouldn't fit. So, I ended up lowering the compressor and getting the snap ring from the front view (without a mirror) It really does take patience.
    I ordered a larger pair of pliers and also ended up removing the spring to get them to spread wider also. The on your head flashlight also helped.
    The old bearing didn't seem to have play but it was the howler/squeeler. Its all quiet now.
    1998 328ic
  19. #69
    Feb 2010
    Memphis Tn
    Notes about the snap ring. One hole is smaller and your plier tip may not fit. I drilled it out after removal. My small pliers open farther with the 45 or straight tips than the 90 degree. I used the larger pliers to reinstall the snapring.
    1998 328ic
  20. #70
    Jan 2017
    Chicago
    2003 E39 540i
    Great thread I will be attempting this very soon.
    Sent from my SM-G935V using Tapatalk
  21. #71
    Dec 2016
    DFW
    1998 BMW E36
    After replacing the bearing in the pulley, how hard is it to reinstall back onto compressor? I got the pulley/clutch kit off rockauto and seems like it will be an interference fit and will require a hammer to install the pulley with the new bearing installed back on to compressor.
    Sent from my Nexus 6P using Tapatalk
  22. #72
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I recently had a leaking compressor and wanted to swap the clutch from it onto a spare compressor I had, but lacked the special tools needed to remove the clutch. I decided instead to just use the clutch already on the spare compressor. You can get a rebuilt compressor with clutch for $150 or a used compressor for half that. You might also be able to rent for free AC clutch tools from Autozone -- but I don't know what they have for AC tools.
  23. #73
    Oct 2002
    Chicagoland
    Quote Originally Posted by namiam View Post
    I remember it being a press fit; tap it in with an appropriate socket.
  24. #74
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by al_r View Post
    …tapping on inner bearing race only…
  25. #75
    Oct 2002
    Chicagoland
    Tapping it in using the inner race could stress and dent the ball and / or races, use the outer race...
