Now where's the fun in that?...last time I checked it was 2pts for a cone, 1 point per second early or late, and no points for markers or "support crew". The whole fun of motorsport photography is dodging the guy with the camera(s).
-M
The rest of the fleet: '06 WRX, '01 Forester EJ205
'90 325iX 4dr, '89 325iX, '91 318i, '89 525i, '71 2002, '99 528iT
Amish Mob - Monitoring those who misinform, and those concerned with Misinformation since 1997
that is easily the sweetest and only touring 7 passanger I've ever. X5s can't even accommodate seven.
you probably want to take the backwindow off, if the window shocks give out a little it will shatter the glass on the rifle barrel. also if you are going to be having a rear facing shooter, I would suggest a pintel mount for the gun. nothing sucks more than a fully automatic weapon spraying the inside of a BMW during a drift at speed.
I meant camera...
For guns I just open the sunroof...
those were some pretty scary and sad videos. i dont know if you guys watched them. im pretty glad i did because i was actually thinking about buying a booster seat for my 4 year old. i think i will skip it. i think i will be calling about the tether pieces tomorrow too. does anyone know, do these work like the latch system? where do you anchor the top of the carseat?
I like to touch people's hearts, it's what i do best!
great info, and very easy to understand. but is the above quote a typo? my understanding (and also on this website http://www.car-safety.org/latch.html) is that the anchor is for front-facing seats only. it attaches to the top rear of the seat to tie the childseat to the car's seat in 3 locations instead of only 2.
can you please confirm what you meant?
thanks, ian.
No current BMWs.
1994 Roadmaster Wagon
1974 Alfa Romeo Berlina
if you look at Q's post you'll see the anchor mounts. they are just behind the rear seat, at the front end of the toolkit cavity.
if you go into the dealership and ask for a child seat anchor kit, they'll sell you the bolt and hardware needed. mine had it in stock. i believe you then anchor the child seat over the top of the seatback, and down to the floor, much like a racing harness.
No current BMWs.
Sorry the message was unclear Ian. Reading it again I see how it can be interpreted both ways. What I meant to emphasize what if a parent puts their child in a forward position, they MUST SECURE the tether strap correctly for the safety design to work properly. Some parents may put their child in a forward facing position without properly securing the tether strap because they don't want to drill holes or "ruin the upholstery".
So bottom line, when you deploy a forward facing car seat, you MUST also secure the tether strap. As a general remark, the tether strap should be pulled as tight as humanly possible. The tether strap is meant to prevent the forward tipover motion in the event of a vehicular impact as shown in the videos.
1990 BMW Alpina B10 Bi-Turbo (37/507)
We have 2 boys and 4 bmws. the car seats all fit in any of the cars. Both forward and rear facing. We drive a 1994 525it, 1995 540i/6sp, 2001 525it, and 2001 325ci convertible. You need to look a bit for seats as bmws have a narrow seat width and some bases are so wide on the car seat that they cover the seat belt plug. That said a bit of trial and error and you will be fine. As discussed before use a retention clip to keep the car seat tight.
I have a touring and I'm looking to install those tether setups behind the rear seat. I've found all the parts on RealOEM, except for the white threaded inserts that the tether bolts go into. Has anyone purchased these? If so, part number? My car does not have them pre-installed.
Sorry to revive this old thread, but it seems to make sense here.
I wish i knew.
This is a good thread, can't believe I missed it.
I had a hard time getting my sons car seat to mount correctly, for some reason the center lap belt doesn't fit right. The buckle length of belt is too long.
If I have to take him anywhere we just take the e39, wich it fits in perfectly.
When the e34 was designed I don't think they thought about carseat safety like they do now.
e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
Does anyone know something about the Touring child seat tether mounts behind the rear seat? I want to put these in my car but I cannot find any information on them.
- how are those white inserts mounted in the holes?
- where can I get those white inserts?
Reviving this old thread. I want to install forward facing car seat on passenger side. Can't use center location because I'm pretty tall and there will be no space behind me.
I got it as far as holding car seat to the bottom with belt. Belt clip required. Thats OK
Now, for tether strap..
1. Where "behind" rear seat this hook should be found? Does it mean I need to remove rear seat back to see it? Does it mean I have to unbolt rear seat back to find and mount to it? Doesn't sound right..
2. I installed E32 headrests, The way those built - there will be no way to get strap other than over it. Looks like I will need to remove it completely when car seat installed?
There is no rear seat hook. The car was built before that was a thing. You can add them but I never used the rear hook in the two car seats I had in my 535i.
Andy
Shown in the below pic, there are 3 rear shelf anchors that are (I believe and you need to confirm) for anchoring baby seats. I used them to bolt down the rear shelf so it doesn't vibrate because of the sub. You can see them from inside the trunk, just look up. I think they take an M8 bolt.
You will need something like this to install. This one is for a Benz but BMW should have one also.
demet
Got them in both my (euro spec Aus delivered) 1993 540i's, both sides, I used them for my son's seats in both. Hook is on top of parcel shelf just behind each headrest, bolt and nut is installed from inside the boot through a hole in the frame. Maybe that was a requirement of Australian regulations.
1993 BMW 540i
Yeah, they often come with the seat itself.
If you're lucky katit2 you should have the holes in the parcel tray shown in the pic above where the bolts are in. Also the parcel shelf should have a welded in nut the same pitch and dia as the child seat belt's anchor bolt pictured above.
I put mine on the passenger side as my seat is all the way back, so not enough room for my kid to get into the rear seat behind the driver/me, and also too unstable on the centre hump (on my exes commodore the seat is in the middle though as that's best if you could do it imo)
I sent a drill bit up on the passenger side up from the boot to find when it came out inside, then carefully cut a hole inside the size of the spacer through the parcel shelf.
I think when researching this last year that aussie ones where set up for this, and maybe euros, but possibly not every country? Anyway, deadset easy on an aussie delivered car, and the bolt that came with the seat fit the BMW welded nut fine as they they have been standardized here for a long time so e34s sent here are compatible
I did more researching yesterday and placed order. Carseat definitely does not have anything. Even belt lock not included, they list 800 number in manual for older cars if I need one.
Anyway.. I just did whole upholstery and rear shelf covered in alcantara No holes yet. But I will put one, got good idea on what I need. Rear headreast will have to be removed while carseat installed.
Parts were ~$20 from ECS. Hook, bolt, washer and cap.
# 14-17
http://www.realoem.com/bmw/enUS/show...diagId=72_0085
For some reason #18 grayed out and no PN. Wonder if I don't need any standoff in E34? Threaded hole located through the trunk. What I'm going to do is to use sharp pick to make a hole from below. Then will see if anything else needed. If I need standoff of some kind - I will be able to machine it myself (extra hobby time )
It looks like solid mounting not a problem in E34, which is good! I drive my son to daycare every day and E34 parked most of the time, need to give it more use
