whatever,
laster i heard the fogs crack not always because of chips on the road but more due to the heat generated within and then something like water hits and cracks it up. so after you get some new ones, you can try this. Take some alumunium mesh and cut it to fit over the fogs tightly such that the mesh touches the fog lens. it will also fit back into the fog housing perfectly. i know this because i have done so myself.
anyway the reason for this is that the alumunium mesh will protect your fog lens in 2 ways. Firstly simply as a metal barrier, secondly and more importantly it acts as heat sink s.t the heat generated by the fog lens is immediately dissipated into the atmosphere. Remember for this your mesh must touch or be in contact with the fog lens.
Reason for lens breakage is because the co-efficient of expansion of glass is lower than metals (glass is a bad conductor of heat), thus the inner part of the lens heat up and starts to expand while the conduction of the heat generated does not transfer fast to the outer part of the lens. As a result the expansion of glass on the inner and outer side is unequal and when it comes in contact with water or a drastic reduction in temperature it breaks.The mesh prevents this and allows even heat dissipation.
This low co-efficient of expansion of glass also explains why sometimes moonroofs or windows explode during severe winter.
<FONT COLOR=PURPLE FONT FACE="TIMES NEW ROMAN" FONT SIZE="3"><i><b><br>Sean Gohain `02///325ci</i></b></br></FONT><IMG SRC="http://members.roadfly.org/seangohain/night+shot+star+frame.JPG"><FONT COLOR=PURPLE FONT FACE="TIMES NEW ROMAN" FONT SIZE="2"><i><b><br>A thing of beauty is a joy forever, <br>as its beauty increases it shall never pass into nothingness </i></b></br></FONT>
