Results 1 to 24 of 24
Thread: Stock injector size for S50B32?
    Mar 2001
    FL
    E36, E46
    Cant find out what # rate they are. Thanks
    '99 Estoril Blue + Dove Grey ///M3 coupe
    '04 Jet Black + Cinnamon ///
    M3 coupe
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    Mar 2001
    FL
    E36, E46
    I read that, but no confirmation.
    Bruce says he has 24# but didnt indicate what color they are...
    I'm trying to find out what lb/hr rate the stock dark blue top injectors are. (ie 21.5#, 24#, 30#, etc)
    M3 coupe
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    There's only one injector for all S50 B32 motors: Bosch part # 0-280-150-792 (dark blue top).
    Bruce confirmed in a PM that the 12 injectors he had cleaned/blueprinted were flowing between 24.2 and 24.9 #/h @ 43.5 psi.
    From Stan Weiss' website:
    Jul 2001
    South Florida
    E46 330ci turbo, 05 ZHP,
    Jon, can you verify the part number on your injectors? (280-150-792)
    Nick Glantzis
    2005 330i ZHP auto with Technique Tuning turbo kit (currently For Sale)
    Mar 2001
    FL
    E36, E46
    Quote Originally Posted by NickG View Post
    I'll check tomorrow
    M3 coupe
    Jun 2001
    Reston, VA
    88 M5 FOR SALE, E92 335i
    Mine show 280 150 792.
    What do they flow at 72.5psi/5bar?
    Sqrt(new pressure/old pressure) * old flow rate = new flow rate
    Sqrt(5/3.5) * 23.3 = 27.4lb/hr or 288cc/min
    James Muskopf
    RRT Racing
    DC Metro's premier BMW service and racing facility
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    Quote Originally Posted by JamesM3M5 View Post
    Here's an online calculator: http://users.erols.com/srweiss/calcpchg.htm
    Mar 2001
    FL
    E36, E46
    Confirmed. They are 280-150-792 navy tops
    M3 coupe
    Jul 2001
    South Florida
    Quote Originally Posted by Vitolo View Post
    Well then cover over on Saturday and get one of my wideband sensors so we can see what's going on with your setup.
    Nick Glantzis
    Jun 2001
    Reston, VA
    Quote Originally Posted by BSH View Post
    You know what - I might just try swapping in Bosch 0 280 155 715 new Design III injectors. We've been having great success with them in US engines for a 24lb/hr application. Since the S50B32 injectors are very close, I'd imagine they'd work nicely. I'll check current and long term fuel adjustments in the DME to make sure.
    James Muskopf
    RRT Racing
    Victoria, BC
    1999 M3 Evolution
    Has anyone tried these new design injectors with a stock engine?
    Victoria, BC
    1999 M3 Evolution
    Is the anywhere in North America that might have flow tested EVO injectors for sale?
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    so then does the s50b32 use 5b pressure ? Wasn't the 23.3 rated @3b?
    Jun 2001
    Reston, VA
    Quote Originally Posted by digger View Post
    Yes and Yes. They flow approx 24.2-24.9 at 3bar test pressure per Bruce (here on the boards), but with the higher 5bar regulator found on all S50B32s you're getting over 27lb/hr.
    James Muskopf
    RRT Racing
    Jul 2004
    Sid Knee
    325is, 96 M3 Euro
    If its 24.2lb @3b then 24.2*sqrt(5/3) = 24.2*1.29 = 31.2lb @ 5b?
    24.2*sqrt(3.5/3) = 26.1lb @ 3.5b
    Jun 2001
    Reston, VA
    Ah yes, good point. I used 3.5 bar (50.8psi) instead of 3.0bar (43.5psi) in the original calculation.
    James Muskopf
    RRT Racing
    Nov 2017
    New PLymouth, New Zealand
    2001 BMW E46 M3
    Hi there, just wondering if you ended up trying these other injectors and how your got on?
    Hi there, im looking to replace my s50b32 injectors and not that keen paying $200 each for oem ones, interested to know if theres an alternative? Thanks
    May 2005
    Tx
    E46 M3, E28, E38s, E46
    Funny this thread came up, I am working on a S50B32 that has (3) original injectors and (3) that cross reference to a Ford pn#.
    According to realoem.com the injectors supersede to the same injector in a S62. I ordered a set of S62 injectors second hand and found they are not 100% the same dimensionally. Before I modify the fuel rail I to am looking at alternatives or just buying (3) to match the current ones.
    Current Garage... '00 R11S, '09 HP2S, '12 R12GSA, '00 Black 323iT (wife's), '02 Alpine 325iT (Eileen, Track Wagon)
    Instagram @ HillPerformanceBimmers
    Email to George@HillPerformance.com
    The Netherlands
    DE-spec E36 328i/M3 cab
    Wonder if you've gotten the right ones then as the PN is identical for both engines.
    IG:
    May 2005
    Tx
    Quote Originally Posted by MParallel View Post
    Well, this didn't work out like I had hoped. What I found out is the early S62s DID share the same injector as the S50B32 BUT they are a different design/form factor than the later S62s so a 2003 S62 injector is not interchangeable with a S50B32. From what I gather studying the ETKs are that the early production S62s (which were not available in the US) used the injector and then BMW changed it. When they did they also changed the fuel rail so the early S62 injectors do not straight swap over to a later S62 either.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    A number of folks on m3cutters suggested the BOSCH 0280155832. I'm running a set and they work well. The stock injectors are rather vintage.
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    May 2005
    Tx
    Quote Originally Posted by nick325xit 5spd View Post
    IIRC there was some concern that those injectors might cause the engine to run lean as noted in a couple of dyno graphs. This car had a custom tune already and we were chasing some drivability issues so the goal was to eliminate as many variables as possible.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by George Hill View Post
    Fair. But it's worth noting that they are readily available in a pinch.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
