Results 1 to 11 of 11
Thread: open my trunk
    Ontario
    Two, Two BMW's hahaha
    open my trunk
    Hi cant open my trunk from the out side.. the latches are rusted ,the lock is fine.. is there a way to disasemble the latch from inside the trunk?
    Los Gatos CA
    1987 325is, e34, Z3, e39
    What type of e30 do you have? What is the real problem? Have you lost the key? The key doesn't turn? The key turns and nothing happens? You are learning to break into cars?
    The latch on the hood can be unbolted with the trunk shut. Worst case you can break out the plastic from a taillight, reach in and unbolt it by feel. A taillight is much cheaper to replace than body work.
    san antonio, texas
    1986 bmw 325(dead) 1991 318is
    maybe but how do you get in there to do it if it doesnt open
    Ontario
    i have the key.. the key will turn it jsut wont turn all the way to unlock cuz the rods or what ever it is that the lock cylinder moves to physically open the trunk is rusted.. so it will break my key if i
    try and unlock the trunk.
    i cut a whole in behind my back seats
    its an 88 IS
    winter park colorado
    '87 325is, '94 Suburban
    Quote Originally Posted by billyfiction View Post
    that was probably a bad idea...
    Nov 2003
    Fergus, ON
    E30 Turbo, 04 325xi
    Quote Originally Posted by quikveedb2 View Post
    Naw, it'll be ok.
    That's what the inside looks like. The two bolts that are deeper hold the lock cylinder in place. Undo all 3 and the latch will come out too.
    Houston, Texas, United States
    1987 325i Vert
    Wait, try putting wd40 in the lock first. The locks get old and need to be lubricated. Happened to me too. Had to pay 70 bucks for some fat old locksmith to lecture me on how I needed to lubricate my locks.
    Ontario
    thanks a bunch ryan.
    when you look at that pic you see that metal rod that goes from the lock to i guess the latch to open the trunk.. once i undo those bolts will i still need to physically pull up on that rod to open the trunk?? or will everything just fall apart once i undo those bolts?
    Nov 2003
    Fergus, ON
    E30 Turbo, 04 325xi
    Actually, that metal rod extends below to the lock solenoid for the central locking.
    If you undo the two inner bolts, the lock cylinder will pull out. Then if you look inside the hole, there will be a vertical bar. This bar activates the latch. So if you push on it the trunk should hopefully open!
    Ontario
    sweet, thanks a bunch
    Ontario
    got my trunk open in two secs big thanks agian..
