I will do a oil pan gasket replacement to cure my oil leak. I checked the Bentley and it seems that I can do it myself.
Any advices before starting?
Should I use a gasket sealer? If yes, which one do you use? I think I still have a tube of Yamabond. Can I use it on a cork gasket?
Luc
'11 BMW X5 3.0i 87,000 Km
'90 BMW 525i 61,000 Km, Euro, AT, Bilstein, Miller MAF (Sold )
'91 BMW 535i 90,000 Km, Euro, AT, Bilstein (Sold )
'98 BMW 740iL 98,000 miles (Sold )
www.sollev.com
I am gonna stay tuned to this. I was informed at my last oil change that I am missing two oil pan bolts.
I am currently awaiting them to arrive from Germany.
IF MY CAPS OFFEND YOU, BLOCK ME.
AND IF YOU NOTICE THE FIRST LETTER OF EACH WORD CAP'ED...... IT'S DONE AUTOMATICALLY BY THE FORUM BECAUSE I TYPE IN ALL CAPS.BUT IT DOESN'T ALWAYS DO THIS, LIKE WHEN I QUOTE OTHER POSTS.AND IF YOU DON'T LIKE THAT, REFER TO FIRST SENTENCE IN MY SIG.
I started the oil pan replacement and I need some advice about lifting the engine. Do you do it from above or from below.
If from above, where is located the rear engine lifting point?
If from below, where do you put the jack? Under the A/C bracket?
Luc
www.sollev.com
Bump, cause I'm going to do this soon too...
The paper gasket is preferred over the cork if you are going to do this. I paid to $350 to have this done. I didn't have the tools and didn't want to risk lifting the engine myself.
$350 including parts and labour??????????
E3.4
lift from above with proper lift bar. you need to get it up high to clear the cross member. Replace motor mounts while you have it up.
If your not leading your following.
I use black RTV sealant for the gasket. As far as lifting the motor you should do motor mounts or with a crane there should be two O tabs on on the rear of the block on the block itself one on the head by where the end of the cam would be around. that area the front.
Jon N in VA
E34 525iT 1993 Sleeper Born on Sept. 14 1992
Island Green on Tan
Too many things done.... S52 Etc.
Building an E36 Spec3 to rent...PM me
RRT-Powered.
