I replaced the voltage regulator on my previous car, a 944. The assembly also included the brushes that contact the armature.
I don't know how you would determine if just the voltage regulator died. It seems a likely failure if you're getting no voltage, but it could be a bad or broken connection inside the alternator (liek a winding). Other than that, about the only other thing that could be wrong is bad bearings, and you'd know if that were the problem.
Most people just swap out the alternator because it's a sure fix. Personally, I prefer to repair these things. You have to be willing to gamble the $80-100 for a new voltage regulator.
If you decide to replace the voltage regulator, let us know how it turns out. Good Luck.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
BMWCCA Member #337964
