Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Thread: Rear M5 sway bar install
  1. #51
    Queen Mary's Land (MD)
    08 328i|01 530i|96 328s
    ME!!!!
    Im local too
    ~Phil
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557
  2. #52
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    it is for the rear because its so easy. the front is very difficult so its more popular to do only the rear.
  3. #53
    Sep 2009
    UCF/Oviedo, Florida
    (Prd. 5/96) 528i.
    Before taking on the job and effort installing the M5 sway bar. To those who have the non-sport or even sport models hows the ride difference? I would think since you're adding the thicker bar in the rear suspension the front would feel off? The balance would be off. Even the earliest E39's didn't have rear sway bars...
  4. #54
    Jun 2013
    FPO AP Yokosuka Japan
    1996 Euro E39 528i
    Reviving this thoughtful and cost conscious DIY for all us non-M5 drivers that have aftermarket /upgraded suspension..shock/struts...etc...
    I'm about to put on rear endlinks and finish off the Bilstein PSS+wishbone+guidelink trifecta.....and found a used M5 sway avail...hummm...if previous reports are half correct, this $100 ish mod should add some thrill to the driving experience...again, my 96 Euro 528 M52 isn't doing HPDEs or canyon carving..or going over 120kph here in Japan..
    but WTH... any other success/fail stories out there before I pull the trigger? Drive safely- Mark
  5. #55
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Great mod for cheap and yes the effort is worth it!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  6. #56
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Quote Originally Posted by EURO E39 View Post
    Get some polyeruthane bushings for it, it will make the bar more effective. The OE rubber bushing are too soft.
  7. #57
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Actually for those 528, 525, 530 applications I would recommend going with front and rear bars from EIBACH ANTI-ROLL-KIT as this would give a user flatter cornering and better lane change control. The Dinan bar is 250 from Tire Rack and the set up is $325
    Bars
    Bar diameter 27mmF & 18mmR. Front bar is adjustable
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
