I started this thread (http://forums.bimmerforums.com/forum...d.php?t=834705) because I noticed a strange smell when I drive. I had a new clutch and flywheel put in about 1k miles ago, so at first I thought it was that. I still smell it now and not only when launching, so I started to wonder
I just got in from work, about a 20 minute drive bc of side roads and traffic, and when I got home I decided to check my oil again, as it had been low last week bc I hadnt checked it in some time (i know, i know). The oil came right up to the low mark, so I do still need to put some more in, but it's not bad.
What I did notice is that I took off the oil fill cap, and there was some white smoke coming from in the engine and through that hole when the cap was removed. is this normal?
Put your hand over it and see if you get condensation. It will let you know if it's water / coolant or if it's oil. Funny smell leads me to believe it's coolant. When mixed with oil it's kinda funky smelling.
uh oh..... disapearing oil, white smoke, funky smell..... I dont want to be the one to tell you the likely possibility
could this be head gasket? is there any simple way to tell.. ie: w/o having to bring it to a shop
Looks like someone took care of that for you.
V
...To the OP, take a look at your oil. Pull the dipstick out and see if you notice any 'milkiness' to the oil, any white stuff, or anything that indicates there's water mixed with it.
-Nick
-Nick
btw.. the common symptoms i keep seeing for new HG is 'car runs like crap' and 'constant overheating' .. neither are occuring with my car
could the tranny have f'd something up? i had a new clutch and the 5th gear fix done.. but the 5th gear fix was done wrong (ugh!) so i gotta have the place redo it
the oil seemed like oil when i checked the dipstick
i dont recall seeing white stuff with it
Oh.. so i spoke w a mechanic buddy and he said its pretty normal for these cars to smoke a little after being driven when you open the oil cap .. bc no smoke comes up through the engine.. only a little when i actually open the cap..
im starting to think the smell is still the clutch breaking in..
can someone check this for me.. like warm up your car and then (turn it off first) and open the oil cap and see if a little smoke appears? .. i dont have the money for a head job .. so by that reasoning it cant be it!
Ok, so your car doesn't over heat right? Did you check if there is oil in the coolant? Does your coolant magically disapear? Is there white smoke coming from the exhaust? Those are the most common symptoms.
Oh, and the car wont necessarily run like crap if a head gasket is blown, it doesn't mean the WHOLE hg is toast, it could be like part of one cylinder or maybe two that has a leak, and it will slowly leak in the head causing your steam.
Infact if it was just a small leak, you could still drive the car, you would just have to constantly refill coolant, change oil much more regularly, and open the radiator cap every once in a while to let some of the steam out. But thats only worst case scenario, its highly un recommended to drive around with any sort of leak in the headgasket, you would be just begging for more problems down the road.
i noticed the exhaust smells really bad.. BUT after the clutch the car has been throwing pre-cat o2 sensor codes.. so im guessing those need to be changed .. could those effect the smell of the exhaust? im starting to think that might be some of the smell
Coolant hasnt been topped up in over 8 months .. had the whole cooling sys done about 11 months ago.. oil is due for a change soon anyway
ill check in the AM if i see oil in the coolant.. would it be obviously visible from the fill hole?
no it really just smells like a car thats running rich i guess .. sort of like a normal exhaust smell but amplified
Skoot what happened? i have exactly same symptoms
When engine warm, white smoke from oil filler cap
burned oil smell or burned something smell like burned oil
gas smell from exhaust
1 more from me
my oil smells like gas
How long after starting does the smell linger?
Same with white smoke from filler cap; after running a while or only during the first minute or so?
May be more than one problem.
Fuel in oil smell indicates rings worn as does burning oil.
Τake a compression ck. Directions on how to are plentiful.
Add a bit of oil to low cyl if numbers seem out of spec.
If second ck shows increased compression, you need ring work.
I'm dropping my car off for George at ICS to check out tomorrow. Ive been wanting to do this for a while, and now with these weird quirks ive noticed I figure theres no better time. Hopefully by the end of the day tomorrow I'll know if any problems exist and whats causing em
after running 40 -60 minutes. So the engine must be totally warm for smoke.
I changed my spark plugs yesterday and i have old ones. Does worn rings make any sign on spark plugs?
Worn rings will leave traces of oil on the plugs. What color are the plugs? They should be a goldish brown if all is well.. any darker, and you are probably oil fouling them a little.
The white smoke from the filler cap is a result of the oil overheating. What oil are you using? Try something different at your next change, see if it goes away. An oil cooler is the best solution if you can't find the right oil; a colder thermostat will help, but won't really fix the problem.
i use castrol 0-30 slx i take picture of my spark plug but i cant post it to the forum..
outside temperature changes between 15 C - 25 C
