Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 75 of 261
Thread: TS Parts/Repair List
  1. #51
    Jun 2003
    Pac Northwest / GWN Eh!
    97 E36 M3/4 FI
    Thanks TS guys for a great thread!
    97 ///M3 Turbo Saloon
    VEHICLE: TRM Tuning Turbo System | Built Engine | SwainTech coatings | Custom 3.5" exhaust | Cryo Treated 210mm 3.15 Diff w/40% lock-up | 420G 6-speed transmission | UUC Twin Disc clutch | AMS-500 | AST Suspension | AP Racing | Racelogic TC | Dr. Vanos | Riot Racing BBTB | Vorshlag | UUC | AA | JT Design | Recaro | SPA Technique | VDO | Raid | Turner | Castillo Design FXR Retrofits | Zionsville Autosport | Stewart Components | Motion Motorsport underpanel | Z3 steering rack retrofit | Billet throttle body bushings
    SOUND: Pioneer DEX-P99RS | Dynaudio | Morel | Image Dynamics | Arc Audio | JL Audio | Audio Control
    OTHER: AEM Wideband Failsafe gauge | Ecliptech | Escort 9500Ci | LI | Hüper Optik | Llumar Air Blue | Skene Design
    PHOTOS: Engine Bay: Click
  2. #52
    Sep 2003
    nj
    99 m coupe, 88 M5
    I am not sure what seal ring the es guys use but AA Ts owners can buy pulleys from Kenne Bell. They are only $60-$70.
    JMC
    Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
    Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
    Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
    COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
    HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
    THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
    Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
    COMING SOON: custom intake
  3. #53
    Oct 2007
    Denver, CO
    99 M3, 82 500SEC, 07 FJ
    Quick question on the oil level for the supercharger unit. Is there an easy way to check the level or would it just be suggested to drain it and fill it back up with the proper amount everytime?
    99 M3..............twinscrewed and wallet hungry
    07 FJ.......... lots of skid plates, lots of trail damage
    82 500 SEC......ROADHAUS
  4. #54
    Jun 2003
    97 E36 M3/4 FI
    Easy way? Unfortunately not. The best current method is a novel sight glass retofit from forum member Neil. The link for the information is from post #31 in this thread, or
    http://forums.bimmerforums.com/forum....php?t=1017257
    Quote Originally Posted by G60 CAB View Post
  5. #55
    Orland Park, IL
    2015 BMW 335i xDrive MSp
    For those who have had their radiator hose bracket bolt strip out I just fixed mine using a M6 x 1 Helicoil kit. It was a quick and easy fix.
    I inspected the barbed fitting for the idle bypass hose and found that it was separating from the HFM connecter elbow. I believe someone else had this issue in the past. I cleaned the old adhesive off and used Liquid Nails perfect glue which seams to have set up just fine. We’ll find out how well it holds after I get a few days on the road. Josh recommends superglue gel with accelerator. Everyone should keep an eye on this because it could be a source for a big leak in a place that would most likely go unnoticed.
    I recently had my water pump pulley break and I replaced it with the ES under drive pulley set. What a real nice system!
    If anyone finds anything else please add it to this thread. This is a great resource!
    2009 BMW 335i
  6. #56
    Huntington Beach, CA
    E84 X1 35i ///M
    Quote Originally Posted by M Not Z View Post
    I had a leak in my idle bypass hose as well, I used some 3M 5700 marine sealant that I had for my boat... I have had this on for several months now without issue...
    2015 E84 X1 35i ///M +JB4
    __________________________________________________ __________________________________________________ _____________________________
    RIP --- 98 ///M3 Mods:- Eurosport TS - (EVO)Euro 6-speed
  7. #57
    Jul 2001
    Missouri
    See Signature
    Where is this idle bypass hose?
    How did you locate a leak?
    Thanks to all for keeping the thread going.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    -- Warm memories of 99 M3 w/ Eurosport Twin Screw, 2007 335i, 1970 Cutlass, 1989 328is, 1990 328i, 2012 S4, 2018 S4
  8. #58
    Sep 2003
    nj
    99 m coupe, 88 M5
    Quote Originally Posted by Johno View Post
    You already delt with this issue when your intake boot tore and you had to re-glue it.
    JMC
  9. #59
    E84 X1 35i ///M
    HAHAHA
    Johno you are TOOOOO paranoid.... just drive your car and use it for what it was meant... FUN!!!!
  10. #60
    Orland Park, IL
    I was cleaning up after I had issues with my cooling system - water pump pulley broke and then my radiator hose broke. I pulled the boot off of the TB to wipe it down and remembered that others had this issue. I saw that the elbow was starting to come off enough to allow for a large leak. It's back on now and my 2 new hoses should be here today from Bimmerzone as should my 2 spare intake manifold gasket from VAC. I decided I'd order spares just in case.
    2009 BMW 335i
  11. #61
    Nov 2003
    Minneapolis, MN
    99 M3, 13 650 Gran Coupe
    A picture if you have the means/time?
    '99 Hellrot M3 vert; Eurosport twin-screw SC w/ 76mm pulley + Schrick cam (i.e., TRM Stage 2 TS), UDP's,
    oil cooler; GC coilovers; Z3 steering rack; Euro 6-spd trans; Diffsonline 3.46 LSD
  12. #62
    Orland Park, IL
    Quote Originally Posted by agu845 View Post
    A picture of what? the elbow joint? Let me know and I should be able to get to it this evening.
    2009 BMW 335i
  13. #63
    Nov 2003
    Minneapolis, MN
    sorry for the delay in reponding, I meant a picture of exactly which elbow you are referring to. I'm not as paranoid as Johno, but do like to learn from other TS drivers' experiences, that's all - in case some day it does happen to me
  14. #64
    Jul 2001
    Missouri
    See Signature
    I'm not paranoid. You guys all want me to think I'm paranoid......
    I just don't know anything about idle bypass and would like to learn....
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  15. #65
    Nov 2003
    Minneapolis, MN
    Just beacuse you're paranoid doesn't mean somone isnt out to get you.....
    JK, i am the one asking for the elbow picture, so I understand
  16. #66
    Jul 2001
    Missouri
    See Signature
    Maybe I should list some sort of OCD medication in the TS parts list. There is a bit of a compulsive aspect to modifying an already nice car to make it faster.
    BTW, as part of my paranoia, I picked up a spare gatorback belt at the auto parts store yesterday. Runs about $28.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  17. #67
    Orland Park, IL
    I'm a little paranoid as well. I have an extra belt, radiator hose, and 2 manifold gaskets! Here is a blured shot of the elbow joint I had to rebond to the HFM connecter elbow. It's amaizing the difference I'm feeling
    Attachment 259575
    2009 BMW 335i
  18. #68
    Jul 2001
    Missouri
    See Signature
    Attachment 259575
    TWO manifold gaskets! That should get you home no problem. My extra gasket is hanging in the garage. Maybe I should move it to the trunk along with a tool box.
    OK, so are we talking about the black rubber boot that Josh engineered from a couple of parts? If so, the glue on mine failed months ago, and the stuck-on part began to come off the boot. The magic trick for me was 3M trim adhesive. Then one day I found the teeniest of little pinholes where some air was getting out from my repair. (Just remembers I need to check my glue job on the glue job.) Watch that part. The glue Josh used gets brittle with heat. The 3M stuff is rated to 300 degrees plus, or something like that. Mine is still holding many months later.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  19. #69
    Orland Park, IL
    That's the part! The original adheasive became brittle and it was starting to come off. After I reglued it to the boot and let it cure foir 24hrs I laid a bead of adheasive around the edge to make sure there was no possibility for a pinhole leak. So far so good! The Liquide Nails seams to be holding up but we'll see after it is exposed to heat. I think I'll pick up some of the 3M to have on hand just in case. I'm sure I can find other uses for it around the house! If anyone has an emergancy need for a 1 piece manifold gasket I have an extra one I can send out! I was in St Louis 3 weeks ago and almost gave you a call to see the car. The next time I'll make sure I let you know.
    2009 BMW 335i
  20. #70
    E84 X1 35i ///M
    Hey Johno... I hope you know I was just bust'in your shoes, right???
  21. #71
    Jul 2001
    Missouri
    See Signature
    I hope you do look me up next time.
    I found the pinhole in my glue job by pressurizing the intake with about 3 PSI, and my daughter could hear the tiny hiss. (I could not). Moe Muny had the same glue-failure, IIRC. Looks like we need to put the boot down as a maintenance/check/wear item. I'll adjust the original post to suggest this.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  22. #72
    Jul 2001
    Missouri
    See Signature
    Quote Originally Posted by MoeMuny View Post
    Definitely not any problem here with your shoe-bustin. And besides, if the shoe fits....
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  23. #73
    Nov 2003
    Minneapolis, MN
    Attachment 259575
    thanks for the picture post. Its hard for me to fully see the underside of that connection, but what I see looks intact. I guess I could partially disassemble it and look underneath, or take the lazier route of spraying a little it of brake cleaner along the underside while she idles to listen for sounds of an air leak.
  24. #74
    Jul 2001
    Missouri
    See Signature
    much easier to uninstall and visually inspect it. A couple of seconds for removal and installation. Any leak at this glued seam will be visually obvious.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  25. #75
    Utah
    M3's , 330CI
    My ES style manifold gasket went again, I did not replace it with the shrick last time... This time I will. Ugh not looking forward to pulling the SC off again.
    D R I V E A D D I C T • Eurosport TS E36 M3 • E36 M3/4 • 330CI ZHP •
