Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 26 to 50 of 261
Thread: TS Parts/Repair List
  1. #26
    Sep 2002
    USA
    BMWs
    Grab a resistor an put an LED on the 12v circuit for your pump - no more guess work as to whether the pump is getting power or not. if its a fuse on the pump, simply do the same thing, except access the pads for the fuse.
  2. #27
    Orland Park, IL
    2015 BMW 335i xDrive MSp
    Quote Originally Posted by UrineMachine View Post
    Great idea. The only issue I see is it is possible for the pump to be getting power but not moving any fluid.
    2009 BMW 335i
  3. #28
    Jul 2001
    Missouri
    See Signature
    Bump for updated information on Bypass valve proper operation diagnosis...
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    -- Warm memories of 99 M3 w/ Eurosport Twin Screw, 2007 335i, 1970 Cutlass, 1989 328is, 1990 328i, 2012 S4, 2018 S4
  4. #29
    Califronia
    what else, M3 ;)
    do you regret getting a TS johno?
  5. #30
    Jul 2001
    Missouri
    See Signature
    sometimes. I regret having it installed incorectly, and service is an order of magnitude more complicated.
    If I could have all the money back, I'd take it.
    But I enjoy it a lot when everything is working.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  6. #31
    Jun 2001
    Wash, DC
    2011 1M
    Link to instructions for adding an oil level sight glass to twin screw.
    http://forums.bimmerforums.com/forum....php?t=1017257
    Neil
    MDORPHN - 2011 Alpine White 1 Series M Coupe w/stuff
  7. #32
    Utah
    M3's , 330CI
    Just wanted to add this to my subscribed threads... I think my intake gasket went out again... Going to use the better one next time.
    I have not driven my TS pretty much since December when I got my New M coupe. Oh and it needs a Clutch, Brakes, and tires, rear shock mounts... better sussy... another reason it has just been parked
    The people running the smaller pulleys did you need to change out the belt size? Or does the tensioner take up enough of the slack?
    D R I V E A D D I C T • Eurosport TS E36 M3 • E36 M3/4 • 330CI ZHP •
  8. #33
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Josh did not have me change the belt size,
    but it was based on my Eurosport underdrive pulley set.
  9. #34
    Utah
    M3's , 330CI
    Quote Originally Posted by milKT View Post
    ok I have the UD pulley set as well.
  10. #35
    milKt's Avatar
    The replacement (sturdier) intake gasket referenced
    in post #1 is the Schrick M52 manifold gasket?
    I ask because the link has moved.
    help
  11. #36
    Jul 2001
    Missouri
    See Signature
    Correct on Schrick. Not sure about M52. It is an intake manifold gasket for an e36 M3, and it costs about $24.
    It is much beefier.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  12. #37
    Dec 2005
    md
    Bus,Metro,Walk
    thanks Johno for starting this write-up.
    my problem was a combination of a loose/broken resistor in the yellow wire for the maf AND a collapsing isc hose(both 1 and 6 in. hose) behind the TS unit as suggested by jmc(Joe).
    car is all good now-no cels or idle issues!
    thanks guys
    BTW: fixed the collapsing hose issue with 1/4 in. pvc pipe cut to length and shoved with in the hoses.....
  13. #38
    Jul 2001
    Missouri
    See Signature
    Thanks. It's interesting to see the common ground on TS trouble as we do the long-term R&D testing for the manufacturers.
    Common problems seem to be:
    • Blown water pump fuses
    • Paper intake gasket
    • Fuel pressure regulation
    • Collapsing hose
    • Bypass valve failure
    • Potential-vanishing TS oil
    Did you use the same resistor or replace it?
    I need to find a source for that resistor to place in the original post.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
  14. #39
    Huntington Beach, CA
    E84 X1 35i ///M
    as far as catching the TS oil overflow, this is what I have come up with,
    http://www.steeda.com/products/steeda_oil_separator.php
    I was turned on to it by my neighbor who installed it on his 03 Cobra, it is a very small unit and looks like it will work great, I have yet to install it but it should do the trick nicely
    once I get it set up (in a month or so) I will take some pics and post them up
    2015 E84 X1 35i ///M +JB4
    __________________________________________________ __________________________________________________ _____________________________
    RIP --- 98 ///M3 Mods:- Eurosport TS - (EVO)Euro 6-speed
  15. #40
    Jun 2001
    Wash, DC
    2011 1M
    Quote Originally Posted by MoeMuny View Post
    Unless you're planning to re-route the vented oil back into the compressor gearcase (which would be a desirable feature), it's not clear to me why you would need a separator as an oil catch-can.
    Neil
  16. #41
    E84 X1 35i ///M
    right now the vent on the top of the EuroSport TS goes into the intake boot, I would like to stop the oil from dumping there, and at the same time you will be able to see how much blow-by the TS creates...
    but you could re-route it back to the TS case if you wanted
  17. #42
    Jun 2001
    Wash, DC
    2011 1M
    OK.
    I've chosen to simply vent the case to the atmosphere and monitor oil level with the sight-glass assembly (link to instructions above in this thread).
    Neil
  18. #43
    Sep 2003
    nj
    99 m coupe, 88 M5
    Since I started using 20w50 i deleted my catch can with a return and I have not lost a drop I want too see what happens as the oil gets thin/old
    Jmc
    Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
    Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
    Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
    COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
    HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
    THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
    Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
    COMING SOON: custom intake
  19. #44
    Dec 2005
    md
    Bus,Metro,Walk
    Quote Originally Posted by Johno View Post
    hit that in the head.....seems we are all the test mules
    "Did you use the same resistor or replace it?"
    i had touble finding it locally.....
    the guy at radioshack suggested to me a temporary fix until i find the correct value resistor(i'm looking/calling around).
    he hooked up in series a 1.5k-ohm resistor and a 470 ohm resistor to come up close with the posted value of 1.91 k-ohm value of the original resistor.
  20. #45
    Jun 2003
    Pac Northwest / GWN Eh!
    97 E36 M3/4 FI
    JMC: You are simply running with the stock vent plug now?
    Quote Originally Posted by jmc View Post
    Jmc
    97 ///M3 Turbo Saloon
    VEHICLE: TRM Tuning Turbo System | Built Engine | SwainTech coatings | Custom 3.5" exhaust | Cryo Treated 210mm 3.15 Diff w/40% lock-up | 420G 6-speed transmission | UUC Twin Disc clutch | AMS-500 | AST Suspension | AP Racing | Racelogic TC | Dr. Vanos | Riot Racing BBTB | Vorshlag | UUC | AA | JT Design | Recaro | SPA Technique | VDO | Raid | Turner | Castillo Design FXR Retrofits | Zionsville Autosport | Stewart Components | Motion Motorsport underpanel | Z3 steering rack retrofit | Billet throttle body bushings
    SOUND: Pioneer DEX-P99RS | Dynaudio | Morel | Image Dynamics | Arc Audio | JL Audio | Audio Control
    OTHER: AEM Wideband Failsafe gauge | Ecliptech | Escort 9500Ci | LI | Hüper Optik | Llumar Air Blue | Skene Design
    PHOTOS: Engine Bay: Click
  21. #46
    Dec 2005
    md
    Bus,Metro,Walk
    Quote Originally Posted by vr4boy View Post
    not exact but real close-there's a 5% +/- correction value.....
  22. #47
    Sep 2003
    nj
    99 m coupe, 88 M5
    Quote Originally Posted by WK446 View Post
    yes for a couple hundred miles now.
  23. #48
    Orland Park, IL
    It is much beefier.
    I used this gasket and it is certainly the way to go.
    2009 BMW 335i
  24. #49
    E84 X1 35i ///M
    update on the Eurosport Bypass Valve:
    The part itself is made by Magnuson products 805-642-8833
    http://www.magnusonproducts.com/
    part number is 45-01-31-764
    they call it an actuator the price is about $30 I think and it got to me in just a day or two
  25. #50
    Jul 2001
    Missouri
    See Signature
    Thanks to everybody for all of the input on this thread.
    This is turning into a handy list of twin screw info...
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
