Page 1 of 11 12345678910 ... LastLast
Results 1 to 25 of 261
Thread: TS Parts/Repair List
    Jul 2001
    Missouri
    See Signature
    A couple of comrades suggested I make this thread. I'm not sure how it will go given AA's excellent two-year warranty would presumably cover any repairs for those lucky customers. So this thread might be before its time. On the other hand, ES TS has zero warranty, at least in my case. Still, I'd rather source from Josh if needed, but some customers may wish to get parts from sources other than AA or ES. So here goes.
    The idea here is to post any TS replacement parts or repair sources that you are aware of:
    ES E36 Kit:
    Standard ES belt: Goodyear Gatorback "The quiet belt" 4060760/6PK1930
    Fuel Injector Make unknown -- D3165BA
    Delphi / Lucas
    37 lb / hr. Disc Injectors
    Part Number Delphi D3165BA (Lucas old 5203002, Lucas New 621037)
    Static Flow Rate: 37.27 lb/hr @ 43.5PSI (300kPa) or 282gm/min
    Dynamic Flow Rate: 8.42 gm/pulse - 2.5ms pulse width and 10ms repetition rate
    Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
    Injector source: http://www.racetronix.com/621037.html
    S/C Oil? Mobil 1 15w50 long life -- 100 ML
    Radiator hose -- upper radiator hose is from a 1995 540.
    Intercooler coolant sensor (Found on later models) -- This is part number 61 31 8 360 459 -- Washer Level Sender used for Fits BMW : 318i / 318i Convertible / 318is / 318ti / 323i Convertible / 323is / 328i / 328i Convertible / 328is / M3 / M3 Convertible
    Intake gasket? Use this one BMW M52 intake gasket: http://store.nexternal.com/shared/St...t=products.asp (This Kevlar-reinforced intake gasket is much beefier than the paper gasket. That could make the part less sensitive to installer precision.)
    Twin Screw repair source?
    Fuel Pump -- Made by Walbro -- replaces factory part.
    Throttle body?
    ITG Filter?
    Note: I tried an Amsoil for no oiling hassels and to eliminate risk of expensive HFM contamination from the No-Toil Oil.) 6/4/08 update -- my Amsoil air filter is going back in at the next ITG change. 9/15/09 update -- Amsoil may have led to or contributed to fuel air problems. Conforti says tune is "very, very, very" sensitive to intake air flow. ITG filter is back on.
    HFM: Porsche part number: Bosch 0280217803 (Seems to be from a 933 or a 911, but not sure what year.
    REPAIR TIPS:
    MAF Wiring Resistor -- ES twin screw has resistor in MAF line that can come lose or fail. The correct resistor value is exactly 1.91 K Ohms.
    Fuel Pressure Spec -- Here is the required fuel pressures:
    Idle -- with vacuum connected: 44 PSI
    0 Vac. 0 Boost -- 51 PSI
    X pounds of boost -- 51 + X PSI.
    Air Fuel going Wacky? CHeck for compressed hose at the back of the TS. You're looking for that big "coolant-looking" hose that is right at the back and is about 6 inches long. It has a spring inside to keep it expanded. This spring has beem known to collapse and allow the hose to collapse at idle.
    Seem low on power? Check for blown fuse on the intercooler pump.
    Can't keep car running after messing around under the compressor? See if you accidentilly bumped the idle control valve out of place. Massive vaccum leak if it's unstuck.
    Bypass Valve Operation Check:
    The bypass valve is at the back (top) of the ES TS, with a vac line running into it. It's a black cylinder with a V stamped in the plastic. These can go bad, at some unspecified interval. Two ways to check for proper operation:
    1. Peer into the bottom of the PBV with a flashlight. Note position of lever. Start car -- position should have changed.
    Option 2 -- Detach vac hose from the BPV cylinder. Add vacuum to nozzel on the PBV cylinder, using a cheap hand vac. pump. You can see if the lever is retracted into the BPV. If the lever doesn;t move with vacuum and back with no vacuum, it's bad and call Josh.
    Maintenance Items to Have on Hand --
    Intake gasket
    Drive belt
    Extra radiator hose
    Last edited by Johno; 04-16-2010 at 06:08 PM. Reason: Update for coolant level sensor
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    -- Warm memories of 99 M3 w/ Eurosport Twin Screw, 2007 335i, 1970 Cutlass, 1989 328is, 1990 328i, 2012 S4, 2018 S4
    Sep 2003
    nj
    99 m coupe, 88 M5
    Quote Originally Posted by Johno View Post
    ES E36 Kit:
    Fuel Injector Make unknown -- 1636 (???) part number? D3165BA (Perhaps same as Lucas or Delphi D3165BA)
    S/C Oil? Mobil 1 15w50 long life -- 100 ML??? (Is 100 right or is it 150?)
    Radiator hose?
    Intake gasket?
    Throttle body?
    ITG Filter?
    Other?
    Your rad hose is from an e34 540, the TB is stock, the ITG filter can be sourced from a few companies online, just go to ITG web site. BUT the g60 conical is an ES only item, you can only buy the cylinder type online.
    The gasket is an ES item only for the ES TS as far as I know.
    I believe the BPV is a eaton but I cant swear to it.
    repairs go here:
    http://www.pse.us/products.Aftermarket.htm
    AA part list:
    Meachincal tensioner BMW PN 11281427252 (ES ALSO)
    NAPA BELT: 25-060744 (GATOR BACK 4060745)
    Intake Gasket OBD1 11611717259 (qty 6)
    Idler pulleys (for snout bracket) Toyota timing belt idler 13503-63011 make sure it uses bearing PU355816rr9d
    K&N RU-3130
    MAF porsche TT
    Injectors? lucas 42lbs I think.
    Everything else should last forever...I hope.
    JMC
    Motor: Hurtig/AA custom 2.0l TS OBD2 AA tuned 444whp/384wtq SAE 470whp/400wtq STD
    Exhaust RMS headers, Maximum PSI custom exhaust, magnaflow mufflers
    Driveline E46 M3 6 SPEED, 2.93 LSD, Rouge SSK/tranny mounts, UUC Ultrasmooth /LTW steel flywheel. CDV delete, UUC clutch pedal bushings with GSP pedal
    COOLING: Stewart WP, 78* thermostat, S54 radiator, Euro/S54 oil cooler, ES TS oil cooler adapter, M3 power steering cooler
    HANDLING: MR M CAR SF reinforcement, TCK D/A CO 450/500, TCK Camber Plates, Rogue RSM, Ireland SFB, Dinan STB. CCW classics, polished lip, brushed centers. P295/30/18 P245/35/18.
    THE SHOW: Stygar Z8 Nozzels, Leather Z armrest, Z8 push button start, chrome door handles, OEM FOGS, BMW Traffic Pro.
    Monitoring: PLX Wideband, VDO vision boost/VAC both with custom chrome trim ring.
    COMING SOON: custom intake
    Orland Park, IL
    2015 BMW 335i xDrive MSp
    Quote Originally Posted by jmc View Post
    Your rad hose is from an e34 540, the TB is stock, the ITG filter can be sourced from a few companies online, just go to ITG web site. The gasket is an ES item only for the ES TS as far as I know.
    repairs go here:
    AA part list:
    K&N RU-3130
    MAF porsche TT
    JMC
    Thanks for the info. I was trying to find out what the radiator hose was so I could get one on order. My belt broke and I could feel where it put a crease in my current hose. Time to change it!
    2009 BMW 335i
    Jun 2003
    Pac Northwest / GWN Eh!
    97 E36 M3/4 FI
    Johno: 100 mL is correct (Mobil1 15-50 Extended)
    97 ///M3 Turbo Saloon
    VEHICLE: TRM Tuning Turbo System | Built Engine | SwainTech coatings | Custom 3.5" exhaust | Cryo Treated 210mm 3.15 Diff w/40% lock-up | 420G 6-speed transmission | UUC Twin Disc clutch | AMS-500 | AST Suspension | AP Racing | Racelogic TC | Dr. Vanos | Riot Racing BBTB | Vorshlag | UUC | AA | JT Design | Recaro | SPA Technique | VDO | Raid | Turner | Castillo Design FXR Retrofits | Zionsville Autosport | Stewart Components | Motion Motorsport underpanel | Z3 steering rack retrofit | Billet throttle body bushings
    SOUND: Pioneer DEX-P99RS | Dynaudio | Morel | Image Dynamics | Arc Audio | JL Audio | Audio Control
    OTHER: AEM Wideband Failsafe gauge | Ecliptech | Escort 9500Ci | LI | Hüper Optik | Llumar Air Blue | Skene Design
    PHOTOS: Engine Bay: Click
    Jul 2001
    Missouri
    See Signature
    Anybody know what car/part is the MAF or HFM from?
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    Huntington Beach, CA
    E84 X1 35i ///M
    I believe the eurosport one is from a porshe
    2015 E84 X1 35i ///M +JB4
    __________________________________________________ __________________________________________________ _____________________________
    RIP --- 98 ///M3 Mods:- Eurosport TS - (EVO)Euro 6-speed
    Jul 2001
    Missouri
    See Signature
    Edit: That has proven to be correct. The original post is edited to reflect this.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    Jul 2001
    Missouri
    See Signature
    Any other parts info? I changed the first post to reflect the Eursport HFM.
    I can circle back to add that Shrick Kevlar gasket for the intake.
    JO
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    I believe the ES TS injectors are 36 lbs
    AA probably needed to upgrade to 42 lbs for the stage 3, JMC
    but use 36 lb for the first two stages.
    (correct me, I may be wrong.)
    milKt's Avatar
    Who spelled Porsche wrong?
    Sep 2003
    nj
    99 m coupe, 88 M5
    Quote Originally Posted by milKT View Post
    Yea thats wrong..42lbs for all stages.
    JMC
    milKt's Avatar
    JMC
    for AA maybe.
    Orland Park, IL
    for AA maybe.
    36lb for ES. I would love to have 42lb injectors with the 73mm pulley. Tuning would be to costly right now.
    2009 BMW 335i
    OC
    95 m3, 08 m3, '87 325is
    73mm goes beyond the recommended rev limit of the twinscrew at redline doesn't it?
    Orland Park, IL
    Quote Originally Posted by borealiss View Post
    That I don't know. I got the pulley from Josh during my visit to Eurosport. IThe 73mm yields ~ 14psi and I thought the the max boost of this TS was around 15 - 16psi at max RPM. This makes me believe I have a little buffer before maxxing out the RPM. I hope
    2009 BMW 335i
    Jun 2001
    Wash, DC
    2011 1M
    It's pushing the limit and may not be worthwhile without new tuning (perhaps including larger injectors). After expirementing with increased boost together with lowered compression, I opted to return to "stock" set-up.
    Neil
    MDORPHN - 2011 Alpine White 1 Series M Coupe w/stuff
    Nov 2003
    Minneapolis, MN
    99 M3, 13 650 Gran Coupe
    Thomas and Techno550 have a well established tuning solution with 48# injectors. Well, that was with the more conservative 76mm pulley, but I imagine it could be modified for 73. Costs are not that bad actually.
    Good parts list, John, thanks. BTW, you know I was just razzing you on that other thread......
    '99 Hellrot M3 vert; Eurosport twin-screw SC w/ 76mm pulley + Schrick cam (i.e., TRM Stage 2 TS), UDP's,
    oil cooler; GC coilovers; Z3 steering rack; Euro 6-spd trans; Diffsonline 3.46 LSD
    Jul 2001
    Missouri
    See Signature
    We're cool. I derserved it and the razzing was very much on-target.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
    Jun 2001
    Wash, DC
    2011 1M
    Quote Originally Posted by agu845 View Post
    Quite right, just not sure I'm ready to move to OBDI or standalone engine management.
    Neil
    Nov 2003
    Minneapolis, MN
    I will add that neither Thomas nor I have had any real issue with ours, either in terms of reliability, driveability or any other aspect of operation. Still, I understand the hesitency to cross that bridge, Neil.
    OC
    Quote Originally Posted by M Not Z View Post
    that might be the limit for some of the seals within the twinscrew but i doubt that has any bearing on rpm limits. depending on engine and exhaust mods PSI could vary any which way.
    Sep 2003
    nj
    99 m coupe, 88 M5
    You guys are lucky, you must not have OBD2 port inspection. With alot of states making the conversion I hope they dont do it in your state.
    I had disconnected my battery for an electrical install i was doing. I had inspection a few weeks later. Now keep in mind I dont drive my car alot, usually a couple of short rides a week. It took me 10 months to get my OBD emissions rediness to turn on!!!!! I had to re inspect every 45 days to stay legal so I wouldnt get the $180 failure to inspect sticker. And forget about buying them, with everything computerized its tough once you have failed.
    I dont know if its a Z thing but 640 miles later they finally started, some BMW's take forever, some not. It was a pain in the ass. I will never mess with emissions crap after going through that hassle.
    BTW, I got pulled over 6 times for having that big red rejected sticker, NJ cops suck!!! Never ticketed cause I had the paper work!
    JMC
    Nov 2003
    Minneapolis, MN
    I would not have done anything if I lived or had plans to move to such a state.....if my state does, it will take years to implement and by then....well, in a pinch I could revert it, but more likely I would have moved on by then. No fear here
    milKt's Avatar
    The 73mm pulley spins BEYOND its efficiency
    (based on the LYSOLM OPCON graphs for the 1.7l compressor.)
    Jul 2001
    Missouri
    See Signature
    Bump for updated repair information in first post.
    Johno
    -- 2003 e46 M3
    -- 2018 e90 M5
