This may seem like an obvious NO...but I just want to throw this question out here>
I recently changed my tie rods and haven't had a professional alignment since. I would prefer to change them before the alignment since I have some time.
Would it affect the pad bedding if my wheels are not aligned? Should I wait until after the alignment? Thanks!
Alignment does not change any of the angles used between the pad and rotor, so I would doubt it would affect bedding in of the brakes. Though I can't say I'd feel comfortable doing it not having everything aligned.
Strömung Exhaust // Bilstein Sport/H&R Sport Suspension // Microsuede Interior // 6000k HIDs // Cosmos V2 Intake // Manual ZF Swap // Jim Conforti Chip
your brakes goes where the wheels are...i can't see how the alignment would affect the brakes. i believe the alignment only affects how much tire wears.
95 alpine white 318iC - my 1st bimmer!!! now even better w/ dasc, tokico illuminas, h&r sport springs, new wheels, new top & hid...just a few of the sunk costs in this money pit!!!
88 civic w/ zc swap
97 lifted tj
and a few more project cars!!!
Unless your about to replace your tires or change springs, then you should align anyway. Plus, a bad alignment puts a constant load on the bushings, which will wear prematurely.
Yeah, I'm getting it aligned tomorrow, would rather do the pads tonight but I can hold off until tomorrow! thanks
