Trying to get an idea of how peoples I/C's look in their bumper. I mounted my Precision 750hp i/c the other day. Overall I'm happy, but I wish the core could sit closer to the opening in the bumper.
I'll start by example:
Intercooler: Precision 750hp
Size: 31 1/2" L x 10 5/8" H x 3 1/2" D
Kept A/C Fan?: No, but there is room for an aftermarket one.
Post em up
I'm glad you sold the Viggen for this awesome project!
I have the same problem! The I/C doesn't sit flush with the opening of the bumper. In other words, the I/C sits approx. an 1 1/2" away from the opening. Also, it sits approx. a 1/4" low past the bottom of the bumper.
You should probably note how you mounted them also?
ICS Stage 1 NickG tune, 60lb Injectors, Blow through MAF, Synapse BOV, Boostlogic Manifold, BW-S366, Full 4" exhaust, Built Block w/ Wiseco's and K1 Rods = Good Times
Bigsalot, wtf is with your IC hanging below your bumper?!
a32guy, be warned, my IC fits exactly like yours. Until I put the pipes on the end, and they hit the fog lamps, and that broke the outside bumper mounting tabs off. I am going to be welding the endtanks at a 30-45* angle back towards the engine vs having them coming straight off the IC. But thats for v2, I'd like to drive my freaking car currently!!
///Andres
11 X5d sport - daily tow rig
09 335d - evolve tuned 327whp / 490wtq
97 M3 - NASA TTB
95 M3 Turbo - 3.0l s52, PTE74GTQ, AEM EMS & CDI, etc
obviously you can see my fogs didnt fit anymore.
1005whp/831wtq little bit of low boost pump gas magic...
heres mine.
31x12x4
stock Aux fan didnt fit anymore. had to use a slim fan.
my fogs didnt fit either so i got the fog light delete panels.
my intercooler does not hang below my bumper, we tucked it up as high as we could. used angled steel as a bracket welded to the inside of the nose panel and the intercooler is mounted to the new bracket using bolts.
I just welded up a couple of little mounting brackets and bolted them to the vertical bolt on the bumper mounts, also used a cheap slim pusher fan for the condensor. Oh yeah, I cut off the passenger side outlet and welded up a 90 degree elbow for a rearward facing exit.
Hey nice intercooler
Becoming a Professional OT Troll . CAN Bus Project: http://www.youtube.com/watch?v=2QuRBQzGs-c VGT/VNT +LDA controller: http://dmn.kuulalaakeri.org/vnt-lda/
Originally Posted by [B]SilverBeam[/B]Diesel > gasOriginally Posted by sparkchaser
My IC is flush with teh bumper cover. I had to cut the bumper bar out to make it fit the way I wanted. I may pull the alum bumer bar out again and modify it more to get the IC out farther..And weld the endtanks at an angle.
If you look you can see it almost touches the sides of the bumper cover.
Gary Gray
If you can take it apart you can make it faster!
anybody got any premade brackets for mounting?
Intercooler: no name made in Poland
Size: 28" x 9" x 2.75"
Air conditioning: removed
they all look great. If only i had the $ for FI
did anyone have a jtd panel before and were unable to use it with their intercooler mounted???
CP Pistons
Eagle Rods
T67 Turbo
Lots and lots of custom goodies and 666 fab schtuuufff
05/01/07 RIP pops
Normality is the death of personality.
http://www.bimmers.no/viewtopic.php?t=43929
http://www.bilforumet.no/showthread.php?t=162746
