BAVToys
Results 1 to 25 of 40
Thread: DIY: ** E36 STOCK headlight REMOVAL **
    PQ & USA
    --97 SC'd ///M3--04 ///M3 VERT--07 ESCALADE--
    Open your hood and take a look.
    Remove the six (6) screws from your hood cowl and also the tubing at the back and pull
    up and towards the rear of the engine.
    This is what it should look like when you take it off.
    Unhook your headlight bulbs.
    Take out your turn signal.
    Take your 8mm socket and a 19mm wrench and unscrew your headlamps. You will need
    the 19mm wrench to hold the back nut in place while your undo the bolts.
    The first picture are of the screw under the turn signal, the other is closer to the radiator.
    [/color][/b]
    -zkw- -hella- -bosch- -depo- -prolumen- -kwd- -bbs- -predator chromium- -predator ice- -simota- -ecis-
    //-install guides-//-total lighting group buy-//-zkw group buy-// -exhaust group buy-//-ellipsoids+hid group buy-//-led tails group buy-//
    Columbia, SC
    '95 325is, '97 M3
    it's not too hard, trust me folks
    San Jose, CA
    Calypsorot 328i
    Quote Originally Posted by PirateJake View Post
    Especially if you take off the radiator cowl and leave it off!
    Sep 2003
    Athens, GA
    2K M Roady, '86 944T
    Quote Originally Posted by BMWALDO View Post
    Nah. You need that for aerodynamics and proper cooling. Leaving it off will make your car slower.
    Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
    San Jose, CA
    Calypsorot 328i
    Quote Originally Posted by Robstah View Post
    I <3 you
    Sep 2003
    Athens, GA
    I <3 you
    Mar 2005
    St. Louis, MO
    E-ballin
    Only problem I ran into was some of the bolts were hard to reach. Real easy if you have the right extensions though.
    Jun 2003
    Los Angeles
    it's no E30 :/
    Quote Originally Posted by addnon View Post
    I lost 2 screws, they were the ones that were hard to reach, but I've taken apart my headlights like 30 times since I've owned the car lol
    R.I.P. Louie: TehPandaShow gone but not forgotten
    PQ & USA
    Quote Originally Posted by The-Great-328ic View Post
    a little piece of tape in the socket will prevent that.
    Jun 2005
    Fairwood,WA
    03 X5 4.4i
    do one for E46?
    OB
    PQ & USA
    Quote Originally Posted by sadkorean34 View Post
    do one for E46?
    working on it.
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    do one for E46?
    Remove 4 8mm bolts: 2 near the radiator support, 1 behind the light assembly and 1 behind the inner light. That bolt is easier to get through via the grille area.
    Los Angeles, CA
    1997 Alpine White M3
    Dont you need to ziptie the corner lights if you take them out?
    San Jose, CA
    Calypsorot 328i
    Quote Originally Posted by 6i9 View Post
    What?!
    Why?!
    Mar 2006
    Chicago, IL
    99 Estoril M3
    That's only if you break the tabs.....like I did....
    Keflavik, Iceland
    EY40858 & JE35415
    When I first took a headlight off an E36, the hardest part was to remove the blinker. I always broke them and had to buy new ones
    1998 Honda Civic 1.5i
    1999 E46 320i
    2001 E46 330i
    2017 VW Polo 1.2 tsi
    Atlanta
    98 328i Sedan
    cool
    Omaha
    '00 M5 '07 750i '87 325
    What's the easiest way to hold the adjusters for the screws closest to the radiator? Mine just spun and the gap between the lens and the body was too narrow to fit a 19mm wrench in there.
    I'm not sure exactly how I eventually got mine out.
    PQ & USA
    Quote Originally Posted by IppoJ View Post
    they have a wedge in them, stick a flat head in it to stop them from spinning.
    Omaha
    Quote Originally Posted by habbie View Post
    You mean put the flat head in from above, right? I tried fitting one in between the lens and body.
    Thanks for the tip!
    PQ & USA
    Thanks for the tip!
    the black plastic insert has a wedge in it, stick the screwdriver in the wedge and you are golden.
    Portland, OR
    2003 Subaru WRX
    is there a special tool for doing this? i cant seem to reach the two that arent right on top of the light.
    PQ & USA
    Quote Originally Posted by bimmerE36freak View Post
    see the wedge in there? that where you put a screw driver. if not a wrench, if not then pliers if not pull the plastic insert completely out and get the bolt out of it.
    Portland, OR
    2003 Subaru WRX
    thanks but im talking about the other two, the ones that arent on top of the light.
    PQ & USA
    same difference, twist them out and then take the 8mm bolts out.
