Ok,
I have had a CEL reading p1519 for the longest time now. I have been searching the forum trying to find the right thread with that magic answer to get rid of this damn code, but that has lead to no avail. I was told that I have a sticking VANOS so I figured I would start thereish. After reading around, I decided to see what I could do with my VANOS solenoid. I called my local dealerships and the cheapest i can get this part for is $198, so screw that, and I wasn't able to find the part at any local pick-a-parts. I read a thread in which a guy tried cleaning his VANOS solenoid with desil fuel, but he didn't really go into what success he had. I am wondering if anyone has been able to successfully clean their VANOS solenoid, and if so how? Also, any other help or advice on getting rid of this code would be GREATLY appreciated.
P.S. If I do become convinced that my VANOS unit itself is the problem, than I will be buying a new unit from drvanos.com.
Thank you for your time and help.
Have you tried testing the solenoid yet?
Very easy to do, just need a big cresent wrench or 32mm open end to remove it, and then you can apply 12v to the plug, being careful to match the + and - correctly.
You should see the small pin in the solenoid pop out. If it does, then it's ok.
If not, let me know... I have a 'few'.
Chris
DrVanos.com
Ok, so I checked the solenoid and the pin sure enough did shoot up when the electrical current was supplied. However, should the pin shoot back down when the current is removed or should it just kinda chill there and slowly go back down or go back down at all?
The pin was never forced back down once the current was removed. It would either slowly move back into the solenoid or i tried pushing it back in and there was a fair amount of resistance.
No, I think you misunderstood. The spring part is in the vanos itself. If you pull the solenoid off you'll see a small plunger about 10mm across in the vanos that is spring loaded. That is what pushes the pin back when the current is removed.
What I meant was that with the solenoid installed, the spring loaded plunger will push the pin back in.
Hard to explain, but your solenoid sounds like it's working just fine.
Chris
DrVanos.com
got it. Thanks for the input and help.
It's greatly appreciated.
Just in case this might help somebody somewhere. I found out what was causing my CEL code. I changed the VANOS solenoid and presto, problem gone. After further investigation i found that my original VANOS solenoid was only shooting the pin out 3/4 of the way. It was a PITA but i'm glad that hurdle is done with.
