Anyone have a problem with the AA strut bar hitting the underside of their hood?
Mainly the insulation thats on the underside of the hood?
There is a slight bulg in the insulation on the underside of the hood...Anyone know what purpose this serves?
Anyone have any tips?
98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
2017 Toyota Tundra Crewmaxx - Family Whip
2011 Pierce 75' Quint - Fire Apparatus West Islip FD
Mine used to touch... but it wasn't a problem.Originally posted by NY98M3
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
mine touchs no problem tho
This shop ripped me off and they'll rip you off too!
~~~> Autobahn EBAY ID: 1autobahn1
444 Vernon Way, El Cajon, CA 92020
619-444-2290
When i first installed the bar on my '94 325i, I didn't notice that it was touching. Now there is a small upward dent in my hood over the driver's side strut tower. Grr:
1996 Hellrot on Modena M3
1991 Imola on black 318is
Same thing happened to my friend as it did to Aquila. He had two upward dents on his hood after the install. Pretty piss poor design flaw, assuming it wasnt an installation issue.
Are you guys talking about dents in the actual hood or the insulation?
I don't have a strut bar, but I installed an under hood light, and I noticed that the insulation is sagging. I didn't notice this until I put the light in, and there is no way to notice unless you do what I did. So what I'm saying is that maybe your insulation is sagging.
I dented my hood when I installed my AA front strut brace, but that's because the wiring was in the way. You know that cable that normally clips into the stock shock tower cover on the driver's side? That has to go around the base of the brace, not over it. Otherwise, you'll end up with a nice dent in the hood (the metal, not just the insulation)
That being said, my brace touches the insulation, but isn't causing any trouble.
-c///m
1997 Estorilblau M3 2-door
Performance: JC euro intake, AA Gen III exhaust, Evosport UDP, fan delete, Schrick cams, OBD-I intake manifold, 540 HFM, ASC delete, 24# fuel injectors, DiffsOnline 3.46 40% LSD, Boston BMWCCA sticker
Suspension: TC Kline SA (Suck-A**) coilovers, ///M front strut brace, X-brace, TCK RSM, Powerflex RTAB, Turner sways, Motorforce camber plates, RRT reinforced rear LCAs
Lighting: ZKW w/ HID, Euro clears, Lamin-X foglight film
Other: Z3 steering rack, SS brake and clutch lines, Stygar SSK, UUC TME, VDO Gauges, MB Quart Discus components, MB Quart Discus 6x9 triaxials, Audio Art NA 4070 280W amp
Did it make any rips or tears in the insulation?
Get an OMP bar.Non-hinged. No issues and $179, Italian made.
Edit: Didn't realize you already had the AA NY98
Walk a mile in my shoes and you are a mile away in someone else's shoes.
Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
Coming...nada
BMWCCA-303681
NY98M3 - You might want to try and close your hood in a different fashion to prevent dents from the bar. The JT-Designs bar is a close fit too and it touches the insulation as well. Now, when I close my hood, I manually put it down all the way and then push it closed with my palm over the BMW Roundel. No dents so far...
1993 Acura Legend L Sedan
2009 BMW M3 Sedan
My aa bar hit the insulation too. I always carefly close my hood and I have had no problems. It does not tear the insulation but just kinda indents it in a little. i imagine if the hood is slammed and the locking catch is at its lowest it may dent.
Car looks good!
"It does not tear the insulation but just kinda indents it in a little."
Is there any purpose for the insulation on the passenger side to be the way it is? Is there anything underneath there?
Car looks good!
same thing happend to me. i had to totaly remove the insulation and cut a chunk out of my VIS carbon Fiber hood: not too happy about that one.
- CJ - Turbo ///M3
