Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
Thread: I can PROBABLY get the S50 B30/32 VALVE TAPPET DEPRESSOR (115-070): Who wants one??
  1. #51
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    Quote Originally Posted by Shock(/\)ave View Post
    Should we attempt to get a quote for group pricing on the S14/38 version of the tool?
    I just wanted to update everyone. I just looked up these tools and the shim kit on the updated etk. They are the same part numbers for the s14/s38 and the s50b30/b32. They tappet depressor and the shim kit are Identical, and DO work. I just tried this last night on my car.
    FYI, the s50b30/32 part HAS been superceeded to the s14/38 tool.
    The Original GoldMember!!
  2. #52
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    Quote Originally Posted by Thewiseguy View Post
    What are the new BMW part numbers?
  3. #53
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    Ill post them tomorrow
  4. #54
    Jun 2001
    Reston, VA
    88 M5 FOR SALE, E92 335i
    The B30 shims are in the thicker range, where the B32 shims are typically thinner than what come in the S14/S38 shim kit. For the B32 owners, you'll have to either order a handful of shims in each thickness in the high 2,--mm range, or check clearance, measure shims, and order the correct shims for your car. They are around $8-9 each from the dealer, so ordering half a dozen shims of each size (0,05mm increments) from 2,50mm to 3,20mm gets expensive very quickly! I think with all the B32 engines I have around here, I may just have to suck it up and do that.
    James Muskopf
    RRT Racing
    DC Metro's premier BMW service and racing facility
  5. #55
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    Quote Originally Posted by JamesM3M5 View Post
    Bmw still lists the same part number for the b30 and b32 kits. However like you stated, the thickness' for the b32 go to a lower range. These are not available in a kit. As far as I know you have to order them seperately.
  6. #56
    Victoria, BC
    1999 M3 Evolution
    I needed a bunch of shims between 2.70 and 2.90 and all of the dealers around here and in Seattle only had shims over 3.00 in their kits. I ended up ordering some from Germany.
  7. #57
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    part number for the tappet depressor is: last 7 is, 11 3 170
  8. #58
    Sep 2003
    PA
    M3 x 2
    valve adj tool
    I need to bow out of the gb. Already have an s14 tool. (for which there are aftermarket suppliers).
    -MJ
  9. #59
    Avoca Beach NSW Australia
    1995 EuroM3 92 Range Rover
    I think the GB is dead.
    I bought an s14 tool from Samstag.
    Regards Philip A
  10. #60
    Aug 2003
    Holland
    '97 Hellrot euro M3 SMG & '93 dakar yellow euro M3
    Interesting info in here, missed this up until now
    It's almost impossible to get tools here as well, but if S14 works then it should be easy
    E36 M3 S50B32 daily - E36 M3 S54 trackcar
    They Say Money Talks, All Mine Ever Says Is Goodbye
  11. #61
    Apr 2014
    Castlegar,BC,Canada
    94e36M3RIP, 95 318 S50
    I know this is an old thread. and I think the answer is already here. I would just like to get some clarification if it is possible. Can the BMW tool 113170 valve depressor for the s14/s38 be used successfully on the s50b30 euro engine? Does anyone have any real experience with this, so I can be sure before dropping 125$ on the tool.
  12. #62
    Oct 2003
    Colorado Springs
    E30 M3,E28 M5,E39 M5 etc
    yes.
  13. #63
    Canada
    E30 M3, E34 M5, E36 M3
    Exclamation
    The S50B3X valve tappet tool is now available for special order from your BMW dealership with an active part number of 83300491053.
    It is definitely the exact same tool with the original tool part number printed on it:
    https://www.turnermotorsport.com/p-1...uine-bmw-part/
    As an added bonus it's less than half the cost of the S14/S38 tool as of this post, though I ordered both tools to service all of my cars. Get yours while you can!
  14. #64
    The Netherlands
    DE-spec E36 328i/M3 cab
    Just tried to order this item 2 weeks ago, but NLA since August. No new # know at this moment.
    IG:
